BenQ W5000 DLP Projector Review
by July 23, 2008
BenQ W5000
BenQ W5000
  • Product Name: W5000 DLP Projector
  • Manufacturer: BenQ
  • Distributor: VisualApex
  • Review Date: July 23, 2008 20:38
  • MSRP: $ 4999
  • Display Technology: DLP Technology by Texas Instruments
  • Native Resolution: 1080p (1920 x 1080)
  • Resolution Supported: 480p, 720p, 1080i, 1080p
  • Brightness: 1200 ANSI lumens
  • Contrast Ratio: 10000:1
  • Image Size (Diagonal): 40" to 300"
  • Throw Ratio: 98"@4m (98"@13.12 feet)
  • Zoom Ratio: 1.2:1
  • Video Processing: Silicon Optix HQV
  • Aspect Ratio: Anamorphic/ 4:3/Wide/Letter Box/ Real screen selectable
  • Lamp: 200W, 2000/3000 hours (Normal/Economic mode)
  • Operational Noise: 28/25 dB (Normal/Economic mode) )
  • Horizontal Frequency: 15 ~ 75 kHz
  • Vertical Scan Rate: 50-85 HZ
  • Input Terminals: HDMI (with HDCP) x 2; Component Video; RGBHV/BNC (shared as Component 2); Composite Video; S-Video
  • Video Compatibility: NTSC, PAL, SECAM
  • Lens: F=2.4-2.7 f=38.9mm (wide) – 46.6 (tele) mm
  • Lens Shift: Power +120% - 80%
  • Control: 12V Out, RS-232C
  • Adjustments: 100 to 240 V AC, 50 to 60 Hz
  • Auto Switching Power Supply: Max 340W
  • OSD (On-Screen Display) languages: English/ French/ German/ Italian/ Spanish/ Japanese/ Traditional Chinese/ Simplified Chinese
  • Accessories (Standard): Users Manual, Safety Manual, Remote Control, Batteries, Micro Dust Filter, Power Cords (Euro and US), Component Cable
  • Accessories (Optional): Ceiling Mounting Kit, Spare Lamp Kit, HDMI Cable
  • HDTV Compatibility: 1080i, 720p, 576p, 576i, 480p, 480i
  • Preset Modes: Cinema, Dynamic, Standard, User 1, User 2, User 3, Photo, Gaming Mode
  • Functions: BenQ Senseye Technology, DynamicBlack, Powered Vertical Lens Shift, Motorized IRIS Adjustment, Dust Proof with Air-Filter, ISFccc, Panamorph Compatible
  • Dimensions (WxHxD)    19.4" x 7.7" x 15.5" (492 x 195 x 393 mm)
  • Weight: 21 lbs (9.6 kg)
  • Support for anamorphic aspect ratio
  • Excellent post-calibration performance
  • Great value given street pricing
  • Anemic 1.2x zoom lens
  • No horizontal lens shift
  • Poor out-of-the-box performance
  • Overscan anomaly with SD material
W5000 Features and Build Quality
If you think you're having a hard time deciding which projector is the best, think about my job... I actually get to see, use, and calibrate most of them and yet I still have a hard time determining which is "best". Let me tell you that I do NOT envy the job manufacturers of projectors have these days. The market is ripe with bargains and price points are all but written in stone, with very clear distinctions between $1000, $2500, and $5000 models - all of which are competing for consumers' wallets. BenQ is clearly going after the custom installer market with its new W5000 DLP projector and that's good - because it gives them some leeway that wouldn't be granted for those pursuing consumers directly.
BenQ has a history of making some very excellent projectors. They now appear to be in a mode whereby they are attempting to really bring some incredible value and quality to consumers with their W5000 and W20000 DLP systems. The two projectors are remarkably similar; however the W5000 lacks some of the optical engine refinements of its bigger sibling and therefore has a slightly lower contrast ratio. The two share the same chassis, menu system and general features, so it's a good bet that many will find the W5000 to be the bargain of the lot.
The W5000 is a bit of an enigma, or a huge deal depending on your point of view, since it sells on the street for less than half its retail price point. In fact, the upper-scale W20000 has a street price that equals the retail price of the W5000. For a brand new product those are some steep discounts.
If you have been reading our reviews you'll find that the important differences which affect picture quality are getting harder to distinguish and lots of manufacturers are really getting it right. I guess that's a good thing, since negatives of late seem to center on obtuse vs. helpful menu systems, excellent vs. average calibration results and the general feature sets. For the W5000 image quality looks to be above average but we found a few surprises worth noting.
Mercedes BenQ?
W5000-top.jpgPhysically, the W5000 is an impressive projector. While not exactly elegant, it is a true machine. From my first glance at its exterior I had to pop my eyes back in their sockets when I saw the enormously deceptive size of the lens hood. The W5000 exudes high build quality, from its looks, to the 21 pound weight and convenient side-entry lamp replacement.
The top of the projector houses a real slick-looking control panel for menu, power, and source controls. You can also activate lens shift functions and toggle through presets. Three small lamps give you a quick overview of power, temperature and lamp status (you really only want to see one light on.) The enclosure itself is a beautiful mix of white and silver with some black trim thrown in for good measure. I'd easily cast my vote for having this thing show up as a small Decepticon in next year's Transformers 2 movie. Lamp access is via the left side (no need to remove the projector from its mounted position) and the filter can be replaced easily from the right side of the unit. Unlike most projectors I've seen, all four feet are adjustable. If you're not mounting this to a ceiling or other permanent fixture, however I think you'd be doing yourself a disservice.
W5000 vs. W20000
Some may be curious as to what differences there are between the W5000 and the W20000. Near as I can tell, the differences are about $2500 and 0.95-inch DarkChip3 DMD technology. The W20000 uses the new DC3 technology while the W5000 uses the less expensive (but still impressive) DC2 DMD. Both projectors utilize Philips' VIDI lighting technology which helps enhance both red and blue color performance to create a more accurate picture. Both projectors also appear to have identical features apart from the DMD chip, including the dual iris system and HQV Reon-VX video processing.
I Like the Way She Moves
W5000-top-angle.jpgBenQ seems to have spared no expense in equipping the W5000 with a slew of handy features. Some I found useful, but all are very handy in terms of their ability to allow this projector to dial in a nice picture and work well in a myriad of installation scenarios. While DLP has a lot of catching up to do when it comes to lens shift, the W5000 at least provides vertical shifting of the optical system. This means that you have some height flexibility when mounting the system in a front or rear projection scenario. The W5000 allows up to +120% and -80% adjustments, giving you a wide range of placement options. Horizontal shifting is unavailable - so you'll really have to nail your location or ensure that your screen can be shifted slightly to get the perfect projected image.
Other hardware advances include a dual iris system. This is cool, and it's rather complex. I personally like it because it allows me to get better black level output when high lumen output isn't so important. Then, once I choose my fixed Iris position, the Dynamic Black electronic iris kicks in and further refines the image on screen. Here's BenQ's graphical representation of how the Iris system works:
In our case, we dialed the fixed Iris down to 2 and enabled Dynamic Iris after we calibrated the unit to allow it clamp down during truly dark scenes. The way we understand it - you set the light output potential using the fixed iris, then you enable (or not) the Dynamic Black mode to further reduce light output (resulting in lower black levels) during darker scenes. Cool? Yeah it is.
Connections
BenQ provides a pair of HDMI inputs and dual component video connections, though the second is a BNC-style RGBHV input. Composite and S-video are included and should never be used with a projector at this price point. The RS-232 connection is a funky 8-pin din connector that requires a cable in order to connect to most serial control devices. Finally, a 12V trigger allows the projector to control a drop down projection screen or other device based on the status of the W5000.
Dual HDMI, Dual component video (including 1 via BNC), 12V trigger and RS-232C control.
W5000 Throw Distance and Menu System
Once again I called upon my Peerless PRG-UNV Precision Gear universal projector mount to handle the duties of supporting and dialing in the physical orientation of the W5000. The BenQ comes with four threaded mounting holes - which sounds standard except that my reference Marantz VP-15S1 and the even the last projector I reviewed only had three mounting points. No matter how you slice it - four is better than three for mounting projectors over 15 pounds.
Physically setting up the projector is easy, provided your room is long enough. Primarily you want to configure it for front projection (ceiling mount in my case) and then dial in the vertical lens shift until you have it perfectly in line with the screen. Since there is no horizontal lens shift you must do a very good job of getting that lens centered to the screen, or ensure that you can slide the screen left or right as needed (most screens with the exception of Stewart and a few others allow the screen to be slipped horizontally as needed.) We connected both HDMI and component video to the W5000 to ensure we could thoroughly test it out in our system.
The 1.2x Zoom lens on this projector is pitifully weak. It allows for only a cursory zoom and as a result you will have a very strict window in order to hit your particular screen size. This seems to be a trend in DLP projectors and one I find disappointing. Pay close attention to the throw chart below as it will determine where you need to mount the projector in order to hit your particular screen size.
Throw Chart for Distancing the Projector from a 16:9 Projection Screen
As you'll see below, you'll need to be at least 13 feet 5-inches away to hit a 100-inch diagonal screen. That's a pretty long throw distance and one that I find a bit too restrictive for most people. While the image is extremely sharp and clear, the placement requirements of this projector may automatically rule it out for many consumers with smaller rooms.
Screen Size
Diagonal (inches)
Size (Inches)
Distance (Feet)
width
height
wide
tele
70
61.0
34.3
9' 4"
11' 3"
80
69.7
39.2
10' 9"
12' 11"
90
78.4
44.1
12' 1"
14' 6"
100
87.2
49.0
13' 5"
16' 1"
110
95.9
53.9
14' 9"
17' 8"
120
104.6
58.8
16' 1"
19' 3"
150
130.7
73.5
20' 1"
24' 2"
170
148.2
83.3
22' 9"
27' 4"
200
174.3
98.1
26' 9"
32' 2"
Tweaking the Menu System
If I had to describe the menu system on the BenQ in one word I'd say: Simple. Intuitive. Logical. Then you'd say "Hey, that's three words." And I'd say "Whose article is this, anyway - go write your own." The menu system is well laid out and doesn't confuse users with a trendy, pictoral, or otherwise "innovative" (read: frustrating) user interface like so many other models. Menus should be simple, easy to access and logically laid out. This one is and that means you'll spend less time navigating around and more time getting things dialed in.
menu-picture-basic.jpgPicture - Basic
The name of this menu section is accurate. It provides access to the basic picture controls such as Brightness, Contrast, Color, Tint, and Sharpness. You can also select the Picture Mode which is accompanied by any number of presets designed to work well in different scenarios. As you'll see in our calibration section, we highly recommend starting with Cinema Mode. Nearly any time you affect the Picture mode you'll hear the rather "grating" sound of the powered Iris system as it changes to accommodate the new setting.
menu-picture-advanced.jpgPicture - Advanced
Once you are in the correct picture mode you can make many other adjustments to help bring out the best picture quality possible. Black Level should be set to 7.5 IRE, not 0 in order to get the best response possible. We were not able to achieve below black (blacker than black, or BTB) no matter what we tried, however we weren't unsatisfied with our black level response. The Clarity Control has its own submenu of four functions. Noise Reduction only works on standard definition content (we recommend a setting of +2). Detail Enhancement seemed fine at +1. Both Luma Transmission and Chroma Transmission looked better to us in the Off (0) position, however it will definitely cause colors and high contrast areas to pop. We just felt it added too much edge enhancement and took away the film-like nature of the projected image.
The Gamma can be set, and after calibration we did indeed achieve close to the 2.4 setting we configured. Brilliant Color definitely cause colors to pop, but we felt it to be a tad artificial and not accurate. Skin tones looked oversaturated. We left it off both during and after calibration. The saturation of specific Primary and Secondary colors can be dialed in using the Color Management menu system. We didn't go this far, and indeed our results didn't indicate much of a need to affect global color saturations. Dynamic Black controls the secondary Iris system. We left this off for calibration, but enabled it afterwards. Not once did we notice it engaging during normal use. Of course, with our primary Iris set at just +2 the secondary iris (Dynamic Black) was doing very little overall.
The last item on this menu (which can also be accessed directly via the remote) is the vertical Lens Shift which we found incredibly useful. The W5000 can go +120% and -80% vertically. In our inverted ceiling-mounted position that meant it had more negative (down) range than up. In either case, it's an ample amount of lens shift and should do well for nearly any installation.
menu-display.jpgDisplay
The Display menu is well laid out, however the Lens Shift would have been better placed here alongside Keystone and Position functions which both digitally alter the position of the image on the screen. Overscan Adjustment, as we mention below, has a strange interaction with the Silicon Optix video processing engine in that it needs to be set to +2 for best (smoothest) deinterlacing response. We didn't notice any problems when progressive material was sent to the projector. The PIP functionality is cool, however the second source is only possible with S-video or composite sources. You cannot simultaneously run two HD channels using the PIP mode. This is unfortunate; however most of those with digital cableTV set top boxes will find they have that functionality already built in.
menu-system-setup.jpgSystem Setup
This menu contains the items which will likely be configured once and then never used again. This includes the Projector Position, Language, Splash Screen (which can be customized), Sleep Timer, Menu position and Auto Source Search. I tend to disable auto source search, simply because the projector tends to freak out when the cableTV switches resolutions - as it so often does when moving between HD and SD channels. Custom Installers can use a laptop to set a custom client screen with their logo (and perhaps phone number) as the startup screen. Not a bad idea to make sure you get the follow up calls should your client decide to do further upgrades.
menu-advanced-setup.jpgAdvanced Setup
Advanced setup contains such items as your Lamp Power level (we recommend Whisper as the fan is noticeably louder with Normal mode). You can activate High Altitude mode if you like excessive fan noise (or I suppose if you live at high altitudes where the fan won't be as successful at cooling down the lamp). The ISF password is also located here (I could tell you what it is, but then I'd have to... you know the rest). You can password-protect the settings and there is also a key lock function (which is terribly easy to engage (too easy if you ask me) that can be turned off by holding down the remote control's Exit button for 5 seconds. Key Lock disables all remote control functions as well as the physical buttons on the projector itself. This is a good idea for presentations or conventions and is certainly better than a black piece of electrical tape over the IR sensor.
The last tab on the menu system is an Info display that shows the current input resolution, Picture Mode, Source, and Lamp and Dust Filter hours of use.
Remote Control
W5000-remote.jpg As I hinted, the remote is great, though a tad large in the hand. It is completely backlit and the light can even be deactivated by a second press of the 'Light' button. The remote has direct input buttons for each input and has direct access to Memory settings and common controls such as Brightness, Contrast, Iris and Lens Shift. About the only negative I saw with this remote is the lack of discrete On and Off controls at the top. It's becoming increasingly common to see "Double Tap" power buttons for turning the projector off. I don't particularly prefer this method as it's not as handy as a discrete power system, however it's certainly not a major issue.
W5000 Calibration and Bench Testing
As always we utilize datacolor's ColorFacts Professional software with a Spyder2 sensor (tristimulus colorimeter). Our opening measurements were not all that hot, but certainly watchable. Color temperature was around 7500K and there was a noticeably bluish tint to the bright areas of the picture. It's almost as if this ISFccc-certified projector was made to include a calibration from an installer. As you'll see below it dials in quite nicely and we were more than pleased with our final results.
Checking out the various picture modes, we found the following when engaging the Whisper mode of lamp operation and color temperature set to Warm:
  • Cinema Mode - 7500K, 15 fL
  • Dynamic Mode - 14000K, 17.5 fL
  • Standard - 9000K, 21 fL
We found it odd that Standard mode actually provided more light output than Dynamic mode. When turning the lamp to Normal mode, we saw some further light output improvements:
  • Dynamic Mode - 21 fL
  • Standard - 24 fL
Crank the lamp to Lamp Native mode and you'll see even more output (but the color accuracy gets thrown out the window). To dial in the best initial picture we chose Cinema Mode, selected the Warm Color Temperature and set Black Level to 7.5 IRE. Brightness needed to be set to +61 and Contrast dropped to +43. The lamp, as expected, was placed in Whisper mode (BenQ's version of Eco mode).
We performed our calibration on a Carada Masquerade Screen Masking system. Their Brilliant White screen material has a gain of 1.4 but is clean and presents no hotspots that we can detect. The grayscale color controls are very sensitive and any changes could be seen immediately on the screen. We knew right away that Blue was a bit high and we'd need to do some work to get the system perfectly dialed in. Fortunately, the system was extremely responsive and the results are some of the best we've ever seen in a projector.
Final Gamma (right) was between 2.4-2.5, a slight but marked improvement over the original 2.6 (left)
The grayscale, initially dominated by blue (left), ended up nice and smooth after our calibration (right)
Color temperature dropped from its initial 7500K (left) to an almost spot-on 6500K across the board (right)
It's been a while since I experienced a projector this easy to calibrate and get to a really across-the-board result that I found to be near perfect. The menu system makes it easy to get around and the numerical controls aren't so ridiculously over-delineated that changes take forever to materialize on the screen. The W5000 is ergonomic and will make lots of home enthusiasts and custom installers very pleased.
Perfect Score is 130
BenQ W5000 Benchmark Score: 105
(Excellent performance - throw anything you want at it)
Test Max
Points
Results Pass/Fail
Color Bar 10 10 Pass
Jaggies #1 5 5 Pass
Jaggies #2 5 5 Pass
Flag 10 10 Pass
Detail 10 10 Pass
Noise 10 10 Pass
Motion adaptive Noise Reduction 10 10 Pass
Film Detail 10 10 Pass
Cadence 2:2 Video 5 5 Pass
Cadence 2:2:2:4 DV Cam 5 0 Fail
Cadence 2:3:3:2 DV Cam 5 0 Fail
Cadence 3:2:3:2:2 Vari-speed 5 5 Fail
Cadence 5:5 Animation 5 0 Fail
Cadence 6:4 Animation 5 0 Fail
Cadence 8:7 animation 5 0 Fail
Cadence 3:2 24fps film 5 5 Pass
Scrolling Horizontal 10 10 Pass
Scrolling Rolling 10 10 Pass
Total Points 130 105
*Tested with 480i via HDMI from a Denon DVD-3930CI
HD Tests (via Blu-ray @1080i)
Max
Points
Results
Pass/Fail
HD noise
25
0
Fail
Video Resolution Loss
20
20
Pass
Video Reconstruction
20
20
Pass
Film Resolution Loss
25
25
Pass
Film Resolution Loss Stadium
10
10
Pass
Total Points
100
75
Comments on Bench Testing
We encountered two really bizarre events as we calibrated the projector and explored its many features to find the optimal settings. The first we discovered while running the Jaggies #1 test. The rotating bar on the screen, while smooth, seemed to "judder" around rather than smoothly spin on its central axis. Changing the Overscan Adjustment setting to +2 (minimum is +1) fixed this and resulted in smooth spin. As near as we could tell the video processor had some issue with the +1 (lowest) setting.
The second event occurred when we attempted to experiment with the Dynamic Black setting. Once activated, the projector began making mechanical noises (not iris-related) that sounded like it was unable to control the black levels - and indeed the screen bore this out, with a constantly changing light output level. At first, disabling the Dynamic Black fixed it, however soon the noise came back and the Dynamic Black was once again out of control. After power cycling the projector this never again occurred.
In testing for rainbow effect we noticed two things. First, we could easily see RBE with any test pattern that showed a thin white line on black. Second, we couldn't see RBE in most of our real-world test material. This presents the scenario that if the on-screen image shows high contrast white on black you'll likely see it, but with 99% of viewing material this won't be an issue.
Recommendations
I like having Overscan essentially 'Off' so I'd like to see a firmware fix that addresses this particular video processing anomaly. I'd also leave it up to the user as to whether or not they engage Luma and Chroma Transmission in the Clarity Control settings section. My preference was to leave them off to avoid any edge artifacts, however you may prefer the increased color and luminance detail. I have to say, this is one of the most detail-rich, most naturally sharp projectors I've seen in a long time, so my preference for leaving these particular enhancements 'Off' didn't make me feel as if I was missing anything.
Noise Reduction seemed best when set to +2. It did an incredible job of reducing mosquito noise in the picture and I didn't encounter any disjointed "floating object" effects so often experienced when the noise reduction hits the edge of an object and unnaturally "floats" it over the background. There was no blurring on the Motion Adaptive tests we did, in either the HQV disc or real-world examples, so the noise reduction system is good for both static and moving images. Noise reduction does not, however, work for HD sources and it is grayed out when any progressive or 1080i signals are received. The Film Detail lock was as quick as anything I've seen, meaning that the HQV processor can recognize and grab onto an unflagged 2-3 pulldown scene with no difficulties.
W5000 Viewing Evaluation and Conclusion
I'd like to leave this section with as few words as possible. The images truly speak for themselves and we found the picture quality of the BenQ to be both filmlike and crisply detailed. Detail was so good, in fact that I was able to see definition and characteristics of on-screen elements in places I had never been able to see before. I always espouse high definition as being able to see the dimples in a golf ball when watching Tiger Woods in HD. With the W5000 you'll likely begin to notice the shadows in the pits. Everything below is taken with our reference Marantz VP-15S1 DLP projector in mind, a model we keep on hand to compare other products to and derive differences and capabilities.
advertisement
HDTV: Deadliest Catch
This is a great show on Discovery HD Theater, made even greater opportunities to see how well your display stacks up against nighttime hi-def shots, rolling waves, and a lot of fast pans with complex source material. Ever want to see how well your front projector will follow a king crab flying across the screen into an ice-soaked ship deck? OK, maybe I'm weird... Still, it looked really great on the W5000.
The colors in this show really come out in the sky and the outfits worn by crew members as they struggle to survive the brutal conditions associated with fishing the Bering Sea.
HDTV: My House is Worth What?
This show is filmed with high quality HD cameras and utilizes ample lighting. The result is a crisp, clean image that is hard to beat. Colors pop, edges are crisp and the content does well to show off any projector's ability to render crisp detail. In this particular episode, an establishing shot of the city resulted in a real-world deinterlacing test which the W5000 passed with flying colors.
Look at the buildings here. At 1080i and in motion, this presented a great challenge.
HDTV: MTVHD Bon Jovi Live Concert
We got a chance to see some Bon Jovi in high definition courtesy of MTV's new HD channel. It was well worth our time and the images we captured, while they can't possibly do justice to what we saw, are at least representative of the excellent material we viewed.
DVD: Shrek
An oldie, but goodie, I wanted to put something up which showed the excellent film-like color reproduction possible with the W5000. Shrek seemed like a perfect movie to use and we also got to see more of how well the BenQ projector handles SD content upconverted to its natural 1080p resolution.
Colors popped but maintained a film quality provided Brilliant Color was left off
Brilliant animation moments like this delivered shadow detail and opportunities to see (a lack of) banding in difficult areas of images such as fire on a kettle.
The street price of this projector is around half its retail. Given the quality and level of sharpness this system is capable of - plus the excellent Blacks it can produce thanks to its dual iris system - it's hard not to take notice. The BenQ W5000 is going to rival some more expensive projectors and certainly beats out the Epson 1080UB in terms of its ability to reproduce deep rich blacks. For those daring enough to risk even less lumen output and less contrast, you can dial down the iris to its lowest setting and really get some seriously low black levels. For those wanting some daytime use the W5000 offers enough flexibility to endure with ambient light and less-than-pristine viewing conditions.
I think BenQ hit one out of the park this go-around. The W5000 isn't perfect (heaven knows I'd like a shorter throw distance and horizontal lens shift) but for the price it's really, really, hard not to take some serious notice. We started by trying to figure out what price bracket the BenQ W5000 fit. The answer is that it is pretty much taking on, successfully, both the $2500 and $5000 markets. Put this on your short list and be sure to check it out.
MSRP $4999
15375 Barranca
Suite A205
Irvine, CA 92618
949-255-9500
www.benq.us
About BenQ Corporation
BenQ Corporation consists of three main business groups ¡X Digital Media Business Group, Integrated Manufacturing Service Business Group and Mobile Communications Business Group. These three business groups encompass a broad range of products and each possesses a focus on providing consumer-oriented solutions designed for the digital lifestyle. 2006 revenues for BenQ Corporation exceeded US$6.2 billion dollars.
  • StarStarStar — Good
  • StarStar — Fair
  • Star — Poor
MetricRating
Detail and ResolutionStarStarStarStarStar
Deinterlacing & ScalingStarStarStarStar
Contrast and Black LevelsStarStarStarStarStar
Color ReproductionStarStarStarStarStar
Noise ReductionStarStarStarStarStar
Calibration OptionsStarStarStarStarStar
Ease of SetupStarStarStarStarStar
FeaturesStarStarStarStar
Remote ControlStarStarStarStar
ValueStarStarStarStarStar
