Paradigm Signature Sub 2 Subwoofer Review
- Product Name: Signature Sub 2 Subwoofer
- Manufacturer: Paradigm
- Performance Rating:
- Value Rating:
- Review Date: October 31, 2006 09:25
- MSRP: $ 10,500
Six 10” long throw woofers in a radial arrangement
Hexagonal sealed enclosure
Non-removable grilles
Amplifier: 4,500 watts rms, 9000 watts dynamic power (When connected to a 240v AC main)
Paradigm PBK interface
Frequency Extension: 7Hz DIN (Indicates -3dB in a typical listening room)
Finishes: Black ash, Cherry, Piano Black
Dimensions (H/W/D): 24.5” x 23.75” x 22.375” (23.75” Hexagonal cabinet diameter)
Weight: 230 lbs. (310 lbs shipped)
Warranty: 3 years bumper to bumper
Designed, Engineered and Manufactured in North America
Driver features
Mineral filled co-polymer polypropylene cone with RCR (Resonance Control Ribbing)
25.2lb FEA optimized triple stacked ferrite magnet structure
3” diameter 10 layer aluminum voice coil
AVS (Airflow Ventilation System) die-cast aluminum frame
Dual large diameter Nomex cloth spiders
Oversized pole piece with integrated aluminum heat sink
Through pole voice coil leads
Amplifier Features
Efficient Ultra-Class-D technology
PFC (Power Factor Correction)
Extreme output capabilities 4,500w rms, 9,000w dynamic power
Universal Input Power (Connects to any line voltage 108-265v)
Internal DSP (Digital Signal Processing)
Solid 5/8” thick machined aluminum plate for strength and heat sinking
Adjustable input gain
35-150Hz variable low pass crossover with bypass
Phase: Adjustable from 0-180 degrees
Auto on/off
Detachable AC cord set
Inputs/Outputs
Unbalanced (RCA) inputs
Balanced XLR input
1/8” 12V trigger
PBK interface port (USB)
- Neutral sound
- Loads of headroom
- Subterranean deep bass extension
- Impeccable finish
- Dummy proof
- Top shelf design and parts quality
- Easy to integrate
- Expensive
- Very heavy
Paradigm Sub 2 Introduction
Paradigm
is a name that is probably familiar to most audio enthusiasts as a
manufacturer of bookshelf and floor standing speakers, center
channels and subwoofers. Over the last 25 years Paradigm has stuck to
a core model of offering audio related products that are well
engineered, subjectively pleasing to the ear and reasonably priced.
Today Paradigm has a broad range of products and full speaker lines
at a couple of different price points. At the top of the heap is the
Signature series, which offers a few subwoofer models to choose from
including the Signature Sub 2, which is the subject of note for this
review. Sitting at the very top of the Paradigm subwoofer mountain
the Sub 2 is in many ways a statement level product and the $8,999
msrp certainly suggests that it is, being the single most expensive
product in the Paradigm catalog or that Paradigm has ever produced to
my knowledge. However for that rather substantial sum of money the
Sub 2 delivers an almost comical amount of hardware that on the
surface sounds like it sprouted from some bass obsessed teenagers
dreams, including specs like: Six 10” drivers, a total motor
assembly weight of over 150 lbs, an amplifier that needs a 240v line
to develop its full peak output of 9,000 watts short term and an
unpacked weight of 230lbs. Firepower is obviously not in short supply
here. But can all of this hardware be turned into accurate sound
reproduction with equal parts finesse and bludgeoning force if
needed, the veritable iron fist in a velvet glove? Read on…
Unpacking and Initial Thoughts
The
Paradigm Signature Sub 2, being a very expensive and heavy piece of
equipment, was delivered via a freight carrier and arrived wrapped
and strapped to a large pallet with the small box containing the PBK
kit (Perfect Bass Kit) riding on top. The shipping documentation
listed a shipping weight of 310 lbs. Needless to say the box itself
is very large and a full sized pallet will not fit through most
domestic door frames. This necessitated removing the main box from
the pallet prior to bringing it into the house. Additionally I have a
couple of steps to go up to enter the doorway so the act of getting
the Sub 2 into the house took some amount of effort from a couple
people in concert, one of which was the delivery driver who seemed
curious as to just what sort of “speaker” was this big and heavy.
Either that or he was simply feeling sorry for us. Once we had the
Sub 2 to the door it wasn’t too hard to slide it on in. The box
just barely squeezes through a regular sized door frame. Since this
unit came directly from Paradigm I am not sure what arrangements
would be made when purchasing through an authorized dealer, but I
assume that there would be some after sale support to get it into the
home and in place in your room. A single person job it is not.
After getting the Sub 2 into the house and having a moment of reflection I set about reading the unpacking instructions furnished by Paradigm, which were attached to the top of the box and boldly labeled ATTENTION! READ FIRST. The instructions were not that different from most other large subwoofers. Open the top and then tilt the box over onto the top using the plastic handles integrated into it. Lift the box up and off of the subwoofer, remove packing materials, plastic wrapping, accessories, etc. This leaves the Sub 2 sitting on two large pieces of thick foam cut to fit over the cabinet bottom and protect it. At this point you tilt the Sub 2 slightly so that one of its three feet is off of the floor and remove the foam piece from under that foot then repeat for the other two until it is sitting on the floor. Obviously due to the weight of the Sub 2 you would want to unpack it as close to your final placement for it as possible. The packaging and materials used are robust and high quality. This coupled with the freight shipping ensure that there is little chance of a Sub 2 sustaining damage during shipping. Other than the Sub 2 itself, contained in the package were: Two owner manuals, one in French and one in English, the power cords, one for 120v and the other for 240v operation, threaded adjustable feet for the Sub 2, the PBK kit, etc.
Once the Sub 2 was sitting alone and I had my first chance to inspect it in person I was immediately given the impression of very high quality. All of the joints were tight, the grills were solidly attached and the piano gloss black finish of the review unit was simply stunning. The cabinet exterior was mirror polished and very deep to such an extent that you could easily see distortion free reflections in it. Additionally the unusual hexagon shape, the large milled aluminum amplifier plate and the nicely contoured top and bottom panels which blend into the grilles and amplifier offer a somewhat more exotic than usual profile for a subwoofer. I was also a little surprised at the size of the Sub 2. After viewing the size of the outer box and feeling the weight I expected the Sub 2 to be somewhat bigger than it actually is once unpacked. In person it is much smaller than you would think and one compact, massive slab of speaker. To be sure it is no shoebox subwoofer but it is no giant either. It is actually smaller in volume and with less of a footprint than some other subwoofers that I have reviewed lately.
Paradigm Signature Sub 2 Subwoofer Design Overview
The
Signature Sub 2 is a sealed subwoofer system utilizing no less than
six heavy duty 10” drivers in an unusual hexagonal shaped enclosure
and a host of technologies developed by Paradigm’s Advanced
Research Center (PARC) over the course of a few years. The drivers
are arranged in a radial fashion on three of the enclosures six sides
in vertical groups of two drivers to a side. This provides the
benefit of cancelling the vibrations that otherwise would be imparted
into the cabinet by the movement of the driver cones. This
cancellation occurs due to the opposing forces from the other drivers
in this type of arrangement. In a conventional driver layout at high
output levels the driver can start to vibrate or physically shake the
cabinet due to its movement. This has nothing to do with the actual
sound waves emitted by a subwoofer and is a result of the physical
mass of the driver moving assembly vibrating back and forth rapidly.
In effect it acts like a shaker weight attached to the enclosure. The
Sub 2 design cancels out these forces which is especially important
with six high power long excursion drivers all active in one small
enclosure. An internal amplifier of unusually high output
capabilities provides the motivation for all of those drivers and
occupies the entirety of a fourth side of the hexagon enclosure. The
amplifier is rated at a titanic 4500w rms when connected to a 240v
line, has internal DSP which is set by Paradigm to contour and shape
the response of the Sub 2 and also has a USB port for connection of a
computer for use with Paradigm’s PBK kit, which is included. The
Perfect Bass Kit is Paradigm’s own crack at developing an automatic
correction for the effect of a rooms acoustics on the subwoofers
output as delivered to the listening position. More on that later…
The Sub 2 owner manual, PBK manual and quick start guide are all very detailed and much more thorough than the average literature, even going so far as to get into some basic theory on room placement and system integration. In particular the owner manual provides a lot of background information on the design and engineering that went into the Signature Sub 2 and Sub 1, including notes on the drivers, amplifier, exploded views and internal shots of the cabinets, major components, etc. It is obvious that Paradigm are proud of these units and the engineering that went into them as most companies do not provide this type of detailed information even for their flagship products.
Usually I will partly disassemble the subwoofers as part of a review in order to assess the design further and check the quality of the internal cabinetry and components, but Paradigm literature notes that the grilles for the Sub 2 are non removable due to the extreme power of the Sub 2 and for safety reasons involving the amplifier design. Additionally there are a lot of nice pictures and renderings of the internal workings and components used in the Sub 2 such that there really wasn’t a need to do this since Paradigm has already provided most of this information and plenty of product pictures. That being the case and since I couldn’t help myself, I decided that I would still go ahead and have a look inside of the Sub 2 with Paradigm’s blessing.
The 10” drivers used in the Sub 2 are very robust and individually would be impressive in most other company’s subwoofers. The motor is a very large roughly 8” diameter affair utilizing 3 large ferrite magnets stacked on top of each other and attached to a proprietary heavily vented and open cast aluminum frame which Paradigm calls AVS or Airflow Ventilation System. The motor also has a large diameter pole vent with a mildly bumped back plate and a couple of small diameter holes for gap venting. Additionally the pole vent has a large aluminum heat sink, which probably also doubles as a demodulation circuit, mounted inside of it which is a first in my experience. The motor assembly for each driver is listed as 25.2 lbs which puts the individual driver weight at about 30lbs. With six drivers all crammed into the single enclosure you can easily see where the 230 lb mass of the Sub 2 comes from. That is 180 lbs worth of drivers! The voice coil is a 10 layer, aluminum wire on a 3” Nomex former with a long wind for extra excursion. The leads for the driver voice coils do not connect to terminals on the driver frame from the area near the spiders as is usual with most bass drivers. Instead the leads exit the driver from inside the former out of the pole vent. The cones are a mineral filled polypropylene with reinforcement ribs molded into them for extra stiffness. The stiff suspension consists of a large half roll FEA optimized thermoplastic foam surround and a pair of large diameter spiders. This is a heavy duty and likely somewhat expensive driver to produce and there are not one, not two, but six of these in each Sub 2.
Paradigm Sub 2 Driver
The
amplifier of the Sub 2 is a very high end piece that is not your
typical plate amp. First off there is the obvious which is the extra
high power rating of 4500 watt rms and 9000 watt peak, which is
closer to the types of power levels seen more commonly in
professional touring power amplifiers rather than the plate amps in
commercial subwoofers. Paradigm calls the patented topology used in
the Sub 2 amplifier Ultra-Class-D and indicate that it has a very
high efficiency of around 95%. It is a transformer-less design
utilizing PFC to regulate a 400v bus which the bridged class D
amplifier is powered from. PFC or power factor correction in very
simplistic terms allows the amplifier to draw current from the wall
more efficiently and throughout the entire ac cycle instead of only
during the peaks of the waveform. This helps boost the amplifier
efficiency and also can help the amplifier produce maximum power when
operating from sagging or dirty AC lines. Again this is a feature
normally found in touring grade professional amplifiers. The Sub 2
amplifier also has Universal Input Voltage which allows it to be
connected to voltages between 108 and 265 volts. In order to get the
full continuous output from the amplifier it should be connected to a
240v line. The rating is 3000 watts continuous if connected to a
standard 120v line. The amplifier’s continuous output is limited
when operating from 120v in an effort to avoid tripping the breaker.
A cord set for each voltage is provided. Interestingly both have a
ground pin but the actual socket on the amplifier has no ground pin.
This is because the amplifier is double insulated. Being that the
amplifier operates in a non isolated manner the driver voice coils
have the same potential as the AC line voltage and this is the reason
for the non-removable grilles. In practice the difference between
operating on one voltage versus the other would not be noticeable
until the extra power is needed when the Sub 2 amplifier is asked to
produce maximum continuous power into low impedances for extended
duration. Auto on/off, thermal and short circuit protections, a soft
clipping circuit and 12v trigger on/off are employed as well. The
amplifier also has internal DSP processing but this is configured by
Paradigm at the factory and not user accessible. The amplifier
provides a left and right unbalanced RCA style input, a balanced XLR
input, USB input for connecting to a computer for running PBK and a
12v trigger input. Input sensitivity, phase adjustment and low pass
crossover are the only controls provided.
Paradigm Sub 2 Back Panel
The hexagon enclosure used for the Sub 2 appears to be made of 1” thick MDF throughout with the top and bottom panels perhaps being slightly thicker material. After removing the grilles and a couple of the drivers to examine the internal workings, a thick shelf brace across the middle of the cabinet in between the drivers could be seen which ties all of the enclosure corners together. It has a couple of strategically placed windows to allow the total enclosure to still appear as one air space to the drivers. Additionally there is a large 2”x2” brace extending through the center of the enclosure which ties together and braces the top and bottom panels. There is also plenty of dampening fiber inside of the enclosure in between the drivers and on the panel surfaces. This is one rock solid and inert enclosure. As mentioned previously the piano gloss black finish was visually stunning and befitting of a product of this caliber. Internally all of the enclosure surfaces are sprayed with a matte black paint. The grilles are heavy duty and not just cloth but are actually constructed of wood frames with perforated steel grilles which are then covered in black fabric.
Once I could see the internals of the Sub 2 it became apparent just how compact and full of hardware the cabinet is. It is literally cram packed as you can see in the pictures below. The effective volume of air seen by the drivers must only be a couple of cubic feet in total. The driver motors are only about an inch from touching each other or the center brace and the amplifier itself takes up a good amount of room as well and sprouts a ridiculous amount of wires to feed the six drivers. The driver motors are in such close proximity to each other that when you mount one the magnetic field from the other motors tries to twist or push away the motor of the driver in your hands and this despite the 30lb driver weight. That said the attention to detail and logical layout that is apparent on the outside of the Sub 2 also extends to the inside of the enclosure as each driver has a set of terminals anchored in the cabinet behind it with quick disconnect spade connectors. The leads from the amp can be secured in place with only a short lead from the drivers to the terminal. If a driver somehow got dropped or otherwise yanked during removal it will not yank on the leads from the amplifier or at the voice coil since the leads are anchored into the back of the motor heat sink as well. Not that any Sub 2 owners should be delving hands on into the guts of their multi thousand dollar bass maker, especially since it will void your warranty and all. I don’t want to give anyone that impression, but it shows that the Sub 2’s designers were paying attention even to the internals on their products.
Interior View at Paradigm Sub 2 Internals
One thing that puzzled me slightly was the lack of casters in the Sub 2’s included accessories. The Sub 2 has three feet built into the bottom of the enclosure which also happen to have a nice big threaded hole. With the odd shape, the relatively small size, massive weight, beautiful finish and only three feet, maneuvering the Sub 2 when you have to can be a tricky affair as you try to protect the finish and grille cloth while dealing with its bulk. It also makes leveraging it onto a furniture dolly, or using a 2 wheel dolly a little dicey. As soon as I could see that there were threaded holes that I could use for a set of wheels I made a run to the hardware store for a set. Simply screwing in a couple of casters and rolling it around when needed sure made life easier. Paradigm probably rightly assumes that most users will only ever move it into position once or maybe twice. I’m not so lucky. I can only assume that Paradigm put those threaded holes in the bottom for just such a purpose.
As can be seen the Paradigm Sub 2 build and components quality is through the roof. It is even evident in little things like the screws and small bits of hardware used which are of higher than average quality as well. Even the inside of the grilles, which are not meant to ever be seen by the end user, are over built and nicely finished. The amplifier is a cut above any other commercial plate amp I’ve yet seen attached to a subwoofer both in power and sophistication. There are other subwoofer manufacturers who have drivers of similar quality but they use one or perhaps two of them at the most, while the Sub 2 is shoehorning no less than six of them in. The finishing quality and packaging quality are the very best I have seen to date as well. It is a very expensive subwoofer but the build, finishing and component quality are certainly in line with that big sticker.
Paradigm’s Perfect Bass Kit
As
part of the purchase price of the Signature Sub 2 Paradigm includes
their PBK kit which is an auto equalization system developed by
Paradigm that helps counteract the effects of a room’s acoustics
and smooth out the subwoofer response in the room and at the
listening position. These types of auto
EQ systems are growing more popular of late with many manufacturers
starting to incorporate their own version into their products.
Paradigm’s PBK comes in a small light weight box, separate from the
Sub 2 itself, that contains product literature, user manual, quick
start guide, software disc and multiple smaller boxes containing a
usb powered microphone, microphone tri-pod stand and a couple of usb
cables. Running the PBK routine is very straight forward and
involves: Placing the subwoofer, installing the PBK software onto a
computer with two available usb ports, connecting both the Sub 2 and
microphone via the supplied usb cables, placing the microphone at the
primary listening position and starting the auto routine. At which
point all you need do is occasionally move the microphone to a new
position in between measurements. After the minimum amount of
measurements are gathered, or you decide that enough have been done,
the system will calculate the EQ corrections needed, import them into
the subwoofer and display the results. These can then be saved to
your computer for recall later. The whole process is very simple and
takes less than 20 minutes. The results in my room are shown below
and indicate that I have a dip at 30Hz, a peak near 40Hz and another
dip near 65Hz. After measuring many subwoofers in this placement,
none of this was a surprise to me. The raw response of the Sub 2 as
delivered to the microphone is the red line on the first graph below
and the purple is the expected outcome after PBK’s equalization is
applied. I also decided to do a couple of before and after
measurements with my own rig to see how closely they correlated with
the PBK reported results. This is presented in the second graph
below.
Paradigm Signature Sub 2 PBK measurement
Paradigm Signature Sub 2 before and after PBK measurement
The two results match up rather well despite the different software, resolutions and graph scales. All of the major response features both dips and nulls are present on both measurements. The important point of this is that before running PBK the Sub 2 response was +/-5.7dB, or an 11.4dB total window from 20-150Hz. After running the PBK routine the response was flattened into a much tighter +/-3.4dB and now fits into a 6.8dB total window over the same frequency range. The measured result after running through the PBK routine is a large improvement that should result in audibly smoother, more uniform bass and indicates that running PBK can have a big effect on your Paradigm subwoofers performance, especially if you are not the type of person who manually measures and equalizes your system yourself.
Paradigm Signature Sub 2 Subwoofer Review Listening Session
For all of the listening sessions the Paradigm Sub 2 was placed in the front right corner of the room about 4 inches from the walls. This places the subwoofer a little over 4 meters from the primary listening position. I have determined this to be the best available single subwoofer placement in the room for most units. The Sub 2 was connected to one of the 240v outlets normally occupied by a KPA2400 amplifier and this ac voltage was used for the duration of its stay. Paradigms PBK routine was run on the Sub 2 first to allow it to adapt the subwoofer response to the room. This was followed by Audyssey auto EQ being run on the system to allow it to further integrate the Sub 2 and flatten the response, which was then followed by a check and recalibration of the subwoofer and speaker levels prior to the listening sessions. Paradigm recommends running PBK prior to any other EQ or system optimization in the literature supplied with the Sub 2. For all listening the Sub 2’s internal low pass filter was bypassed in favor of a 125Hz setting inside of the Onkyo PR-SC886P.
Listening Impressions: Various Artists, Movies and Formats
This part of the review will be a little different from normal. Reason being that Paradigm sent the Sub 2 way back in 2011 before the holidays and instead of the week or two that I usually have to get acquainted with and listen to a subwoofer I was lucky enough to have the Sub 2 as the part of my home theater for about 3 months. The reasons for this length of time were part, timing, part scheduling, life events, weather, you name it. Thankfully Paradigm was very patient and only inquired once every few weeks and they never rushed the review process. A good chunk of my time spent with the Sub 2 was critical in depth listening with notes using material of every stripe. Other times it was just casual enjoyment without focusing in on what the Sub 2 itself was doing. Since I had an extended amount of listening to the Sub 2 and used such a wide range of materials I’m just going to give my final impression mixed in with some specific notes from various sessions.
The
first thing that I did once the Sub 2 was fired up in my system was
connect my i-pod, which only has uncompressed .wav files loaded on
it, and run through a bunch of favorite tracks at a moderate volume
which have bass that I enjoy for one reason or another, old Beastie
Boys, some Victor Wooten, Pink Floyd, etc…Over the duration of time
that I listened to the Sub 2 I would occasionally go back and listen
to just pure music in between movies and sporting events. The first
couple of times that I listened with the Sub 2 involved, nothing
immediately jumped out at me, or bowled me over and nor did I expect
it to. This not what a subwoofer should do if it is integrated and
level matched well. What eventually became apparent was that the bass
lines just seemed to be there in a nonchalant manner and presented
without coloration. If the kick drum was heavy so was the Sub 2’s
contribution. If the track was mixed lean it stayed lean just as it
should. On dense tracks such as those contained on Strapping Young
Lads The New Black album, which has quick double kick flurries and
occasional blast beats interspersed with frantic bass guitar runs and
the occasional 808 like drop bass effect, the Sub 2 was completely
unfazed even at volume levels that were starting to get uncomfortable
to be in the same room with. Even at those levels everything was
clear and uncongested sounding. One track on this record in
particular, “Almost
Again”,
has drummer Gene Hoglan throwing in the occasional drop bass effect
into his double bass patterns before adding in floor toms to the
previously already over the top verse drum beat. On most systems you
might not notice the floor toms being thrown into the beat on this
section of song as there is so much going on already and they do not
have a lot of top end attack. The Sub 2 clearly maintained separation
of this material such that the floor tom fundamentals were readily
apparent over the kick drum pattern and bass guitar. On VAST’s
“Music
for the People”
album which is moody pop rock the low register of piano and bass
guitar were satisfyingly smooth and the drums were presented with a
lot of weight to them and a dark analog warmth which is how they are
mixed on most of the tracks. On a track titled “Take
Me with You”
from a different album there is virtually no bass until a huge bass
drum drops into the song at about 1:54 in. I believe it is centered
at around 40Hz or maybe slightly lower but it sounds like it is
coming from a mountain in the distance and has a lot of sustain and
impact. It is not particularly taxing but I love the way that it
sounds on a dynamic system. I cranked the Sub 2 way up for this and
it did not disappoint generating a huge percussive slam. Other fodder
served up to the sub 2 included everything from Animals as Leaders
and Loreena McKennit to Neil Young and Cypress Hill. Slow booming rap
bass, quick bass guitar runs, fast kick drum patterns, piano, deep
male voice and I even threw some pipe organ in there. The big
Paradigm was impressive with all of it and would only call attention
to itself when the material demanded it. One of the concert blu-rays
enjoyed was Michael Jackson’s “This
Is It”.
If you haven’t seen this movie it is primarily behind the scenes
footage and rehearsal’s during the build up to what was billed as
his final tour and contains a really well mixed low frequency range
during many of the bigger rehearsal sequences that only gets that
much better with a subwoofer like the Sub 2. Even if you aren’t a
fan it is worth a watch just for the smooth low end mix and skill of
the backing musicians. I had only seen this once previously and had
forgotten just how good the bass mix was but the Sub 2 reminded me in
short order with big, punchy and clear bottom end that made me want
to reach for the remote and increase the volume every couple of
minutes, which I did quite a bit. Awesome.
As
is customary I also enjoyed a couple of movies with subwoofer
crippling bass in order to gauge how the Sub 2 would deal with loud
playback of this material in a fairly demanding room. For this I
decided to go straight for the big guns starting with Steven
Spielberg’s 2005 adaptation of “War
of the Worlds”.
Despite being released quite a few years ago this is still one of the
most demanding if not THE most demanding movie soundtrack available
and has simply punishing bass in a number of scenes. Suspect number
two was Dreamworks “How
to Train Your Dragon”,
an animated children’s film about a bungling young Viking that just
happens to have an insanely bombastic mix as well. The thought behind
using this material is that this is about the most demanding material
that any subwoofer will ever see, so if the Sub 2 does well here then
it should have the headroom and in some cases protections built in to
deal with anything else Hollywood is likely to send down the pipe.
Considering the massive amount of testosterone the Signature Sub 2
brings on deck with it, I had a hunch that cutting it loose on these
big action flicks aught to be entertaining to say the least. I was
not disappointed. With a little apprehension I started War of the
Worlds with a master volume of -12 from theater reference, which may
not seem that high, but I can assure you that the majority of single
subwoofers will utterly crumple at that playback level of this
soundtrack in my system. Not Paradigm’s Sub 2. The first scene with
notable bass is during the lightening storm which is very low
frequency such that most subwoofers skip it entirely. The Sub 2 sent
a good sized tactile pulse through the furniture and floor which was
impressive and tells me that the Sub 2 has response that extends very
low in frequency with substantial power. During the pods emerge scene
the Sub 2 produced room shuddering bass with impressive authority,
shaking the couch and floor both. When the giant alien ship goes on
the rampage and starts laser beaming people and houses the bass
shifts a little higher in frequency to the 25-35Hz range at very loud
levels. This is the section where most subwoofers would be over
driven and the Sub 2 just cranked the bass out while sounding like it
was completely in control the whole time. Again on the highway bridge
collapse I listened for any sign that the Sub 2 was distorting or
into the limiter but it was difficult to tell because it sounded like
a bridge had just collapsed! This performance on extremely demanding
material was about the point that the Sub 2’s output capabilities
started to sink in. About a week later was when I finally had a
chance to watch “How
to Train Your Dragon”.
I used the same volume level as used with War of the Worlds and again
the Sub 2 seemed to have no problem at all with the myriad
explosions, thumps and loud booms present in the soundtrack. This
film also has a lot of very low frequency content below 20Hz and
again it was readily apparent that the Sub 2 has deep extension
producing what I like to refer to as the push or shove effect, which
is where the bass is so low in frequency that it barely registers
with your ears but you get a tactile or physical sensation of it on
your body or through the furniture. It is a subtle effect that is a
little eerie at first experience, but it takes a subwoofer or sub
system with deep extension and a lot of headroom to pull this off.
Apparently the Sub 2 qualifies. At the very end of “How
there is a climactic battle with the uber dragon that results in a
loud, rumbling, thud of epic proportions. The Sub 2 pulled out all of
the stops and provided a powerful room shaking shudder befitting of
the action on screen.
Over the next month or so I continued to use the Sub 2 and enjoy its contribution with a wide variety of material. Not once did it do anything other than a fantastic job. With high quality music and movies it was always neutral and never sounded anything other than composed. I do not know if its limits were ever found with either of the two big bass flicks that were used but if they were, I could not tell. I never heard any noises of overload or anything like that. The fact that all of that clean output comes from such a good looking and reasonably sized enclosure is the cherry on top. Also I did briefly put a glass of beer on the subwoofer while I was watching “This Is It” and there was barely a ripple even though the sub was cranking out an impressive amount of bass at times. I was a little sad when the time came and the Sub 2 was finally boxed up and sent back to Paradigm. I would be proud to have one or three in my system.
Paradigm Signature Sub 2 Subwoofer Review Meaurements and Analysis
Configuration for Measurements
The Paradigm Signature Sub 2 subwoofer was measured outdoors sitting on the ground with the M30 microphone placed 2 meters from and pointed directly at one of the blank panels of the cabinet with four of the six drivers pointed toward the microphone in a V shape and the final two firing backwards away from the microphone. The XLR input was used, the internal low pass filter was disabled, the phase was set to 0 and the subwoofer volume was set to its center detent. The PBK equalization curve used to flatten the in room response was deleted from its memory. The Sub 2 was connected to a 240v ac line for all of the testing unless specifically noted that the measurement was taken using 120v ac power. All tests were conducted in this configuration, except for those tests purposely conducted to examine the effects of the built in functions, different cabinet orientations, or different operational modes.
The overall approach to this testing along with the equipment and software used is outlined in the article here.
Powered Subwoofer Testing Outline and Procedures Overview
additional recommended reading: How to Interpret Audioholics Subwoofer Measurement Report
Editorial Note on Enclosure Orientation for Outdoor Measurements:
When measuring subwoofers for performance such as CEA2010 maximum short term output in an outdoor environment, in order to have an accurate comparison of data in a fair manner each DUT should have as much of its energy directed at and as close to the specified distance from, the microphone element as possible. For subwoofers with multiple points of radiation such as those having ports that fire from the opposite side of the enclosure, or drivers on multiple sides of the enclosure, it is impossible to direct all of the radiation towards the microphone and minimize the difference in distance. In room there are boundaries that constrain and reflect the output back toward the listener from these multiple points of radiation. Outdoors in quarter space there are no close boundaries other than the ground. This causes the output to be under represented when measured from any single point in space around a subwoofer having the radiating elements separated as compared to a subwoofer using the same radiating elements placed all on one panel which can then be directed towards the microphone. Technically there is no difference in total energy from the two approaches only distribution of it depending on where you are in proximity to it. That being the case there is a need to develop a compensation file for subwoofers such as Paradigm’s Signature Sub 2 which has drivers firing from three opposed faces on the enclosure such that no matter how it is oriented there will always be drivers firing away from the microphone. Additionally the Sub 2’s drivers all operate over the entire effective range of the subwoofer unlike a port or passive radiator. Measuring from a greater distance from the subwoofer helps to equalize for the differing distances from the major points of radiation to the microphone. In order to ascertain the correct amount of compensation to add to correctly represent the Sub 2’s output SPL a series of measurements are taken at various distances of 1 meter, 2 meters, 4 meters and 10 meters, using the same drive level and compared with the change in SPL that should occur due to the inverse square law. Measuring at 10 meters (roughly 32.8ft) allows for much better integration of the Sub 2’s output from the various drivers since a difference of less than a meter to the microphone causes a negligible difference to the total SPL at that distance. This is then compared to the 2 meter measurement and what the 10 meter measurement indicates that the 2 meter measurement should show according to the predictable drop off in SPL of the inverse square law. The difference then becomes the compensation file.
Paradigm Signature Sub 2: Output Compensation
Outdoor Groundplane Measurements & Analysis
Paradigm Signature Sub 2: Basic Response
Above is the basic response measurement of the Sub 2 with the internal low pass filter defeated. Overall this is an extremely extended and impressively flat response which fits within +/-3dB from 13-240Hz. 13Hz is an extremely deep -3dB point in a quasi anechoic setting especially for a sealed alignment. The -10dB points are at 11.1Hz on the low end and 285Hz on the top end respectively. The Sub 2 should be able to be effectively crossed over as high as 180Hz if such an extended range were needed to integrate with small, bass shy mains perhaps. This might be an unlikely scenario but it is nice to have the bandwidth available to do so if needed.
Paradigm Signature Sub 2: Effect of Low and High Pass Filter Settings
Above is the effect of various settings of the Sub 2’s low pass filter on its upper bass response. These were taken with the filter bypassed and at the minimum, maximum, 11 o’clock and 1 o’clock positions on the dial. These correspond to about 40Hz, 50Hz, 80Hz and 120Hz acoustically. The Sub 2 exhibits a text book 4th order LR roll off.
Paradigm Signature Sub 2: Waterfall Decay
Paradigm Signature Sub 2: Group Delay
The response of the Signature Sub 2 in the time domain shows no area of concern, never breaking even1 cycle of delay. The waterfall plot is free from any ringing and shows a rapid 30dB drop in energy which is exactly the type of thing you would want to see indicating a well damped response with a clean decay. There is a slight increase in energy below 25Hz due to the boost EQ being employed to extend the response but it is at very deep frequencies and not enough to be of any concern at all.
Paradigm Signature Sub 2: Long Term Output Compression
Above are the results of the output compression test for the Sub 2. It maintains the very deeply extended basic response shape up until the nominally 100dB output sweep. By the nominally 105dB level there is starting to be some output limiting below 20Hz. By the 110dB nominal output sweep it is obvious that the limiting circuit is intervening heavily, limiting the deep bass output at which point the response shape below 30Hz has changed by a large amount. Increasing the level a further 5dB resulted in the Sub 2 abruptly muting a few seconds into the measurement. When this happened I was worried that a fuse had blown in the amplifier or that something else had happened in the amplifier. After a few tense minutes the Sub 2’s amplifier reset and resumed operation. Luckily it was only a protection circuit inside of the amplifier that muted the output. To say that I was relieved is an understatement. After this occurred I was a little more careful with the input levels sent to the Sub 2. Remember that 13Hz extension that was mentioned earlier? The Sub 2 has incredibly deep extension but its relatively modestly sized sealed enclosure implies that it also requires a very large amount of deep bass boosting to accomplish it. This combined with the very high output levels being asked from it resulted in a monumental amount of power being asked from the amplifier which resulted in it protecting itself. The Sub 2 with its six long throw drivers and brutally powerful amplifier is in a much better position than most to be able to handle the increased load but even it will eventually succumb to physics. This was the only event of note encountered with the Sub 2 during the entire review process. It was run very hard in actual use during the listening sessions and this protection never triggered, so it is very unlikely to occur with real world use and signals.
Note on Output Compression Testing: This is by far the most demanding measurement type conducted on the subwoofers and will reveal any issues with overload, port compression, port noise, driver distress, creaks, rattles, buzzes, clipping, etc. Additionally this is outdoors with the subwoofer operating alone with no nearby walls or objects to vibrate and no upper frequency content from other speakers that would normally help to cover up or mask any objectionable noises from the subwoofer in a typical room. Any sort of audible distress or issues with the subwoofer will be readily apparent in this environment.
During the high power sine wave sweeps the Sub 2 behaved as well as one could hope and never sounded distressed or overdriven. There were no cabinet or panel resonances noted and the drivers while driven to large excursions in the low bass range never seemed to be out of control. Even at the very loudest levels there were no discernable buzzes, rattles, resonances, or other spurious noises. Being a sealed system there is no possibility of port noise either. The Sub 2’s force cancelling design and distribution of the amplifier power amongst six drivers coupled with a rock solidly constructed enclosure combine to give it among the quietest at the limit operation I’ve encountered. Judging from what I observed despite the humongous power reserves of the Sub 2’s amplifier it is still an amp limited design and as such it will go into protection before the drivers are driven to audible distortion. The Sub 2 simply refused to make an offensive noise.
Paradigm Signature Sub 2: Output Compression Magnitude
Above we have another way of looking at the previous results which shows only the amount of output compression occurring. Here we can see that the Sub 2 has virtually no compression up to and through the 100dB nominal sweep level. Further increases in level indicate that the subwoofer is into the limiter in the sub bass frequencies and give an indication as to the shape and placement of the equalization used to extend the Sub 2’s response. It appears that the boost is centered at 14Hz and is probably at least 12dB which is a substantial amount. 12dB of boost corresponds to 16 times the power needed from the amplifier. The negligible amount of compression apparent above 40Hz indicates that there is likely a large amount of headroom still available there.
Paradigm Signature Sub 2: Connected to 120v versus 240v AC
Above we have a comparison of the Sub 2 when connected to a 240v versus 120v line. Paradigm’s literature on the Sub 2 indicates that the amplifiers long term output is limited when on 120v service so as to avoid potential tripping of the breaker and that for maximum output and headroom a 240V line is recommended. In order to test this out the Sub 2 was measured both on 240v and 120v service. The graph above shows that there is essentially no distinction in the Sub 2’s performance when using it with either voltage well within its limits. This is the bottom two traces on the graph. However the 240v line does allow 2 or 3dB greater long term SPL if you drive the Sub 2 to its limits as shown in the top two traces on the graph where you can see that on the 120v service the Sub 2’s deep bass output limit is a couple of decibels lower. This is just as Paradigm claims. To make a long story short there was some performance advantages to the higher voltage line but they really only take effect if you are running the Sub 2 at the edges of its very considerable limits. Otherwise it performs virtually the same on either voltage.
Paradigm Signature Sub 2: Total Harmonic Distortion
Paradigm Signature Sub 2: 110dB Sweep Distortion by Component
Total harmonic distortion and distortion by harmonic component testing reveals that the Signature Sub 2 has very low distortion above 35Hz well below 10% and less than 5% THD above 40Hz. In the deep bass the distortion increases smoothly as is usual with sealed enclosures where all of the output comes from driver displacement. Still the THD stays below 15% until under 20Hz. Once again the effects of the deep bass boosting can be seen in the distortion results near 14Hz. Even though the distortion below 16Hz may seem high the Sub 2 never sounded distressed or distorted to the ear. The make-up of the THD is primarily 2nd and 3rd harmonics which are not as offensive as higher order over tones. Overall this is a good showing for a sealed subwoofer especially considering the amount of actual output capability below 30Hz.
Paradigm Signature Sub 2: CEA2010 2 Meter Groundplane RMS Results
Paradigm Signature Sub 2: CEA2010 2 Meter Groundplane RMS Comparison 120v / 240v
CEA2010 Results
As expected the CEA-2010 maximum short term distortion limited output results are impressive with over 120dB recorded at 50Hz and above. In the sub bass frequencies the six 10” drivers and amplifier combine for some heavy lifting with just shy of 100dB of maximum peak output at 12.5Hz and almost 97dB at 10Hz. Remember this is a quasi anechoic outdoor result. In room with the help of pressure vessel gain, output in these bands could easily be boosted by 10dB or more. The Sub 2 is amplifier limited at every band above 16Hz and is 3rd harmonic distortion limited below 20Hz. More important than the output at any one band is the overall headroom that is available across the entire bandwidth. Not to mention that this sort of output is produced from a unit not much physically bigger than many companies vented 12” offerings. The Sub 2 was CEA-2010 tested while operating from both a 120v and 240v line. 240v operation offered about 1-1.5dB more output below 25Hz and slightly less distortion. Higher up in frequency the output advantage was only about 0.5dB in favor of the higher voltage operation.
Paradigm Signature Sub 2 Subwoofer Review Conclusion
Paradigm
has produced a tour de force with the Signature Sub 2. It is overall
the highest performing and most thoroughly impressive subwoofer that
I have encountered. The msrp of $8,999 is undoubtedly a large chunk
of cash but with the amount of development, technology and hardware
packed into each Sub 2 coupled with the attention to detail, high
tech look, beautiful finish and high
performance, that big sticker starts to look more reasonable. The
performance basics are well covered with a linear response, deep
extension, low distortion and plenty of headroom. Additionally
Paradigms PBK system is probably the best example of an automatic
equalization system that I have used to date. It made a measurable
and clearly audible improvement in response smoothness in my room. I
was also pleasantly surprised at the basic control scheme and lack of
filler features of limited usefullness on the Sub 2. The result is a
subwoofer that is surprisingly easy to integrate and set-up. I had it
dialed in in about an hour and a half, at which point it sounded very
good indeed. Wall shaking power is on tap at will as the Sub 2
clearly demonstrated with a couple of big time performances on movie
night. Obtaining useful extension and output down to the 10Hz range
is not out of the question with this subwoofer. Likewise with two
channel music there is plenty of headroom to serve up near live
output levels. But the kicker is that no matter how hard the Sub 2 is
pushed the output is always well controlled and lacking in
significant coloration. You are more likely to run into issues with
objects vibrating due to the Sub 2’s output in your listening
space. That sort of neutrality coupled with lots of headroom goes a
long way towards making the foundation of any material sound its
best. The Sub 2 simply performed magnificently no matter what I
happened to be listening to. One other unanticipated attribute of the
Sub 2 that I noticed was that it always started a conversation
whenever one of my friends or family would be over and see it for the
first time where they would ask what it was or “how
does that one sound”? Most
of my friends have seen so many speakers come through my house that
they barely get a second glance or draw a comment anymore. Not the
Sub 2, it invariably received comments and questions. Paradigm’s
Signature Sub 2 is undoubtedly one of the most impressively
engineered powered subwoofers on the market today. If this fine
subwoofer is within your financial means you would be remiss to not
give it an audition.
The Paradigm Signature Sub 2 receives the Audioholics Bassaholic Extreme Room rating, which means that this sub is recommended as maintaining adequate headroom in rooms or spaces of 5,000 cubic feet or greater and/or for users who usually listen at high volume levels. For further information in how we make these recommendations see the full article here.
See: Audioholics Subwoofer Room Size Rating Protocol
Paradigm
Signature Sub 2 Review
Paradigm
Electronics Inc.
Paradigm.com
Customer
Support: (905)696-2845
MSRP:
$8,999
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Bass Extension | ![]() ![]() ![]() ![]() ![]() |
Bass Accuracy | ![]() ![]() ![]() ![]() ![]() |
Ergonomics & Usability | ![]() ![]() ![]() ![]() |
Dynamic Range | ![]() ![]() ![]() ![]() ![]() |
Performance | ![]() ![]() ![]() ![]() ![]() |
Value | ![]() ![]() ![]() |
