Terrestrial Digital Lacrosse Micron HDTV Antennas
The Lacrosse Micron line is the result of extensive research conducted by Terrestrial Digital that has allowed the company to produce compact antennas with far more power than traditional models.
The Micron Technology will come in 3 versions:
- Clearstream Digital Tuner/ Antenna combination
- Lacrosse Micron All Weather
- Lacrosse Micron Indoor
The Clearstream will be the first practical antenna/set top box combo on the market. The Micron All Weather version is an outdoor model that, at 10"x12"x4", is 40% smaller than the original Lacrosse. The indoor version will be a 9"x9"x4" antenna that's less intrusive and more powerful than any other indoor antennas on the market. All 3 antennas will feature approximately 10dBi of max gain and will include a low noise amplifier.
Terrestrial Digital's R & D team has developed a process to hone antenna geometries in on the narrower bandwidth with more strength. The Lacrosse, at 14" x 20", has received critical acclaim for being the first aesthetically pleasing antenna that could compete with and in most instances beat the performance of traditional antennas. When made commercially available in 2007, the Lacrosse Micron antennas will be a fraction of the size and have the same signal strength as the original Lacrosse, with the ability to pick up signals from 35-40 miles away in many areas.
For additional information on Terrestrial Digital, visit: www.terrestrial-digital.com.
