Leon 5-Way Horizon Surround System
When you're looking for a home theater system to fit a limited space, Leon's innovative 5-Way Horizon Surround Sound System fits the bill. Leon offers a dynamic home theater experience in only 3 custom cabinets: Leon's Horizon Series speaker - the original LCR, combining left, center, and right channels all in one cabinet - and a pair of timbre-matched Surround Sound speakers.
Although Leon's Horizon LCR was "originally intended to mate with a plasma monitor on an attached bracket," in the tight quarters of this Brooklyn apartment, Mark Elson of Home Theater Magazine chose to "make use of the Samsung DLP's top ledge for placement." Designed for maximum performance and high power handling, Leon's home theater system is the ideal solution for "tight settings" - that not only saves space, but also saves money and installation time.
Leon is pleased to introduce its premier custom color match system. As a truly custom shop, they do whatever it takes to provide their customers with the highest quality product. Leon Speakers can not only match the exact dimensions and finish of any Plasma or LCD screen, but can also color match any name brand interior paint, including all colors from Behr, Benjamin Moore, Sherwin Williams, and many more to seamlessly integrate with any décor. All you have to do is tell them a color or send along a color sample, and they can guarantee a perfect match every time.
Beyond aesthetics, they seem to be working tirelessly to make the job of the installer easier. They are designing new mounting options for direct-to-TV installs and meeting strict deadlines with our 3-5 day turnarounds. Their goal is to supply speakers that not only look and sound great, but are also easy to installand retail at around $1500 for either the LCR or the two side speakers.
Leon also showed off some bookshelves with custom cabnets. All were hand finished with burled wood. Leon claims that the solid wood cabinets can be created within 5-7 days after provided with samples of the customer's wood to match.
For more information please visit http://www.leonspeakers.com/ .
