Impact Acoustics RapidRun Modular Cables
Impact Acoustics showed off an entirely new cable system that will likely revolutionize the custom install industry. The RapidRun system features a multi-pin connector at each end of the cable with a pull-cap that allows easy pulling of the cable through conduit. Once the cable is in place, you can unscrew the pull cap and attach the cable to any number of connector pigtails or wall plates, including:
- RGBHV (5 BNC) or 5 RCA
- component video (or YRW - 3 RCA)
- component video with digital audio or stereo analogue audio (5/4 RCA)
- s-video with analogue audio (s-video & 2 RCA)
- HD15 (UXGA)
- component video with s-video (3 RCA & s-video)
- stereo audio and digital coax audio/video (3 RCA)
There are two styles of bundled cable, including a 5 bundle coax for video applications and a bundle for analogue and digital audio. Once you run the cable, it is easy to swap out the pigtails or wall plates by simply unscrewing them and replacing with another. Multiple cables can be run to get the particular results required for an installation. The pull caps can be left on to protect the cable ends until final installation where either the pigtails or wall plates can be attached. Different lengths are available and pricing and availability are listed below.
Might this be the end of on-site soldering and sloppy field connections? We think so.
Base Cable Pricing:
RAPIDRUN UXGA BASE CABLE 15FT 40701 $49.99
- RAPIDRUN UXGA BASE CABLE 25FT 40703 $59.99
- RAPIDRUN UXGA BASE CABLE 35FT 40705 $69.99
- RAPIDRUN UXGA BASE CABLE 50FT 40706 $79.99
- RAPIDRUN UXGA BASE CABLE 75FT 40708 $99.99
- RAPIDRUN UXGA BASE CABLE 100FT 40709 $119.99
- RAPIDRUN UXGA BASE CABLE 125FT 40710 $134.99
- RAPIDRUN UXGA BASE CABLE 150FT 40711 $149.99
RAPIDRUN RGBHV BASE CABLE 15FT 40713 $49.99
- RAPIDRUN RGBHV BASE CABLE 25FT 40715 $59.99
- RAPIDRUN RGBHV BASE CABLE 35FT 40717 $69.99
- RAPIDRUN RGBHV BASE CABLE 50FT 40718 $79.99
- RAPIDRUN RGBHV BASE CABLE 75FT 40720 $99.99
- RAPIDRUN RGBHV BASE CABLE 100FT 40721 $119.99
- RAPIDRUN RGBHV BASE CABLE 125FT 40722 $134.99
- RAPIDRUN RGBHV BASE CABLE 150FT 40723 $149.99
Pigtail & Wall Plate Pricing (pigtail / wall plate) :
RAPIDRUN HD15 40725 $12.99 / 40735 $15.99
- RAPIDRUN 5-BNC 40726 $19.99 40736 $23.99
- RAPIDRUN 5-RCA 40727 $19.99 40737 $23.99
- RAPIDRUN 3-RCA + S-VID 40728 $17.99 40738 $21.99
- RAPIDRUN 4-RCA 40729 $17.99 40739 $21.99
- RAPIDRUN 3-RCA (YRW) 40730 $14.99 40740 $17.99
- RAPIDRUN 3-RCA (RBG) 40731 $14.99 40741 $17.99
- RAPIDRUN 2RCA + S-VIDEO PIGTAIL 40732 $14.99 40742 $17.99
For more information, please visit www.impactacoustics.com.
