Definitive Technology Demand D15 Tower Speaker Review
- Product Name: Demand D15 Tower Speaker
- Manufacturer: Definitive Technology
- Performance Rating:
- Value Rating:
- Review Date: July 13, 2020 07:00
- MSRP: $ 3,398/pr
- Type: 3-way Tower Speaker
- Tweeter: 1" (2.54 cm) d (Round) Annealed Aluminum Dome and Laterally Offset
- Midrange: 5.25" (13.34 cm) d (Round) Polypropylene BDSS Bass - Midrange
- Woofer: (2) 5.25" (13.34 cm) d (Round) Carbon Fiber woofer - Mid/Woofer
- Passive Radiator: (2) 8" (20.32 cm) d (Round)
- Frequency Response: 39 Hz → 24,000 Hz
- Nominal Impedance: 8 ohms
- Sensitivity (1 watt @ 1 meter): 85.5 dB
- Lower and Upper -3dB Limits: 48 Hz → 22,000 Hz
- Peak Power Handling: 300 watts
- Tweeter/Midrange Crossover Frequency: 2500 Hz
- Midrange/Bass Driver Crossover Frequency: 450 Hz
- Weight: 52 lbs (23.59 kg)
- Dimensions (HxWxD): 40.78" (103.58 cm) x 9.05" (22.99 cm) x 12.86" (32.66 cm)
- Available finishes: Gloss Black, Gloss White
- Warranty: 5 years
- Very neutral on-axis response
- Excellent imaging ability
- Very good build quality
- Good dynamic range
- Extremely good industrial design
- Average low-frequency extension of 39 Hz
- Relatively insensitive for floor-standing speaker
Definitive Technology launched their ‘Demand’ series loudspeakers
back in late 2017 with three different bookshelf speakers. Two and a half years
later they have finally expanded their Demand series line with two
floor-standing speakers and a center speaker with the D15, D17, and D5C
respectively. The difference between the two floor-standing speakers is that
the D17 uses slightly larger drivers which should give it a bit more bass
extension and slightly more dynamic range. In for review today, we have the D15.
The Demand towers are unusual in that they occupy a similar price range as
other floor-standing speakers from Definitive Technology, namely the BP-9000
series. It is not often that loudspeaker manufacturers have lines similarly
priced in the same company.
There are two key differences between the BP-9000 and Demand product lines. One difference is that the BP-9000 series use a bipolar design where sound is projected from the rear of the loudspeaker. This should make for a sound infused with more late reflections which have been shown to increase listener envelopment, although that may come at the cost of a wide soundstage and precise stereo imaging. Another difference is that the BP-9000 series uses built-in powered subwoofers. That takes a load off of the user-provided amplifier. However, with the prevalence and flexibility of powerful and affordable subwoofers, built-in powered subwoofers are more of an appeal to those who do not want to devote floor space to stand-alone subs.
In comparison, the Demand series is a much more conventional loudspeaker design. The exclusion of rear speakers may make for a more acoustically predictable speaker with finer imaging and a wider front soundstage. The absence of a powered subwoofer section makes integration with outboard subs less complicated. So while Definitive Technology has two different lines occupying a similar price range, in my opinion, they are different enough to justify their availability. Definitive Technology seemed to want to offer a more conventional alternative to their BP-9000 series, hence the reason for the creation of the Demand tower speakers.
Let’s focus on the Demand D15 itself for a moment. At $3,400 a pair, they certainly are not cheap but nor are they extravagantly expensive either. It’s a simpler loudspeaker design than Definitive Technology’s other floor-standing speakers, and if this simplicity is an exchange of complexity for higher quality, that can be a welcome trade. This is not to say that the design is simple, and we will get into the various aspects of its construction in our ‘design analysis’ section, but it is a lot more of a traditional loudspeaker than the BP-9000s. There are a lot of traditional floor-standing loudspeakers in its price range, however, so what does the Demand D15 do to separate itself from the rest? Let’s find out…
Appearance
Upon arrival, the D15 speakers do need a slight amount of assembly by screwing in a metal plinth to the bottom and screwing feet into the plinth, but that is easy and takes less than 5 minutes. Following directions on the box, this should be done before unpacking the speakers. Unboxing the D15’s reveals them to be a strikingly modern design. The boxiness of the cabinet is not at all softened by corner rounding, and, in fact, the design embraces it with hard right angles at all corners. This is an effort to contrast the many circles of the drivers that are emphasized with black cones against the light aluminum front baffle. The all-aluminum front baffle provides a very attractive and high-end element to the appearance, and, to be honest, I am surprised to find something like that in a speaker at a price this low. While the industrial design here is striking, I don’t think it is ‘loud’ in that it will become the center of attention in most rooms. For those who want a tamer appearance, the grille hides the front baffle with a light-silver fabric and gives the speaker a much more minimalist look. The grille uses magnetic adhesion, so it has no grille guides to interrupt the smooth appearance of the front baffle. With the gloss white finish (a gloss black finish can also be had), the grille’d D15 is so minimal that it looks almost like a piece of abstract art. Normally, I think grilles make the speakers just look dull, but that is not the case here. Strangely, there are few images of the D15’s with the grille on posted to Definitive Technology’s product page.
There are 8” passive radiators on both sides of the speaker that have a gloss white cone and are easily the nicest-looking passive radiators I have ever seen. The tweeter is an aluminum dome that is partly obscured by a phase lens and has a mirror-image offset in a large black faceplate. It almost resembles an eye that is looking off to the side. The midrange driver has a large phase plug that Definitive Technology has used in past designs. I have never cared for the way it looks in the past, but somehow it isn’t as visually obtrusive here. The bass drivers have a sleek-looking carbon fiber cone. Altogether, I think it's an interesting looking speaker with or without the grille. I am guessing that even people who normally object to the appearance of speakers will get along with these when the grille is in place. In the Gloss White finish, they would fit right in any brightly colored decor. All-in-all, the Demand D15 speakers look quite nice.
Design Analysis
The Definitive Technology Demand D15 loudspeakers are a three-way floor-standing design that uses passive radiators to augment low frequencies. In such broad strokes, that isn’t a particularly unusual design, but there are a host of design innovations that do set the D15s apart from other tower speakers in its class.
Let’s begin our discussion starting from the top and going down, so let’s talk about the tweeters. The D15 tweeters use a 1” aluminum dome mounted in a shallow waveguide. The aluminum of the tweeter dome is annealed, which means it has been softened by bringing the aluminum close to its melting point and then allowing it to cool slowly. This process dissolves the crystalline structure of the metal, and, in its recrystallization, it becomes softer. In its softer state, it has increased the damping which can tame break-up modes in higher frequencies. It should make for a smoother sound, especially with those people who are sensitive to higher treble frequencies. There is a plastic piece with partly covers the front of the tweeter that is a phase lens that Definitive technology calls the ‘20/20 Wave Alignment Lens.’ Its purpose is to block sound from the tip of the tweeter dome from interfering with sound emanating from the sides. It could also serve as protection for the fragile diaphragm of the tweeter dome.
The midrange driver is a 5.25” polypropylene design that is quite unique to Definitive Technology that they call the ‘BDSS Woofer,’ which stands for ‘Balanced Double Surround System.’ It gets that name because the cone uses two surrounds: one surround on the outer edge of the cone and one in the inner edge that attaches it to the phase plug. Definitive Technology claims that this double surround system allows greater linear excursion. In theory, it should be possible that two surrounds could provide a more controlled excursion from the suspension components, although I can’t imagine that would provide a huge increase in excursion. This particular midrange phase plug is also something only seen in Definitive Technology loudspeakers, and they call it the ‘Linear Response Waveguide.’ It’s the largest phase plug I have seen, and that is probably why Definitive Technology calls it a waveguide, although it certainly does not function as a traditional waveguide. It looks to me like it just does what normal phase plugs do which is blocking wavefronts from the different areas of the cone from colliding and interfering with each other. It just does it a lot more than normal phase plugs.
For the bass drivers, the D15 uses two 5.25” carbon-fiber cones.
They look nice and have a beefy surround and so they should be quite capable in
bass frequencies. They are also used to power the two 8” passive radiators on
the side of the speaker. Definitive Technology claims a lower -3dB limit of 48
Hz for the D15, so these radiators should be very competent down to 50 Hz at
least. I wasn’t able to get a close look at the bare
drivers since a trim ring covers the frame screws, and removing the trim ring can
be a bit risky since it is glued on.
The crossover circuit is a pretty formidable piece that uses a multitude of higher-quality components such as metal-film capacitors and air-core inductors. There is a second-order acoustical crossover between the bass driver and midrange driver at 450 Hz and a third-order crossover between the midrange and tweeter at 2.5 kHz. The D15 has two sets of five-way nickel-plated binding posts for those who want to bi-wire or bi-amp the speakers. This is a feature that most upscale speakers are supposed to have but in reality, it is not very useful. The advantages of bi-wiring or bi-amping a speaker like this are negligible and not worth the potential for problems that can occur for those who attempt those types of connections.
All of this technology is set in a very slick MDF cabinet with the aforementioned aluminum front baffle that is 6mm thick. The side panels and bracing are all 18mm with the bracing designed and positioned with FEA analysis for optimal stiffness of the cabinet. The midrange is enclosed within its own heavily-damped compartment in the cabinet so that back waves from the bass drivers do not affect the cone position. A good amount of polyfill stuffing is placed in the cabinet for internal damping. The speaker is set on a square aluminum bass with the choice of spiked feet or rubber feet. The cabinet feels solid and inert.
The Demand D15 speakers look like a well-designed and competent loudspeaker, but, as with any high-end loudspeaker, its objective is ultimately to sound good. Let’s finally give it a listen to see how it achieves that goal...
Listening Sessions
In my 24’ by 13’ (approximately) listening room, I set up the speakers with stand-off distances between the back wall and sidewall, and equal distance between speakers and listening position. The speakers were set up to face the listening position directly. Listening distance from the speakers was about 9 feet. Amplification and processing were handled by a Pioneer Elite SC-55. No room correction equalization was used. Subwoofers were used for some content that contained deep bass frequencies.
Music Listening
One hi-res 96kbps/24-bit
album that I found to be a superb recording on Qobuz is a recent release of
some Bach works: ‘Magnificat’ and ‘Cantata No. 63, Christen, atzet diesen Tag.’
This release, entitled ‘Bach: Magnificat (Live, Chapelle Royale de Versailles),’
comes from the new classical music label Chateau de Versailles Spectacles,
which, as its name suggests, is tied to performances at the historic Chateau de
Versailles. The music was performed by La Chapelle Harmonique, which is a choir
combined with a period-instrument orchestra that was founded by string
instrument player Valentin Tournet in 2017 (when he was a mere 20 years old).
The musical artistry and production is second to none in this recording, and
anyone looking for some of the finest recorded performances of these pieces by
Bach need look no further.
So how did the Definitive Technology D15 speakers sound with such a talented group of musicians performing these exquisite compositions recorded in such a legendary acoustic space? From the first notes, the sound was enthralling. Each musical section was distinct and crystal clear. The vocals, strings, woodwinds, brass, and percussion were all so vividly rendered that I can’t help but use the word holographic, much as I try to avoid it in my reviews. Now, much of these qualities are matters of the recording, so it’s not as if the speakers can make an unremarkable recording sound amazing, but what I learned right away is that the D15 speakers will allow an exceptional recording to fulfill its potential. The tonal balance across vocals and instruments seemed to be very good. The soundstage was outstanding, and each instrumental section was easily localizable. The lead singers had very well-defined positions throughout the width between the speaker’s placement, and the concert hall ambiance extended well beyond the speaker’s boundaries. Bass was well controlled with extension that easily covered the lower frequencies contained within this album. I’m not sure what more one could ask for from a loudspeaker in the reproduction of ‘Bach: Magnificat (Live, Chapelle Royale de Versailles).’ I suppose that a speaker of this design might struggle in a large room if tasked with playing very loud levels, but for a normal-sized room like my 24’ x 13’ room, they had all the dynamic range I could ask for and would be sufficient in this respect for all but extreme SPL junkies. By the end of this album, I knew that the D15 speakers would be a great choice for any lover of classical music.
For something more focused on
a single voice, I found a great choice in the album ‘Birds on a Wire’ by the
duo Dom La Nena and Rosemary Standley who perform together under the name
Ramages. This was another hi-res new release that I found on Qobuz. This is
folk music that is mostly sung in French but there are a handful of songs sung
in English, Spanish, Russian, and Italian. The instrumental accompaniment is
fairly simple and mostly only consists of a cello and guitar but occasionally
other instruments will make a contribution. This is simpler music and gentle
music. Some of the tracks are cheerful and celebratory, but others are
sorrowful, and the cello is a great instrument to evoke sadness. Rosemary
Standley’s smooth voice is the star of this show, and her singing is relaxed
and melodic. Her vocal range may be limited but her control within her range is
excellent.
Standley’s voice sounded lifelike and radiant on the D15 speakers. Her voice was squarely imaged in the center between the speakers. There is no ambiguity in the soundstage of the D15s. The accompanying instruments also had very well-defined positioning. Bass from the plucked cello was strong without being overbearing at louder volumes. The clarity of the individual instruments was terrific even as they took a backseat to the vocals within the recording. These are pretty speakers, so one thought that occurred to me was: were the pretty looks of the speaker biasing my perception of the sound? Maybe, but usually, I suspect pretty speakers put aesthetics and industrial design first and sound reproduction performance second (if even that high up the list in design priorities), however, the overall sound was excellent while listening to ‘Birds on a Wire.’ These aren’t incredibly expensive speakers either. I would have figured that speakers with smooth aluminum front baffle and base with a gloss finish combined with a seriously good sound would cost more than the $3,400 MSRP for the D15s. The speakers that I have heard at audio trade shows that looked and sounded this good were far more expensive than these. How is it that Definitive Technology is able to pull off high-end looks and a high-end sound without a high-end price tag? I would guess the answer is clever design combined with very efficient manufacturing practices (the lack of curvature in the cabinet may be a real advantage in making these speakers affordable). However Definitive Technology accomplished this feat, I am glad they did.
Some years ago I had heard
some songs from Roberto Fonseca that I quite enjoyed, and I had always intended
to further explore more music by him but it just kept slipping my mind. While
browsing through Qobuz’s library, I noticed Fonseca’s latest release, ‘Yesun,’
was available in hi-res, so I finally decided to dive into more of his music to
get a better sense of him as an artist and also to hear what the D15’s could do
with his tunes. Fonseca is a Cuban jazz pianist who borrows styles and sounds
from many different kinds of music but runs them through his Afro-Cuban sensibilities.
There is a wide variety of musical moods and styles on ‘Yesun,’ and some stray
further from Cuban Jazz than others, but the music is always lively, and the
diversity of sound and different instruments here makes this a great album to
demo on a high-fidelity sound system.
As with previous music, the D15s give a clear and lucid presentation of each instrument, so much so that I was able to discern microphone setup with respect to many of the individual instruments. Again, the soundstage was sensational; it imaged over a wide breadth of space yet not at the cost of precision. On certain moments during the album, I cranked the volume loud, and the speakers did not lose their composure. The percussion hit with a visceral snap and thud, and the bass scaled with the mids and treble without compressing. The two bass drivers were capable of more output than I would have expected of 5.25” woofers, and I was duly impressed. This is a percussion-rich music which is great for demonstrating the transient character of sound systems, and each percussive instrument was distinct on the D15s, whether that be snares, congas, cymbals, hi-hats, or bass drums. There was no vagueness or overhang that I could detect, and this immediate response made for a lifelike presentation. As with so much else that I had heard on the D15 speakers, I was not left wanting for any aspect of sound in listening to ‘Yesun.’
One new release on Qobuz that
caught my eye from its title is the compilation ‘Music for Containment.’ It is
33 tracks of abstract and experimental ambient music from artists on the roster
of the French electronic music label Mille Feuilles. This music can be quite
challenging at times and can range from soothing and calm to harsh and grating.
It is strange stuff and certainly not for everyone’s tastes, but I appreciate
the exploration of different sounds that the artists engage in. There is such a
variety of different sounds here that I thought it would be a good show of the
range and ability of the D15 speakers. The title of this album makes it all the
more apt since, as of the time of this writing, I am was under a
Stay-At-Home order in my state thanks to COVID-19. This often dissonant music
is a good reflection of the anxiety of the era of COVID-19, although I am sure
most people would prefer more escapist music in these times, and I can’t blame
them.
The stereo effects employed in many of the tracks in ‘Music for Containment’ are not supposed to be an imitation of a natural audio event, and, instead, they are used for a more conceptual aural space. The D15 speakers adroitly conveyed this use of imaging as a vehicle for an idea rather than a mere reproduction of a traditional soundscape. I have to imagine that the artists of this album probably expected most listeners would listen on headphones, but the atmospheres created by a set of good high-fidelity speakers like the D15s are so much more palpable. The true-to-life imaging, as well as the more tactile bass of loudspeakers, make the listening experience far more concrete than with headphones. It’s not easy to discern the intended sound of many of the tracks on ‘Music for Containment’ owing to their ‘Acousmatic Sound’ philosophy. Nonetheless, the D15s did realize this music with a good sense of coherence and articulation. However puzzling the musical compositions were, the sound itself was always unambiguous, and the D15s offered a clear translation of the source. Each layer of sound remained distinct on the D15s, and each sound was given a detailed rendering. I’m not sure how many people would enjoy ‘Music for Containment,’ but those who do ought to give it a listen on speakers on the level of the D15s; I think it is a much richer experience than headphones can provide.
Movie Watching
One movie I watched with the
Definitive Technology Demand D15 speakers was the 2018 comic book movie
‘Venom.’ I had not seen it before, but I knew it would be an effects-laden
movie, and I wanted to see what the speakers could do with a wide dynamic range
sound mix. I also wanted to see what it could do in terms of bass without a
subwoofer. ‘Venom’ is a major studio production about a guy that gets possessed
by a crazy alien demon thing which gives him superpowers, so it looked like it
would have a pretty far-out sound mix that would be a good demonstration of
dynamic range and low-frequency extension. I cranked the volume and let ‘Venom’
rip on the D15 speakers, and it wasn’t long into the movie when I could hear
the passive radiators overloading. I quickly learned that the D15 speakers are
not happy in deep frequencies at high volumes. While I could crank music to the
same loudness levels and not worry, most music bass does not dig as deep as
modern movie bass. Music, especially acoustic recordings, don’t really dig much
below 40 Hz at high levels, but a lot of modern action and science fiction
movies do. Deep frequencies are far more taxing on bass drivers than stuff
above 40 Hz. I turned on subwoofers and used an 80 Hz crossover point for the
rest of the movie. Once relieved of deep bass duty, the D15 speakers shined.
The Venom characters' acrobatic moves sounded vibrant, and all of the car
crashes, explosions, and gunfire were potently rendered. Dialogue
intelligibility was good as well, and to ensure that was a quality of the D15s,
I had set my processor for two-channel operation, and no center speaker was
used. ‘Venom’ was a wild ride as far as sound mixes go, and the D15 speakers
can certainly take the listener on that journey- as long as their low-frequency
limitatio
ns are understood.
One movie I had been itching to see since its announcement was ‘Once Upon a Time in Hollywood,’ Quinten Tarantino’s fictional saga concerning Hollywood’s brush with Charles Manson. I figured this would be a great way to gauge dialogue intelligibility since Tarantino’s movies are heavily dialogue-based and the production quality would be as good as it gets. Tarantino also fills his movies with loads of music, so they are typically a great way to hear some good tunes as well as Tarantino’s often brilliant dialogue. ‘Once Upon a Time in Hollywood’ did not disappoint me regarding my expectations of its sound mix. One aspect that surprised me was the pervasive use of diagetic music sources as an element of the sound mix. The music often comes through authentic period radio broadcasts or record players that the characters are listening to, complete with commercial breaks and station identification plugs. I did notice that soundtrack fidelity of the music sources would not have sounded as good as the equipment they were ostensibly being reproduced on (I doubt that a 1950’s MG sports car’s radio sounded that good, assuming it even had a radio). However, it was just a clever and perhaps more immersive way to get music to accompany the visuals. The D15 speakers performed superbly in my viewing of ‘Once Upon a Time in Hollywood.’ The music sounded great and dialogue intelligibility was never less than excellent. This movie was alive with constant music sources, so it was good to listen to it on some speakers that didn't inhibit the sound quality. Even though the music was mostly older recordings, I would implore viewers to use a good sound system for films like this. The sound is so much richer than anything a soundbar or home-theater-in-a-box could have managed.
Definitive Technology Demand D15 Measurements and Analysis
The Definitive Technology D15 speakers were measured in free-air at a height of 4 feet at a 2-meter distance from the microphone, with the microphone raised to a 7.5’ elevation that was level with and aimed at the tweeter center. The measurements were gated at 9-milliseconds. In this time window, some resolution is lost below 400 Hz and accuracy is completely lost below 200 Hz. Measurements have been smoothed at a 1/12 octave resolution.
The above graphs depict the Definitive Technology Demand D15’s on-axis and horizontal dispersion out to a 95-degree angle in five-degree increments. Information on how to interpret these graphs can be read in Understanding Loudspeaker Review Measurements Part II. The first feature that leaps out from these graphs is just how flat the on-axis response is. This is a very nicely linear behavior on-axis. There is a rise beginning at 15 kHz which peaks at 20 kHz, but I would wager that most buyers of the D15s could hardly hear that high, not that there is much content up there anyway. The only difference that kind of peak in the response would make is perhaps the addition of a slightly more ambient sound in some recordings. We do see that the off-axis does see a small rise above 3 kHz at angles outside of 30 degrees, and this is due to a slight directivity mismatch between the tweeter and midrange driver at further off-axis angles. However, out to 30 degrees, the linearity corresponding to the on-axis response holds. The ‘listening window’ of this speaker, i.e., the +/- 30-degree angle from on-axis, is beautifully linear.
One interesting thing to see is that the linearity holds slightly better on the inside angle of the D15s as opposed to the outside angle. As was discussed in the ‘design analysis’ section, the D15 pair have specific left and right speakers, and the differentiating feature is the mirror-imaged offset tweeter; the tweeter is mounted further out from center with respect to the left or right unit. What this means is that the dispersion between the speakers is going to be slightly better than outside the speakers. It’s not hugely better, but if you want to optimally set up your Demand speakers, pay attention to the left/right designations.
The above polar map shows the same information in the preceding graphs but depicts it in a way that can offer new insight regarding these speakers’ behavior. Instead of using individual raised lines to illustrate amplitude, polar maps use color to portray amplitude, and this allows the use of a purely angle/frequency axis perspective. The advantage of these graphs is they can let us see broader trends of the speaker’s dispersion behavior more easily. More information about interpreting this graph can be read in our article Understanding Loudspeaker Review Measurements Part II.
In this polar map, we can see that the D15s have a relatively wide dispersion speaker with good coverage out to 60-degrees off-axis and within that angle directivity is fairly well controlled, although not perfectly. We more clearly see the asymmetry caused by the offset tweeter in the polar map above its crossover frequency of 2.5 kHz (in this map, the right side of the speaker is positive degree angles so left side is negative degree angles).
The above graph shows the D15’s low-frequency response captured using groundplane measurements (where the speaker and microphone are on the ground at a 2-meter distance in a wide-open area). We can see that the D15’s have a fairly flat bass response down to just below 40 Hz. Definitive Technology specs the response of these speakers as 39 Hz to 24 kHz, but they don’t give a window for that response. The low-end of their specs are not exaggerated, and these really do have a strong bass response down to 39 Hz. With a response this flat down to such a low frequency, boundary loading might give a substantial boost to the low frequencies, so users might get a tighter bass sound by pulling them away from walls or corners. These speakers aren’t designed to utilize boundary reinforcement like many other tower speakers that have a more gradually rolled-off low end response.
The above graphs show the electrical behavior of the D15 Towers. Definitive Technology specifies the impedance load of the D15s to be 8 ohms nominal, but I would call that a stretch. They have a 5.4 impedance minima at around 130 Hz. That is too low in a heavily used region for these to fairly claim an 8-ohm load. The phase angle in that region isn’t totally benign as well. If Definitive Technology claimed 6 ohms nominal, I wouldn’t argue, but 8 is a stretch. Nonetheless, this isn’t an extremely harsh electrical load. I wouldn’t want to run these speakers on a budget AVR amplifier, but I think midrange AVR’s should be able to handle these speakers without much trouble. I measured sensitivity at 84.7 dB for 2.83v at 1 meter which is pretty close to Definitive Technology’s spec of 85.5 dB for 1 watt at 1 meter. These aren’t very sensitive tower speakers, and they could benefit from some beefy amplification. On the other hand, I don’t think anyone buying a $3,400 tower speaker pair is going to drive them with a $200 AVR, so it’s not likely to be an issue. However, those who want super-loud headbanging speakers may want to look at higher sensitivity designs, as these will only have so much headroom, even with a monster amp.
Before wrapping this review
up, I will briefly go over the aspects of the D15 that I liked, and the aspects
that I didn’t like, and as regular readers will know, I always start with the
dislikes since I am the kind of guy who prefers the bad news first. But the
good news about the bad news here is that there is very little bad news with
respect to these speakers, and I think anyone who has read this far would have
guessed that much. My only real nit-pick with the D15s doesn’t really concern
the speakers themselves but Definitive Technology’s overly optimistic impedance
spec for them. Too much of the electrical impedance of the speaker falls below
8 ohms for this to be considered an 8-ohm nominal load. However, as I said,
that isn’t to say the electrical load of the D15s is bad, but rather it is just
not as light of a load as Definitive Technology implies. However, this nit-pick
is not a big deal, and I only even mention it just to have something to gripe about.
One other thing I would say here that is not a complaint about the speaker but
rather as a notice to would-be buyers is that while these speakers can get very
loud, they can’t get insanely loud, and those looking to achieve THX Reference
level loudness in a large room will have to look elsewhere. However, for 99.5%
of home audio enthusiasts, these have more than enough headroom.
With those very minor
criticisms out of the way, let’s go over the highlights of the D15s. First and
foremost is the sound: these speakers sound terrific. They are tonally
balanced, accurate, detailed, and deliver a marvelous soundstage. They have
good bass extension down to 40 Hz and a good deal of dynamic range. The
dispersion uniformity is good, if not quite perfect, and these aren’t speakers
that need you to dress your room up in acoustic treatments for an optimal
sound. They sounded great with every piece of music that I threw at them. The
only time they complained was when I blasted them with very high levels of
extremely deep bass in a movie, but that is not something I can fairly hold
against a speaker of their design type, because it is not reasonable to expect
them to play near-infrasonic bass at loud levels;. No speaker like this could.
That is what subwoofers are for.
I can also appreciate how good looking these speakers are. As I said before, I think these could pass some high standards for aesthetic approval from other household members that many other floor standing speakers would not be able to clear. They look very nice, and while they are not cheap speakers, they look more expensive than they are. But the looks are not skin deep with the D15s, because the build quality is also very good. They feel as solid as they look. Again, not a cheap speaker, but it’s easy to identify where the money went.
My time with the Demand D15 is my first close encounter with Definitive Technology as a speaker brand. I have heard other Definitive Technology speakers briefly in store demos, but those experiences were not extensive enough for me to form a meaningful opinion about the brand. For this reason I wasn’t quite sure what to expect from the Demand speakers. However, my time spent with the D15s has raised my esteem for Definitive Technology. They have created a truly good loudspeaker in the Demand D15s. They are a rock-solid choice for anyone shopping for speakers in this price range, and I can easily recommend them.
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Appearance | ![]() ![]() ![]() ![]() ![]() |
Treble Extension | ![]() ![]() ![]() ![]() |
Treble Smoothness | ![]() ![]() ![]() ![]() |
Midrange Accuracy | ![]() ![]() ![]() ![]() ![]() |
Bass Extension | ![]() ![]() ![]() ![]() |
Bass Accuracy | ![]() ![]() ![]() ![]() ![]() |
Imaging | ![]() ![]() ![]() ![]() ![]() |
Dynamic Range | ![]() ![]() ![]() ![]() |
Performance | ![]() ![]() ![]() ![]() ![]() |
