Sencore SP395 SoundPro Audio Integrator
by November 09, 2006
Here's What The SP395 Audio Integrator Delivers:
Fast and accurate adjustments of speaker coverage and cluster alignment, time delays and speaker frequency response equalization; ensures a high-performance, problem free installation.
Tests and documents band-specific background noise, room reverberation, and speech intelligibility to identify problem areas and sign-off the system installation.
Easy to use and interpret user-interface helps you quickly make the test and get the readings you need.
Portable, battery operated (5 hours run time) and handheld instrument in a ruggedized case means you can make precise audio system measurements wherever you do audio system installations.
Optional software feature add-ons such as speech intelligibility, time delay analysis and more mean you are never caught short.
Features & Functions
  • Fast and accurate adjustments of speaker coverage and cluster alignment, time delays and speaker frequency response equalization; ensures a high-performance, problem free installation.
  • Tests and documents band-specific background noise, room reverberation, and speech intelligibility to identify problem areas and sign-off the system installation.
  • Easy to use and interpret user-interface helps you quickly make the test and get the readings you need.
  • Portable, battery operated (5 hours run time) and handheld instrument in a ruggedized case means you can make precise audio system measurements wherever you do audio system installations.
  • Optional software feature add-ons such as speech intelligibility, time delay analysis and more mean you are never caught short.
><br>
Functions
  • FFT Analyzer
  • Real Time Analyzer
  • Sound Level Meter
  • LEQ
  • Sound Study Graph
  • Energy-Time Graph
  • Reverb Decay Time RT60
  • Impedance Meter
  • Polarity Tester
  • Signal Generator
  • Frequency Counter
  • Signal Level Meter
  • Cable Tester
><br><br/>
