RBH Sound Inwall Speakers
RBH Sound may be best known for their inwall and custom products. They have built a legendary reputation over the last 25+ years designing no nonsense products to fit just about every conceivable installation. At CEDIA they debuted two new inwall products, the MC-6DB and MC-83.
Technical Specifications
MC-6DB
• Bi-polar/Di-polar switchable tweeters
• -3dB/0dB/+3dB adjustable tweeter level
• -3dB/0dB/+3dB adjustable woofer level
Frequency Response: |
50Hz - 20kHz±3dB |
Sensitivity: |
88dB (2.83V @ 1 meter) |
Power Handling: |
120 Watts |
Drive Units: |
(1) 6½" Aluminum Woofer |
(2) ¾" Aluminum Dome Tweeters |
Swivel Tweeter(s): |
Yes (2) |
Tweeter Protection: |
Yes |
Crossover Frequency: |
3000 Hz |
Crossover: |
12dB/Octave |
System Impedance: |
8 Ohms |
Color: |
White Paintable Frame and Grille |
Finished Dimensions: |
8¾" W x 12" H |
Cutout Dimensions: |
7½" W x 11" H |
Weight: |
5½ Lbs. (each) |
MSRP: |
$649/pair |
![[rbh11]](/audioholics/images/rbh11_th.jpg)
The MC-6DB (bottom speaker pictured above) is the di/bi-polar in-wall with 6 inch aluminum woofer and tweeters.
MC-83
• Currently RBH's only 3-way in-wall loudspeaker
• -3dB/0dB/+3dB adjustable midrange level
45Hz - 20kHz±3dB |
Sensitivity: |
Power Handling: |
170 Watts |
Drive Units: |
(1) 8" Aluminum Woofer |
(1) 2½" Aluminum Cone Midrange |
(1) 1" Aluminum Dome Tweeter |
Yes |
Yes |
2500 Hz, 10kHz |
Crossover: |
12dB/Octave |
System Impedance: |
8 Ohms |
Color: |
10¼" W x 14¼" H |
9" W x 12¾" H |
Weight: |
5½ Lbs. (each) |
MSRP: |
$649/pair |
The MC-83 (pictured above) is a full range 3 way in-wall loudspeaker featuring an 8 inch aluminum cone woofer and one aluminum midrange and tweeter.
Pictured below are some shots of their newly released W M24 onwall speakers and MM series miniature box speakers. These are hot items to keep on your radar screen if you are looking for high performance, high value, unabtrusive loudspeakers to cosmetically appease the spouse, your golden ears and/or wallet.
For more information, visit RBH Sound
