AVIA Pro by Ovation Multimedia
by November 09, 2006
AVIA Pro
AVIA Pro
Pro Kit Contents
The contents include state-of-the-art audio and video test signals from Ovation Multimedia, as well as industry standards from CEA and other materials from SMPTE, RPG and Genesis Microchip. The printed manual provides necessary instructions for the use of each disc.
The video test disc* provided by Ovation contains over 1,000 new test signals (with approximately 3,000 variations) and gives the video / home theater professional or enthusiast unprecedented flexibility and new capabilities. AVIA Pro not only improves the “traditional” signals but also permits functions never before possible. The variation of patterns available allows the user to select the one best suited for the job, which results in a customized test pattern generator for each project. Special emphasis during development was placed on testing and adjusting widescreen and newer technology, fixed panel display technologies such as LCD, DLP, LCOS, SXRD and Plasma. (*More specific details regarding the video test disc are available in the attached document.)
AVIA Pro’s audio test disc, also provided by Ovation Multimedia, will include sound tones for Dolby, DTS and surround sound up to 7.1. Also, SACD test tones may be included.
CEA has provided the information necessary for manufacturers to meet specifically the Standard Method of Measurement for DVD-Video Players. (Standard EIA/CEA-896.) This standard was developed based on NTSC specifications and created to make it easier to compare the functionality of DVD-Video players. The CEA disc contains a suite of test signals designed to gauge and evaluate the performance of DVD-Video players. Specifically, the standard defines test signals and test procedures for measuring different aspects of brightness and color, while helping to measure signal and audio-related characteristics.
The SMPTE portion of AVIA Pro specifically monitors equipment errors in the motion imaging industry, focusing on tests patterns for color and motion.
RPG has developed two computer programs titled Room Optimizer and Room Sizer. Both are designed to optimize the placement of listener, loudspeakers, acoustical surface treatment and room dimensions in the Critical Listening Room environment. This software (for a Windows program) is an automated process designed to take full advantage of listener and equipment placement as well as take into consideration the specific room dimensions. The details include a new methodology for determining the room size for the small critical listening spaces to achieve the flattest possible frequency response. Also, RPG provides information for minimizing acoustical distortion in project studios. This includes details relevant to acoustical issues facing design of such studios, suggestions about addressing these problems and the real-world limitations of these suggestions.
The information provided by Genesis as part of AVIA Pro includes various test patterns to optimize microchip technology and help achieve life-like visibly better images.
Sample Test Patterns
  • Temporal Dither and Color Separation Artifact Detection
  • Display Panel Uniformity
  • Display Contrast (On/Off, ANSI, Multi-check, etc.)
  • Light output
  • Panel Response Lag Time
  • Color Gamut Test
  • Color Wheel Speed Measurement
  • DVD Player Layer Change Delay Measurement
  • Color Upscale Error Test
  • RGB Legal, Y/Cb/Cr Bowties for Delay Measurements
  • Luma and Chroma Moving Zone Plates in Video and Film Motion.
  • Chroma Sweeps & Multipulses (Including Polyphasic sweeps to Nyquist Limit)
  • Luma Sweeps & Multipulses (Including Polyphasic sweeps to Nyquist Limit)
  • Variable Intensity Color Bars\
  • Vectorscope Grid Test
  • Above White Signal Handling
  • Below-Black Signal Handling
  • Black and White Clipping Tests Built into Multiple Patterns
  • Black Level Checks built into Gray Windows
  • Monotonicity Tests to Single Bit Count
  • Color Decoder Accuracy Checks
  • DVD Player Pixel Cropping
  • Gamma Response and Linearity to Light Test
  • Grayscale Banding
  • Grayscale Windows from 2.5 to 107.5 IRE
  • Automated Grayscale Measurement (when used with compatible instrument)
  • High Resolution Focus Patterns
  • Saturation and Hue Checkerboard
  • Scaler Light Linearity
  • Scaler Pixel Mapping
  • Screen Hotspotting Check
  • Tinted, Multicolored, or Variable Sized Hatches for RGB convergence
  • Variable APL DC Restoration
  • Variable Count Checkerboards
  • Checkerboards with Deep and Shallow Ramps
  • Variable Size Circlehatches
Sample Test Tones
><h3>
Set Up Tones (All DD, DTS 5.1/6.1)
  • Channel ID
  • Main-Channel Level Balance
  • Sub Woofer Balance
  • Sub Woofer Blend
  • Distance Compensation
><h3>
Reference/Test Tones
  • Frequency Response Sweeps Up
  • Frequency Response Sweeps Down (1/2 Bandwidth)
  • Broadband Pink Noise
  • Noise Test
  • Excess-Noise Test
  • Decaying Dither Test
  • Subwoofer Overload Tests
  • Dynamic Headroom Signals
  • Main-Channel Overload
  • DSP-Clicks
  • Imaging Tests
  • Reference Tones
  • 1 kHz 0, -20, -60
  • 35 kHz 0, -20, -60
  • 30 Hz 0, -20, -60
  • 200 Hz 0, -20, -60
  • 500 Hz 0, -20, -60
  • 1/3 Octane Tone Sequence w/ w/o Voiceover
  • 1/3 Octane Noise Sequence w/ w/o Voiceover
  • Subwoofer Warble Signal
