Phoenix Gold In-Wall LCR Speaker
Phoenix Gold featured its new In-Wall LCR speaker at the 2007 Electronic House Expo, held in Orlando, Fla. from March 8-10. The ATI515 is scheduled to be available in March 2007.
The dual 5.25 inch mineral filled polypropylene drivers and one inch swivel mounted dome tweeter with a platform that allows you to direct your audio to the sweet spot in your home theater room.
ATI515 specifications include:
- Sized to Fit between two studs
- Woofer: 2 x 5.25inch textured poly cone w/butyl rubber surround
- Tweeter: 1-inch silk dome
- Frequency Response: 60 Hz to 20 KHz
- Impedance: 8 Ohm
- Sensitivity: 85dB@2.83V
- Power Handling: 25 to 150 Watts continuous
- Outer Dimension: 15.35 inches x 8.30 inches (39cm x 21cm)
- Pricing: TBD
The ATI515 speakers are matched to the current Phoenix Gold audiophile series ATI In-Wall and ATC In-Ceiling speakers. The same speaker cones, surrounds, voice coils, and dome tweeters are used throughout.
Due to continual product improvement, all specifications subject to change without notice.
For more information, please visit www.phoenixgold.com.
