T plus A K-Series Receiver and Talis Mini Speakers
The T+A (T plus A) K-Series 5.1 Receiver caught my attention because of its clean look and the ability to turn it on by waving your hand underneath the front of the receiver. The price is a bit steep at $8500 but for that it includes a DVD! It is DPLII and DTS compatable. Specifications include 45 wpc (5 channels) + 10 wpc (two channels) zone 2 into 8 Ohms and 60 wpc + 15 wpc for zone 2 into 4 Ohms.
Paired with the Talis Mini speakers for a mere $16k for the whole package (as reported by the guy at the booth), one wonders why these things don't fly off the shelves.
- Principle 2-Way-Bassreflex Satellit-speaker
- Nominal power rating 40 Watt
- Music power rating 60 Watt
- Impedance 4 Ohm
- Frequency response 100 - 25000 Hz
- Sensitivity 90 dB/1 m 4 Watt
- Bass drive unit 1 x 80 mm
- High-frequency drive unit 1 x 25 mm
- Crossover frequencies 2000 Hz
Dimensions H x W x D 16 x 11 x 11 cm
- Weight 19 kg
- Colours black (RAL 9005), silver eloxided aluminium, Chrome, non standard RAL colour (extra cost option)
Subwoofer Specifications:
- Principle Active Subwoofer, parasitic speakers
- Nominal power rating 320 W / 4 Ohm
- Music power rating 450 W
- Bass drive unit 4 x 170 mm
- Crossover frequency active , infinitely variable from30 - 150 Hz
- Dimensions H x W x D 52 x 21 x 21 cm
- Weight 18 kg
For more information, visit www.taelektroakustik.de/eng/index.htm .
