RBH Sound SVTRS Active Speaker System Review
- Product Name: SVTRS Limited Edition Tower Speaker
- Manufacturer: RBH Sound
- Performance Rating:
- Value Rating:
- Review Date: August 09, 2021 12:00
- MSRP: $ 50k/pair (includes amplification & set up)
Model Name: SVTRS Limited Edition Active Speaker System
- Frequency Response: 17Hz-35kHz (±3dB)
- Sensitivity: 94dB (2.83V @ 1 Meter)
- Woofers: (4) 12" (305mm) Reference Aluminum Cone Subwoofers
- Midrange: (3) 8" (203mm) Aluminum Cone
- Tweeter: (1) 4.72" X 1" (120mm x 25mm) Air Motion Transformer
- DSP Active Crossover Frequencies: 100Hz, 2000 Hz
- Crossover Filters: FIR Linear Phase 12dB/Octave 108dB/Octave
- Amplifier Power Model Unrivled UA-6:
- 1500W x 2 (Woofer)
- 500W x 2 (Midrange)
- 250W x 2 (Tweeter)
- Model UNRIVALED UA-8:
- (includes 2 additional amplifiers for center channel)
- 500W x 2 (Woofer)
- Cabinet/Color: Medium Density Fiberboard (MDF)/Standard High-gloss Black
- Grille: Black Fabric
- Dimensions: 15-3/16" W x 92" H x 22-3/16" D
- (386mm W x 1981mm H x 564mm D)
- Weight: 310 lbs. (140 kg) up to 410 lbs when mass loaded
- Warranty: 5 Years
- Transformative Audio Experience
- Unlimited Dynamic Range
- Customized Sound Tailored to Your Room
- Limited Production = Exclusivity
- Very large, heavy speakers
- Complex Set Up
RBH Sound SVTRS Introduction
Eight years ago I made a declaration
that the Status Acoustics 8T would be my final speakers, the ones I'd take to
the grave with me. I've always been in awe of RBH Sound flagship speaker
systems and the 8T was what I felt to be the absolute pinnacle of performance
for commercial passive speaker design. Well, the folks at RBH Sound made me
break that promise when they unveiled the Limited Edition Signature SVTRS
Active speaker system. It all occurred one early Monday afternoon when I got a
call from Shane Rich, Technical Director of RBH Sound, where he declared a
breakthrough he made in the next flagship speaker he was designing. "Gene,
you've got to hear this.... you just may want to upgrade again." I
nervously laughed as I had it in my mind that the 8Ts would be my speakers for
life and there was no way Shane was going to convince me otherwise. But deep
down, I just had to know if there was something "better" and if the
active route of loudspeakers was truly the future of audio much like electric
cars are the to the automotive industry, then I’d better listen to what Shane
was saying. I reluctantly agreed to have Shane bring their new Signature SVTRS
Limited Edition speakers to my place after they hosted a demo at the 2020
Florida Expo Show in Tampa (just one month prior to the COVID-19 pandemic that
changed our world forever). Would this new 7.5ft 310lbs monstrosity beat out my
beloved Status Acoustics 8T speakers? Read on to find out.
Design Overview
RBH Sound utilizes their FAST (Focal-point Active Speaker Technology) for this system with trickle-down technology for their complete line including the new UNRIVALED line. The RBH Sound Limited Edition Active SVTRS system is only offered in very limited production, just 20 pairs. It represents the accumulation of the best driver components in the 45+ year history of the brand merged with SOTA DSP processing from Marani to handle all of the active filters, FIR correction and bass management and Class D amplification to provide the necessary clean power to allow this system to reach its full potential at beyond reference levels in even the largest upscale home theater installations.
Marani DSP & Active Crossovers
These
speakers have no passive crossovers. This means the drivers are directly
coupled to the amplifier for less losses and superior transient response and
driver integration thanks to active crossovers. RBH Sound takes the active
approach to the next level by employing Finite Impulse Response (FIR) filters
instead of IIR filters like most active speakers currently use. FIR advantages
are two-fold. Unlike IIR filters whose phase response is inherently linked with
the magnitude response, FIR offers the ability to manipulate magnitude and
phase independently. The end result is not only perfect driver integration, but
also a time and phase aligned speaker without the trade offs of power handling
or off-axis aberrations when attempted in the analog domain with complex first-order
crossovers or angled baffles to align drivers on the same plane. The reason why
you don't see many active speakers employing FIR filters is the amount of
processing power needed to accomplish this effectively. It's not cheap and
hence that’s why RBH Sound is using the Marani LPP-480F flagship DSP speaker
management processor, typically used for commercial applications, at the heart
of this system. The Marani does it's processing at 96kHz/24 bit and has a
whopping 8 x 1024 taps up to 2 x 4096 taps if combining 4 channels for each
FIR. It takes a lot of taps to do proper FIR filtering and this type of
processing power wasn't available a few decades ago. So before some buckaroo
jumps on the forum boasting of a vintage active speaker system they used in the
80s that supposedly did the same thing, realize the 8-bit 1 MHZ Commodore 64
processor back in the day just couldn't cut it.
The Drivers
We've covered the wonderful RBH aluminum cone drivers ad nauseam in prior reviews. Suffice it to say, imagine the incredible 10" bass driver from the Status 8T and make it 12". Now multiply that by 4 for each speaker. That's right, each SVTRS houses dual SV-1212 subwoofers for a total of eight 12" bass drivers to round out the bass of the system. One SV-1212 subwoofer easily exceeds our Extreme Bassaholic room size rating. Having four of these subs increases they system output +12dB while also helping to control vertical room modes by loading into the room in two locations (floor and ceiling) per speaker. These subs have the largest ports I've ever seen. The port diameter is a whopping 6 inches and the combined port volume for the system is 50 liters! What does this mean? Lots of low frequency output without chuffing or compression.
RBH Sound SV-1212 sub + port (left pic) ; SV-831 Mid/Tweet Module (right pic)
The SVTRS system boasts three 8" mid-bass drivers. That's almost as much surface area as a single 15" driver! They are arranged in a modified MTM vertical arrangement, which RBH Sound calls a dispersion averaging array that keeps each mid-bass driver at a similar distance from the tweeter in order to reduce lobing effects in the vertical plane. This arrangement limits horizontal dispersion by focusing the energy more toward the listener. As a result, RBH Sound claims less side wall absorption is required than would ordinarily be used with conventional driver alignments.
The tweeter separates the men from the boys by employing a large 4.7”x1” Aurum Cantus AMT, which has a dynamic range equivalent to some of the best horns but with the smoothness known and revered by lovers of AMT / ribbon designs.
The Amplification
The
RBH Sound SVTRS system is powered by RBH's own amplification, which utilizes a
Pascal Class D design. Pascal is one of the best in Class D amplification and
the company put forth extensive resources to design an incredibly robust and
quiet switch-mode power supply to compliment the design. The advantage of Class
D amplification when done correctly like this is both efficiency (> 90%) and
load invariant response meaning the frequency response remains consistent
regardless of the load impedance it is driving. The RBH UNRIVALED UA-8 offers eight
channels of amplification for users that are also employing their matching
center channel while the UNRIVALED UA-6 offers six channels of amplification for
running just the stereo pair of these speakers.
The bass modules receive a whopping 1500 watts per stack, while the midrange array receive 500 watts/ea and the tweeter gets 250 watts/ea. These are continuous power ratings and you can see this amplifier means business via the Neutrik connector and 20A fuse rating. Each speaker effectively gets 2,250 watts! Doc Brown would be proud of this kind of power. 1.21 Gigawatts!?!
The Grille Covers
RBH Sound SVTRS Speaker System with Grille Covers On
RBH Sound never spares expense with their grille covers and the SVTRS is just the latest example. The grilles are constructed of chamfered HDF tightly covered with low-loss grille material and well-braced for rigidity. They don't normally come with magnetic grilles but I pleaded with RBH Sound to retrofit mine. RBH Sound employed very powerful neodymium magnets that hold the grille in place once set making it quite difficult to take them off. I've seen magnetic grille covers on many brands of speakers over the years and the RBH ones are the best in the business in my experience. No flimsy plastic frames or weak magnets here.
RBH Sound SVTRS Set Up
Setting
up the RBH Sound SVTRS system is a daunting task that is greatly alleviated by
the fact that they send the designer to your house to help you set them
up! No joke, as part of the exclusivity
of this system, RBH Sound flies out their chief designer, Shane Rich, to help
you set up the system and calibrate it.
The RBH Sound SVTRS system is modular meaning there are three boxes you stack per left and right speaker. This is a much better approach than trying to ship and move a 7.5 ft speaker weighing in excess of 300 lbs/ea. You first place the bottom bass modules on the included feet in the desired locations. Next you place the mid/tweeter module followed by the upper bass modules. There is rubber matte on each module that helps to better connect the modules together by increasing lateral friction. The last module is a bit tricky to place since you have to lift the heavy cabinet into position to stack it. This is definitely a two-man job so don't try to be Hercules and do it all yourself. After you have all three modules stacked for both speakers, you then install the connecting bracket that keeps them locked in place. The metal plaque with original owner insignia Roger B Hassing is a nice touch of class to add to the product in celebration of the company's 45th Anniversary of being in business. I put them on with pride humbled by the fact I have in my possession such a limited production, truly a one-of-a-kind loudspeaker system.
RBH
Sound 45th Anniversary Plaque with Insignia
RBH Sound UNRIVALED UA-8 Amplifier & Marani DSP wired in Kimber Kables
I used Kimber 8TC speaker cables and Hero XLR to wire the system up. The Marani DSP takes two channel XLR inputs from your preamp/processor and breaks out the signal for tri-amplification into the RBH Sound UNRIVALED UA-8 amplifier. After you connect the three XLR cables for each channel between the Marani and the UNRIVALED UA-8 amplifier, you're ready to do the speaker cable connections. You start with an 8-ft long jumper cable that connects the top and bottom bass modules together followed by three additional speaker cables that connect the bass section to the 1500-watt amp, the mid section to the 500-watt amp and the tweeter section to the 250-watt amp.
RBH Sound SVTRS Backview & Speaker Connectors
Wiring up the RBH Sound SVTRS system is quite a chore. You need a total of four speaker cables per speaker or eight for the pair. An 8-ft jumper cable is required to connect the top bass and bottom bass modules putting them in parallel connection to the 1500-watt amplifier channel. The two other sets of cables connect to the center module to wire the midrange array to the 500-watt amplifier channel and the tweeter to the 250-watt amplifier channel. The nickel plated speaker connectors are very high quality 5-way binding posts and add a nice touch of class to the product.
RBH Sound SVTRS Measurements, Listening & Conclusion
Shane Rich & Gene hard at work tuning the system (left pic) ; Marani DSP OSD (right pic)
Once you have the system all connected, the magic happens. Shane Rich, Technical Director of RBH Sound, programs the basic filter crossover targets and begins taking nearfield measurements of the speaker response. We spent hours dialing in the system response and achieved the best results by calibrating everything above 200Hz nearfield and everything below at the listening position.
RBH Sound SVTRS Frequency Response - 2 meter (1/12th Octave, in-room)
(left pic - left speaker; right pic - right speaker)
RBH Sound SVTRS Frequency Response - 2 meters (1/12th Octave, in-room)
(left pic - inside tweeter axis; right pic - outside tweeter axis)
The horizontal frequency response from 0 to 45 degrees from the inside of the speaker with respect to the tweeter is flat and very uniform. I was expecting higher high-frequency rolloff of the tweeter when measuring horizontal dispersion outside the tweeter but was pleasantly surprised how similar the response was. This is a fairly wide dispersion speaker and you won't hear much tonal shift moving your head side to side between the speakers. The vertical dispersion was more tapered off when > 30 degrees off-axis but this isn't an issue from the seated ear level position and the narrow vertical dispersion is an intended design trait by the manufacturer. This should make treating ceiling reflections less critical then more conventional 3-way speaker designs. The physical tweeter height was a bit higher than seated ear level position of my theater seats. I felt it shifted the image a bit higher as a result. Simply adjusting the feet to make the speaker have a slightly downward tilt fixed this issue in my room.
After admiring the incredibly linear summed response of the system, it was time to do final tweaks to flatten out the bass response. This system has so much cone area that it needed very little boost to easily hit the target room curve.
RBH Sound SVTRS Bass Response @ Listening Position (no smoothing)
It is quite incredible to see single digit bass extension with meaningful output. Running some very low tones, we could feel the rafters in the floor shaking. It's quite a visceral experience that very few subwoofers, let alone full-range speaker systems, can deliver.
RBH Sound SVTRS Spectrogram Wavelet Response
Because of the active FIR correction and lack of analog crossover components in this RBH Sound speaker system, I've been able to achieve a perfect impulse response yielding incredible phase linearity and time coherence you just can't get from a passive speaker system. As you can see in the Wavelet graph above, with both speakers playing and measured at the MLP, the response is perfectly linear (black vertical dotted line) from 20kHz all the way down to 150Hz where the delay slightly rises as low bass frequencies. Even at 20Hz, we only see 20ms of delay which is inaudible at these frequencies. The end result is coherent full range response that sounds superbly integrated and fluidic.
RBH Sound SVTRS Speaker System installed in the Old Audioholics Showcase Theater Room
Listening Tests
We tested the RBH Sound SVTRS speakers with all of the best gear available to us. This included the Anthem STR preamp, Yamaha CX-A5200 Atmos processor and RBH's own UNRIVALED UA-8 8CH amplifier to power them. Source devices included Control4 EA3 for streaming Tidal and Qobuz, and the Oppo UDP-205 Universal UltraHD Blu-ray player. Speaker cables and interconnects were all Kimber 8TC and Hero, respectively. The listening space is a 6,000 ft3 room that is moderately acoustically treated, courtesy of Auralex Acoustics. The listening portion of this review was written in my old theater room. I will revisit this section of the review when I get these speakers set up again at the Audioholics Smarthome new theater room.
Tidal Streaming:
Don
Dunn from HD2020 described listening to the RBH Sound SVTRS system similar to a
ride at Disney but without the long wait. I certainly could see his point when
listening to various tracks from Yello. "Planet
Dada [Flamboyant]" sums this experience up nicely. The bass is visceral
and deep and hits you at the core when playing back on the RBH speaker system
featuring eight 12" high excursion drivers. It amazed me how these woofers
were able to generate so much clean SPL while barely breaking a sweat. What was
equally impressive was how well integrated everything sounded in the system.
The articulation of detail the AMT tweeters were able to deliver was something
that has to be heard to be believed. These speakers brought out the subtle
details and sustain in the sound effects that I only heard in this much detail
prior on my Focal Stellia closed-back headphones. Post Malone "Wow"
had the vocals anchored dead center as if the center channel was engaged when
it wasn't. Bass had new depths that few speakers can dream to deliver. I found
myself searching Tidal for bass intense songs just to rediscover what I may
have been missing. This says a lot since I'm coming from my reference Status 8T
speakers that to date are some of the finest passive speakers I've ever heard
or owned.
Rebelution "Against the Grain" allowed the softer side of the SVTRS system to strut its stuff. You could clearly hear spacious reverb in the recording while at the same time extreme focus of clarity from the acoustical guitar. The vocals sounded incredibly lifelike and free of any coloration. When I closed my eyes, I was transported into the studio with the performer playing right in front of me. "You Oughta Know (acoustic)" is my favorite version of the song from Alanis Morissette. You could feel the bitter pain in her soul from the breakup of a former lover when listening on the SVTRS system. The immediacy of her voice was so pinpoint and accurate that it almost felt like it was in my head. Turning the FIR filters off in the Marani processor revealed just how much better the system sounded with it engaged. The time alignment of the minimum phase filters works! Don't get me wrong, with standard filters, this was a fine sounding speaker but once FIR was engaged, it took their performance to new levels that NOT even my beloved Status 8T speakers could achieve.
I did extensive solo listening of the RBH Sound SVTRS speaker system during my COVID-19 isolation last year and found myself streaming music I would never have done prior just to see how it sounded on this new system. Dua Lipa is an artist I found myself thoroughly enjoying on these speakers. The energy just captivated me to listen more.
SACD: Chlara - In a Different Light
If you are into SACD's and don't have this one, get it right now! What a sonic delight thanks to the angelic voice of Chlara and the brilliantly mastered and produced recording. "Hotel California" is arguably a top 10 overplayed classic but Chlara makes it her own. The decay of the bongo drums at the beginning really grabbed my attention almost as much as her silky-smooth vocals. Turning on the DSU with "center spread on" transplanted me into the recording studio with the artist for that "better than being there" experience I reserve for only the best playback systems I experience. Chlara's vocals have no hint of coloration or nasal sound, which I often hear immediately on speaker systems that utilize a compression driver. The bass line was so tactile and rewardingly deep without muddying up the soundstage one bit. I found myself turning the volume up quite a bit on the track "Like I'm Gonna Lose You" out of sheer enjoyment, noting that Chlara's vocals never wavered or sounded edgy.
Blu-Ray: Steven Wilson - To the Bone
Anyone that reads my reviews regularly knows how big of a Steven Wilson fan I am. To the Bone, while it isn't his best work to date, still has some great tunes and sounds superb in 5.1 DTS HD especially when upmixed with the DSU for a full 7.2.4 speaker layout. This album gave me a chance to hear how well the SV-821 center channel played with the SVTRS system. The opening bassline of "To the Bone" gives you an idea of how serious the RBH Sound speaker system is at playing back this record with concert level dynamics and slam. Steven's voice was focused with laser precision and the snare drums were snappy. I was completely mesmerized during the bridge towards the end of the song where the back-up vocalists were singing "me on me" and Steven comes in with "rain all the truth". The surround envelope in this recording best showcases just how superior good multi-channel music is over two-channel. My entire room was filled with pristine fidelity that wasn't fatiguing even when played at obscene levels that would send my wife running from our theater room. I used the "Song of I" to demonstrate my system to some local folks interested in hearing the SVTRS system in action. The reaction on their faces was priceless. I heard comments such as "so clear and concise," "the sound is surreal." I always enjoy exposing people to a true high-fidelity demonstration and suffice it to say, they actually decided to go with the in-wall version of this system for their new theater room in a 32,000+ ft^2 home.
SACD/ Blu-ray: Jienat - Mira
This recording remains a
multi-channel benchmark for us at Audioholics, but it also has an incredible
two-channel layer that is equally impressive.
I caution anyone to use the volume control judiciously when playing this
disc on their systems since it has extreme dynamic range that most speaker
systems are incapable of reproducing at
reference volume levels. The vocals were pinned dead center in Track #1 “Sissel” as if I had my
center channel engaged
similar to what I experienced on my Status 8T speakers. The bass was thunderous, reaching depths that
only a handful of full-range speakers that I know of could reach, 2 of them
being RBH Sound flagship products that I have been fortunate to have in my
theater room. Track #6 “Fredrik Albert” showed off the system's fabulous transient
response. The immediacy of the
percussion and depth of the bass was epic and not something that can fully be
conveyed in writing without actually hearing or feeling for yourself. I just had to switch to the multi-ch disc for Track #4 “DanceHall.” The envelopment of singers all around you was so freakishly
real sounding that it was as if I was a fly on the wall in the venue it was
recorded in. Most playback systems are incapable of reproducing the dynamics of
this album, but the SVTRS system did this with utter ease and with modest cone
movement from the eight 12" drivers, indicating I was barely stressing
these speakers that were providing room filling, gut wrenching bass. At the end
of this recording, you are rewarded with electric bass kicked that will shake
you to your core IF your speaker system is up for the challenge. This disc,
although obscure in content, allowed me to test the limits of my amplification
and my hearing because under no circumstance was I able to detect loudspeaker
compression or distress. This is the
quintessential definition of what a flagship reference loudspeaker should be
capable of.
CD:
Michael Franks - Burchfield Nines
At the
end of the day, when I want to chill, I do it to classic Michael Franks.
Burchfield Nines is such an underrated classic that only true fans can
appreciate. Track #1 “When the Cookie Jar is Empty” Michael's voice came
through with such delicacy and poise. The percussions seemed to pop more than I
recalled on my Status 8T system. I think the midbass output advantage of triple
8" mids and four 12"s playing up to 150Hz presents itself with
authority in these instances. Steve Gadd's bass drum sounded deep and tight but
not as damped as I enjoyed on my Status 8T system. I have not yet been able to
recreate the damped bass response I loved so much on my Status 8Ts with the
SVTRS system but I hope further tuning in my new theater room will get me there again. I am of course picking nits since both RBH speaker systems
produced the very best bass reproduction I've ever heard in my own listening
space. Track #2 “A Robin Song” showcased the neutrality, immediacy and richness
to the vocals and brass instruments that rivaled the live amplified
performances I heard at Michael Franks concerts. The saxophone beamed into the left side of my
head as if I was hearing it live right there. Brass instruments truly shine on
loudspeaker systems that dedicate enough cone area in the midrange section to
faithfully reproduce it. The cymbal reproduction of Track #3 “Wrestle a Live
Nude Girl” was so vibrant with sustain that it begged you to listen until its
final decay thanks to the remarkably transparent AMT tweeter. Track #4 “Burchfield Nines” is a slow, downbeat
song but patience rewards with a beautiful melody and some great
instrumentation. You’re showered with
triangles that just slowly dissolve into the room along with clanking
percussion sounds reproduced with pristine clarity that the RBH Sound SVTRS
system seemed to extend beyond what I heard on my beloved Status 8T system. The
trumpet just pours out with a sense of realism and warmth that keeps you
captivated to listen more.
UHD Blu-ray: Bumblebee
Growing
up as a kid in the 80's, nothing brought me more joy than transforming alien
robots slugging it out every week on TV. I couldn't wait to get home from
school to see how Megatron would verbally abuse his second in command,
Starscream or watch Optimus Prime throw down and kick some Decepticon can. Bumblebee
is the first live action Transformers movie that actually got the look and feel
of the robots from the G1 cartoon right. Michael Bay, take note, Transformers
are different colors and NOT just organic sharp metal. The opening scene of
Bumblebee awoke my inner child with all the familiar faces of our favorite
characters clearly identifiable on screen. The voices were as close to the
original, thanks Peter Cullen, and they came across with crystal clarity on the
RBH SVTRS system. This is where the SV-821 center channel really shined. The
dialogue was so true to the source material without a hint of coloration or
strain when turned up at reference levels. Yes the SV-821 is missing one of the
three 8" mid-bass drivers that the SV-831's have in the SVTRS towers. No, I
didn't miss it. These speakers have such incredible dynamic range and with so
much clean power on tap from the RBH Sound amplifier, the limitation was
constrained to my own ability to sustain uncomfortable listening levels for any
given time. I was encapsulated in the Dolby Atmos immersive bubble of the RBH
Sound 7.2.4 speaker system with the SVTRS at the helm handling the front LCR
duties. I was quite pleased with how the rest of my RBH Sound speakers
complimented this system. The SV-661WR on-wall are killer speakers for side and
back channels. Their dual 6" mid-bass drivers with the AMT sandwiched in
the middle in a vertical MTM offer incredible detail and precision for music
and high dynamic range for movies. The SI-615 6 1/2" coaxial speakers with
1" ring radiator tweeters provide excellent height effects for the Atmos
layer despite NOT having the AMT tweeters of the rest of the system. Of course
the bass from the 4 SV-1212 subwoofers is prodigious. Anytime Optimus crushed a
Deception, the tactile response was both heard and felt.
Active Speakers Are The Future
When I
reviewed the Status Acoustics 8T speaker system, I not only told the Lead Speaker Designer,
Shane Rich, that they'd be my last pair of reference speakers, but I also told
our readers as well. These were to be the speakers I'd die with. Well, I'm not
dead yet. Had it not been for Shane continually tinkering with new designs and
embracing active speaker technology, I would have been fully content with that
decision. The 8Ts were virtually perfect sounding without any needed EQ
processing in my room. In some ways, they are still my favorite speakers and
they are certainly some of the coolest looking speakers I've ever owned. But,
the customization of the SVTRS system is just too incredible to ignore. The
fact that you could literally tune the speaker to your room is revolutionary
beyond what simple room correction systems attempt to do. FIR filters allow for
precise crossover slopes and subsequent driver integration along with perfect
transient response and time alignment to stay as true to the source as
possible. The audible differences heard between conventional vs. FIR filters
are not subtle. Getting this speaker system dialed in just right for your room
really adds an additional dimension of realism to the sound. While I miss the
damped bass response of the 8T system, I really appreciate the subterranean
tactile response that the eight 12" bass drivers produce in the SVTRS
system. Hard hitting, spine shaking, depth plummeting, yep it does all of that
but NOT at the expense of accuracy of articulation or finesse. Once you hear a
reference level active speaker system properly set up, it's hard to get excited
about passive speaker designs. I did already liked the passive SVT system when
RBH Sound launched them over six years ago but they didn't approach the level
of fidelity I was hearing in my 8T system. SVTRS takes it to the next level
thanks to the incredible horsepower DSP processing of the Marani along with the
SOTA system amplification. Eliminating the passive crossover network in favor
of digital filtering and having the drivers directly coupled to the amplifiers
enables the system to reach levels of performance and fidelity NOT otherwise
possible. The case for active speakers has never been more clear in my mind now
having experiencing the very best in both passive and active.
The Downside
With
all of this incredible performance, there are some considerations. For one, the
RBH Sound SVTRS is a very large and heavy speaker system. I barely fit them in
my prior theater room with 8ft ceilings. If you want BIG sound like this and
have it be effortless at and beyond reference levels, there simply is no
replacement for displacement. This is NOT a speaker system you're going to want
to put in a family room. Instead, it's meant for a dedicated theater or music
room. The black gloss finish is very reflective which can be distracting when
watching a movie. It's a shame RBH Sound doesn't offer non-glossy finish
options. However, RBH Sound informed me they are transitioning on making
Signature series cabinets locally which will allow for non-glossy finish
options on future units. With its endless configuration options, this is NOT an
easy system to set up so it's a good thing RBH Sound sends their designer to
install and calibrate this system for you. I don't know of any other
manufacturer with this much dedication to their product and customer
satisfaction.
RBH Sound employed large metal cones for the feet on my review system that look cool but don't provide the best stability for such a large speaker system susceptible to being tipped over. I was not thrilled with this and suggested that they add an outrigger system and they obliged my request. In addition, RBH Sound informed me that they recently partnered with IsoAcoustics. I recently installed the SVTRS system with the outriggers in my new theater room of the AH Smarthome. Not only do they make the speakers look more impressive, but they provide the necessary lateral stability I was looking for. Their new UNRIVALED brushed aluminum knobs that secure the outrigger system give an extra touch of class and elegance. UNRIVALED indeed.
Recommendations
Integrating a speaker system as massive and complex as the RBH Sound SVTRS will take a commitment for an audiophile to have the proper room (minimum 3,000 ft^3) to make them shine. A dedicated listening room is a must and preferably one that has some sound isolation from the rest of the house. This speaker has ungodly low frequency output that will be felt and heard NOT just in the room they are located but in the rest of your home and nearby neighbors. If you want to throw a party(or piss off your neighbors), this is the speaker that can do it. Patience is required to getting this system dialed in and it will require at least two people so it's handy that RBH Sound sends their designer Shane Rich to help you set them up. Just make sure you feed him dark chocolate and have Coke Zero on hand since it will keep him productively working all night tuning your system while you can comfortably go to sleep knowing tomorrow will bring you audio bliss.
RBH Sound SVTRS System Installed in new AH Smart Home Theater Room
In the high-end, $50k/pair is a steal for a loudspeaker system of this caliber. Considering that this speaker system comes with ALL amplification and DSP, and the Master Speaker Designer himself to tune it to your room, this is quite a bargain with respect to the cost-no-object audiophile market. More budget minded audiophiles should strongly consider a pair of the RBH Sound SVTRs which will soon be available in an active version. More space minded audiophiles should look into a pair of PM-8s, which incorporate the same driver and DSP technologies in a much smaller and more affordable footprint pre-tuned for easy setup. You will be surprised just how much sound that system can produce for its size. In addition, RBH Sound told me they will soon be offering the an active version of the regular SVTR speaker system too.
Spending the last year with the SVTRS active speaker system has been an eye opening experience for me on the reality that properly done active speakers are not only the future, but they offer superior performance today. I found it interesting how this speaker has once again transformed the way I listen to music just like the Status 8T system did prior. I often find myself seeking out high energy, bass intense music just to see and feel how it will sound. I am always in amazement how little travel those 12" subwoofer drivers have to move to get my room shaking with deep, tight, clean bass. In the same breath, it sometimes freaks me out how anchored the phantom center image projects on vocal music as if I have the center channel engaged. Flip on the Dolby Upmixer or play a discrete Atmos source material, the SVTRS system integrates superbly for multi-channel applications. I like the exclusivity this speaker offers as well. With only 20 pairs being made, and mine being pair one, to own this configuration makes us sort of an secret society of Audioholics. Now all we need is a symbol or secret handshake.
RBH Sound SVTRS System with Sonitus & Gik Acoustic Treatments
The RBH SI-831R matching center channel is behind the Screen Innovation Acoustically Transparent Screen
Editorial Note About Audioholics SmartHome Theater Room
We recently built the new AH Smarthome and documented the entire process on our Youtube channel. This room represents the culmination of expert knowledge from every discipline in the AV industry from acoustics by Anthony Grimani and Matthew Poes, to home automation and room design by Don Dunn of HD2020 to state of the art DSP programming and speaker design by Shane Rich of RBH Sound. This room represents true State of the Art in every aspect from ultra high resolution audio and video and it is our goal to continue to refine and update this as our primary test bed for years to come.
If you can't fit a speaker of this magnitude into your room, RBH Sound offers in-wall equivalents including several SI-831 options and their SI-1212 dual 12" in-wall subwoofer. For those unfamiliar with RBH Sound (in-wall/on-wall) flush mount products, I can assure you that they are on point. My final configuration of this system will be the SVTRS towers and in-wall vertically oriented SV-831 center channel behind a 150" acoustically transparent screen from Screen Innovations. This will provide a perfect timbre match since the tweeters from the front 3 speakers will be at the same height and all speakers will be optimized with the Marani DSP. I will report more on this configuration after it has been set up.
There are very few speaker systems that can approach the level of output with the high fidelity that the RBH Sound SVTRS system offers. Sure you can go with coffin sized boxes with large compression drivers IF that's the type of sound you like. But, I've rarely heard a speaker system with large compression drivers that I didn't find fatiguing. In contrast, the AMT tweeter in the RBH System is a true gem. It offers silky smooth highs, incredible detail that makes you rediscover your favorite music, and endless dynamics. It was very difficult for me to let my beloved Status 8T speaker system go, but I knew it was time to embrace the future of active speakers. I feel privileged to have had the opportunity to experience both incredible speaker systems in my own listening space. Like Don Dunn said, it truly is like a ride at Disney but without the long wait or screaming kids to contend with.
If you’re in the market to assemble an exceptional audiophile two-channel or multi-channel system that incorporates the very best in what DSP processing can offer, then you should pick up the phone after you finish reading this review to find an authorized RBH Sound dealer to hook you up. I can’t imagine anyone not being completely satisfied with this speaker system.
I won't be so presumptuous this time to say these are “speakers for life” seeing how susceptible I am to always looking towards what's next and knowing how Shane Rich is always eager to oblige my curiosity. I will, however, guarantee you that experiencing this system in person will be unlike anything you've ever heard before. It's that epic. It's RBH | UNRIVALED Sound!
RBH Sound SVTRS Active Speaker System Product of Year Review!
RBH Sound Signature SVTRS Speaker System
MSRP: $50k/pair
RBH Sound
Mailing Address:
382 Marshall Way
Layton, Utah USA 84041-7318
Phone and Fax:
Phone: (801) 543-2200
Fax: (801) 543-3300
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Appearance | ![]() ![]() ![]() ![]() |
Treble Extension | ![]() ![]() ![]() ![]() ![]() |
Treble Smoothness | ![]() ![]() ![]() ![]() ![]() |
Midrange Accuracy | ![]() ![]() ![]() ![]() ![]() |
Bass Extension | ![]() ![]() ![]() ![]() ![]() |
Bass Accuracy | ![]() ![]() ![]() ![]() ![]() |
Imaging | ![]() ![]() ![]() ![]() ![]() |
Soundstage | ![]() ![]() ![]() ![]() ![]() |
Dynamic Range | ![]() ![]() ![]() ![]() ![]() |
Performance | ![]() ![]() ![]() ![]() ![]() |
