NEW! Denon AVR-3806 and AVR-4306 Receivers
by September 09, 2005
Filed under: Receivers & Processors
Denon has released us to discuss some of the upcoming products including the new AVR-3806 and the AVR-4306 (surprise!) which bring several new technologies to market at price points unheard of to date. The items that will make you want to sit up and take notice include:
  • HDMI switching (AVR-3806 and AVR-4306)
  • Audyssey MultEQxt Room EQ and Setup (AVR-3806 and AVR-4306) includes microphone
  • iPod Terminal and USB port (AVR-4306)
  • IEEE 1394 (AVR-4306)
  • Analogue to HDMI upconversion (AVR-4306)
  • PC Setup and Control capability via RJ45 port (AVR-4306)
  • New Hybrid EL Remote Control (AVR-3806 and AVR-4306)
Feature/Specification
AVR-3806
AVR-4306
AVR-4806
· Expec ted Release Date
September
October
June
· Sugges ted Retail Price (SRP)
$1299
$1999
$3500
· Dark Silver Finish Availability
Yes
Yes
Yes
· Equal Power Amplifiers
7ch
7ch
7ch
· Power Output; Watts Per Channel @ 8 Ohms, 20hz to 20kHz
120
130
140
· All Channels Ra ted @ 0.05 T HD
Yes
Yes
Yes
· T HX Ultra2 -Certified
Yes
· Low Impedance Drive Capability
Yes
Yes
Yes
· High-Current/Discrete Amplifiers
Yes
Yes
Yes
· Independent Power Transformers
2
2
4
· T oroidal Power T ransformer
Yes
· Independent Power Supply Circuits
6
6
8
· Dynamic Discrete Surround Circuit - D.D.S.C - D
Yes
Yes
Yes
· DSP Processor
Analog Devices SHARC 21366
TBD
Texas Instruments
TMS320DA610 (x3)
· Processor Design - 32-bit Floating Point
Yes
Yes
Yes
· Processor Circuit Sampling Frequency - 192kHz
Yes
Yes
Yes
· Dolby Pro Logic IIx - with Cinema, Music, Game Modes
Yes
Yes
Yes
· T HX Post-Processing - DPL (4.0), DPL2 Cinema, DD/D T S (5.1), ES Discrete (6.1), ES Matrix, Neo:6 Cinema
Yes
· T HX Ultra2 7.1 Cinema, Music and Game Modes
Yes
· T HX Surround EX Decoding
Yes
· Dolby Digital Surround EX Decoding
Yes
Yes
Yes
· dts ES Discrete 6.1 Decoding
Yes
Yes
Yes
· dts ES Matrix 6.1 Decoding
Yes
Yes
Yes
· dts Neo:6 Stereo-to-Surround Cinema and Music Modes
Yes
Yes
Yes
· dts 96/24 5.1 for DVD-Video Processing
Yes
Yes
Yes
· Dolby Headphone
Yes
· HDCD Decoder
Yes
Yes
Yes
· Auto Setup Calibration
Yes
Yes
Yes
· Auto/Manual Room Equalization
Yes
Yes
Yes
· Audyssey MultEq xt Room Eq. with up to eight position setup
Yes
Yes
Yes
· Auto Setup Microphone Included/Type (DM-Sxxx)
Y/Mold (205)
Y/Mold (205)
Y/Alum. (305)
· AL24 Processing - All Channels
AL24+
AL24+
AL24+
· 24-bit/192-kHz DACs - B urr- B rown PCM-1791
2/8ch
2/8ch
2/8ch
· Analog-to-Digital Conversion All Channels - B it Depth/Sampling Rate - PCM-1804
24/192
24/192
24/192
· Variable High/Low Pass Crossover Points (12/24d B ) 40/60/80/100/120/150/200/250
Yes
Yes
F/C/S/S B ind .
· T rue 24-bit/96-kHz Digital Input Capability
Yes
Yes
Yes
· T rue 24-bit/192-kHz Digital Input Capability - Denon Link or IEEE-1394
Yes
Yes
Yes
· Assignable Digital Inputs
Yes
Yes
Yes
· Digital Input - DENON Link 3 rd (PCM/DSD Compatible)
Yes
Yes
Yes
· IEEE-1394 Digital Audio Input/Output
No
Yes
Yes
· Dedicated iPod Terminal and USB Port for Portable Music Players
Yes
· Digital Inputs: Coaxial
2
2
3
· Digital Inputs: Optical
5
5
5
· Digital Outputs: Optical
2
2
3 Incl. Zone 2
· Digital to Analog REC Out
Yes
Yes
Yes
· Analog Audio Inputs, Incl. T uner
11
11
12
· Phono Input
Yes
Yes
Yes
· Source Function Renaming
Yes
· Analog Record Outputs
3
3
4
· Front Panel A/V Inputs w/Cover
* Composite and S-Video
Yes* with Optical
Yes* with Optical
Yes* with Optical
· Video Conversion -Composite to S-Video to Component
Yes
Yes
Yes
· Video Conversion - Composite to S-Video to Composite
Yes
Yes
Yes
· Video Conversion - Analog to HDMI
No
Yes
Yes
· B uilt In Time B ased Correction
Yes
Yes
Yes
· DVI/HDMI Video Inputs - Compatible with 1.1 Spec. - Multi-Channel Audio
2 HDMI
2 HDMI
1 DVI
3 HDMI
· HDMI Repeater Function - Pass Audio onto Display
Yes
Yes
Yes
· HDMI Video Outputs
1
1
1
· Composite Video Outputs
3
4
4
· S-Video Inputs
7
8
8
· S-Video Outputs
3
4
4
· Component Video Inputs x B andwidth - Assignable
3x100
3x100
3x100
· Component Video Outputs - Parallel Main Zone
2
2
2
· Dual Surround Mode Spkr. Selector
Yes
Yes
Yes
· Icon-Based On-Screen Display
Yes
Yes
Yes
· Front Panel System Setup Control
Yes
Yes
Yes
· Personal Memory Plus
Yes
Yes
Yes
· System Setup/Surround Parameters Lockout
Yes
Yes
Yes
· 8-Ch. External Analog Input
Yes
Yes
Yes
· Audio Signal Delay (Sync. Audio with Video signal) - B y source
Yes
Yes
Yes
· Pure Direct/Direct/Stereo Modes on Digital/Analog inputs
Yes
Yes
Yes
· DSD Direct Mode - IEEE-1394 or Denon Link inputs
Yes
Yes
Yes
· Multi-Channel Stereo Mode (No DSP or Delay effects)
5/6/7/9
5/6/7/9
5/6/7/9
· DSP Effect Modes
7
6
6
· Auto Surround Mode (Analog or Digital Input T ype)
Yes
Yes
Yes
· Active Center Channel In All Surround Modes
Yes
Yes
Yes
· B anana Plug Speaker T erminals, All Channels
Yes
Yes
Premium Grade
· Cinema EQ
Yes
Yes
Yes
· 56 Station Auto-Preset Memory Tuning
Yes
Yes
Yes
· Radio Data System (RDS)
Yes
· XM Satellite Radio 'Connect and Play' Ready - with optional antenna
Yes
Yes
Yes
· Direct Function ( T one B ypass)
Yes
Yes
Yes
· Volume Control Un-muting
Yes
Yes
Yes
· Selectable Muting Levels (Full/-40/-20)
Yes
Yes
Yes
· Video Select Control
Yes
Yes
Yes
· RS-232 Port - T hird Party Remote Controllers
Yes
Yes
Yes
· RJ-45 Ethernet Port - Same Functionality as AVR-5805
Yes
Yes
· PC Setup and Control Capability
via Ethernet Port
via RS-232C Port
· IR Serial Remote In/Out terminals
Yes
Yes
Yes
· Remote T urn-on Output (12Volt) - Assignable
2 (25mA)
2 (25mA)
3 (250mA)
· Multi- S ource/Multi- Z one (*Uses REC OU T )
3S/3Z
3S/3Z
3S/3Z
· High Pass Filter for Multi-Zone Outputs
Yes
· Multi-Zone Pre-Amp Outputs - Selectable Output Levels
Zone 3 Fixed
Yes
Yes
· Discrete Multi-Zone Composite and S-Video Output
Zone 2 Only
Zone 2 Only
Zone 2 Only
· Discrete Remote Power On/Off, S ource Selection and V olume for Main and Second/ T hird* Zones
Yes*
Yes*
Yes*
· Discrete Remote Source Selection for Zone 3
Yes
Yes
Yes
· Assignable Amplifiers of Surround B ack (also Center Channel/Surrounds*) for Multi-Zone (Zone 2 or 3) or B i-amping
Yes With Volume
Yes With Volume
Yes* With Volume
· Pre-Amp Outputs
All (8)
All (8)
All (8)
· Microprocessor User Re-set
Yes
Yes
Yes
· Relay-Controlled Protection Circuits
Yes
Yes
Yes
· Detachable Power Cord
Yes
Yes
Yes
· Pre-programmed/Learning EL Remote with B acklighting and Punch T hrough Commands
All New Version
All New Version
Yes
· Weight: In Pounds
TBA
TBA
> 45
· Dimensions (Inches) Width/Height/Depth
17.1
6.7
16.9
17.1
6.7
16.9
17.1
6.9
20.5
Stay tuned for more information and an official review of the AVR-4806.
Discuss These Receivers in Our Forums
[DenonAVR4306receiver] [DenonAVR4306rear]
[DenonRC1024c]
