Audio Precision APx585 Audio Analyzer to Revolutionize A/V Measurements
Ever so often something revolutionary happens in the A/V world that changes it forever. Rarely do you ever hear an A/V publication pay homage to a test equipment company. The new APx585 8CH HDMI …
AVIA Pro by Ovation Multimedia
AVIA Professional (AVIA Pro) is a multi-disc calibration, set-up and test suite from Ovation Multimedia. The suite consists of seven DVDs plus a user manual designed to be an all-inclusive product …
Imaging Science Foundation (ISF) Certifications
The birth of digital television promises to eradicate the ills of conventional TV. Without an understanding of and careful attention to the established standards, DTV will fall victim to difficulties …
Instek GFG‑8216A Function Generator
The Instek GFG-8216A function generator allows for generation of up to 3MHz in sine, square, triangle, ramp, TTL and CMOS waveforms.
Sencore SP395 SoundPro Audio Integrator
The SP395 Audio Integrator is a capable, versatile and completely integrated audio analyzer for use with custom home theater installations.
Home Acoustics Alliance (HAA) Certification
The HAA is a professional training organization dedicated toward home acoustics. Its purpose is to promote the correct and most effective use of acoustical design and calibration techniques …
Hewlett Packard/Agilent 4275A High F LCR Analyzer
The Agilent 4275A precision LCR meter is a cost-effective solution for component and material measurement. The wide 20 Hz to 1 MHz test frequency range and superior test-signal performance allow the …
Wayne Kerr Precision Impedance Analyzer
The 6400 and 6500 series of Precision Impedance Analyzers provide precise and fast testing of components at frequencies up to 120 MHz. Basic measurement accuracy is ±0.05% making the instruments the …
Datacolor ColorFacts Professional 6.0
Datacolor ColorFacts ProfessionalTM 6.0 is a flexible, easy-to-use color calibration software system. This integrated hardware and software bundle analyzes and optimizes the performance of LCD, rear …
Tektronix TPS 2000
As an engineer or technician, you must often make floating, or differential, measurements. You face faster edges and clocks due to the migration of higher performance technologies to widely …
LMS Analyzer
LMS is an antiquated application that is barely maintained by LinearX, a very small company that is living off its legacy. LinearX never, in fact, bothered to optimize the system to work with modern, …
Audio Precision SYS 2722 Analyzer
With comprehensive PC control, unmatched programmability, and the highest precision and sensitivity of any audio analyzer made, the 2700 Series has established itself as the benchmark for audio test …
Datacolor SpyderTV Calibration System Reporting
Datacolor, until July of 2004, dealt primarily with professional computer display calibration tools and software. Last year, however, they acquired Milori, Inc, a company specializing in the …
