Energy Reference Connoisseur RC-70
Filed under: Loudspeakers
The RC-70 is the flagship tower in their Reference Connoisseur lineup. Some of its inherent design qualities that make it Energy include:
- Rigid cabinet construction with ample bracing
- High quality drivers and crossover components
- Well insulated cabinet to reduce resonance and coloration
- Minimized front baffle with all drivers recessed into the cabinet
- Non nonsense build quality through all aspects of the design
- Attractive finishes
Tech Specs:
- Dual 6 ½" Kevlar woofers using Energy's patented ribbed elliptical surround
- Chambered 1" aluminum dome tweeter
- Chambered 5 ½" midrange
- Real wood veneer
MSRP: $2000/pair
- Speaker System: Bass Reflex, Rear Vented
- Recommended Amp Power: up to 250 watts RMS
- Impedance: 8 ohms nominal
- Minimum Impedance: 4 ohms
- Frequency response: 35Hz-23000Hz +/- 3dB
- Usable Bass Response: -10dB Anechoic @ 25Hz
- Anechoic Sensitivity: 91dB
- 2 speakers in a typical room: 94dB
- Crossover Points: 600Hz, 2.4kHz
- Operating Range: Tweeter: 1.5kHz and > , Midrange: 500Hz-3kHz, Woofers 1 and 2:~ to 800Hz
For more information please visit www.energy-speakers.com .
