Denon HTR Series Receivers
by September 09, 2005
Filed under: Receivers & Processors
2005/06 Home Theater Series (HTR) AVR CHART
Similar to the new AVR Series but less custom features such as added multi room sources, the HTR represents their high value line up for folks whose primary focus is on the main zone of audio - the theater room if you will.
Feature/Specification:
AVR
486S
AVR
686S
AVR
786S
AVR
886S
AVR
985S
Availability - August '05
Yes
Yes
Yes
Yes
Current
Suggested Retail Price
$299
$399
$499
$649
$799
Silver Finish Only
Yes
Yes
Yes
Yes
Yes
Equal Power Amplifiers
7ch
7ch
7ch
7ch
7ch
Power Output; Watts Per Channel @ 8 Ohms, 20hz to 20kHz (Watts/channel into 6 Ohms, 1kHz, .7%)
75
(110)
75
(110)
85
(120)
100
(130)
100
(130)
All Channels Rated @ 0.08 THD
Yes
Yes
Yes
Yes
Yes
Low Impedance Drive Capability
Yes
Yes
Yes
Yes
Yes
High-Current/Discrete Amplifiers
Yes
Yes
Yes
Yes
Yes
Independent Power Supplies
Yes
Yes
Yes
Yes
Yes
Pure Audio Construction
Yes
Yes
Yes
Yes
Yes
Front Panel A/B Speaker Selector
Dolby Digital, dts and DSP Modes - Analog Devices
SHARC
Hammer Head SHARC
Hammer Head SHARC
Hammer Head SHARC
Hammer Head SHARC
Processor - Bit Depth and Type
32-bit Floating
32-bit Floating
32-bit Floating
32-bit Floating
32-bit Floating
Dolby Pro Logic IIx - with Cinema, Music, Game Modes
Yes
Yes
Yes
Yes
Yes
Dolby Digital (Surround) EX Decoding
Yes
Yes
Yes
Yes
Yes
dts ES Discrete 6.1 Decoding
Yes
Yes
Yes
Yes
Yes
dts ES Matrix 6.1 Decoding
Yes
Yes
Yes
Yes
Yes
dts Neo:6 Stereo-to-Surround Cinema and Music Modes
Yes
Yes
Yes
Yes
Yes
dts 96/24 5.1 for DVD-Video Processing
Yes
Yes
Yes
Yes
Yes
Auto Setup Calibration
Yes
Yes
Yes
Yes
Auto/Manual Room Equalization
þ
Microphone Included - Molded Plastic Type
Yes
Yes
Yes
Aluminum
24-bit/192-kHz DACs - Analog Devices - All Channels
AD-1837
AD-1837
AD-1837
AD-1837
AD-1835
2/8ch
Analog-to-Digital Conversion - Bit Depth/Sampling Rate
24/96
24/96
24/96
24/96
24/96
Variable High/Low Pass Crossover Points (12/24dB) 40/60/80/100/120/150/200/250
Yes
Yes
Yes
Yes
Yes
True 24-bit/96-kHz Digital Input Capability
Yes
Yes
Yes
Yes
Yes
AVR
486S
AVR
686S
AVR
786S
AVR
886S
AVR
985S
Assignable Digital Inputs
Yes
Yes
Yes
Yes
Yes
Digital Inputs: Coaxial
2
2
2
2
2
Digital Inputs: Optical
1
4
4
4
5
Digital Outputs: Optical
1
1
1
1
Analog Audio Inputs, Incl. Tuner
9
9
9
10
10
Phono Input
Yes
Yes
Yes
Analog Record Outputs
2
2
3
3
3
Front Panel A/V Inputs w/Cover
* Composite and S-Video
Yes
Yes, with Optical
Yes * with Optical
Yes * with Optical
Yes * with Optical
Video Conversion -Composite to S-Video to Component
Yes
Yes
Yes
Yes
Video Conversion - Composite to S-Video and Back
Yes
Yes
Yes
Yes
Composite Video Inputs
4
4
4
5
5
Composite Video Outputs
2
2
2
3
3
S-Video Inputs
3
3
3
5
5
S-Video Outputs
2
2
2
3
3
Component Video Inputs x Bandwidth - *Assignable
3X30
3x100*
3x100*
3x100*
3x100*
Component Video Outputs
1
1
1
1
1
Icon-Based On-Screen Display
Yes
Yes
Yes
Personal Memory Plus
Yes
Yes
Yes
Yes
6-Ch. External Analog Input
Yes
Yes
Yes
Yes
Yes
8-Ch. External Analog Input
Audio Signal Delay (Sync. Audio with Video signal)
Yes
Yes
Yes
Yes
Pure Direct/Direct/Stereo Modes on Digital/Analog inputs
Yes
Yes
Stereo/Direct Modes w/Pure Analog Path
Yes
Yes
Yes
5-Channel Stereo Mode
5/6/7
5/6/7
5/6/7
5/6/7
5/6/7
Video Game Mode
Yes
Yes
Yes
Yes
Yes
Wide Screen 7.1 Mode
Yes
Yes
Yes
Yes
Yes
Mono Movie Surround Mode
Yes
Yes
Yes
Yes
Yes
Rock Arena Surround Mode
Yes
Yes
Yes
Yes
Yes
Matrix Surround Mode
Yes
Yes
Yes
Yes
Yes
Jazz Club Surround Mode
Yes
Yes
Yes
Yes
Yes
Virtual Surround Mode - For 2 Speakers/Headphones
Yes
Yes
Yes
Yes
Yes
Auto Surround Mode (Analog or Digital Input Type)
Yes
Yes
Yes
Yes
Yes
Active Center Channel In All Surround Modes
Yes
Yes
Yes
Yes
Yes
Banana Plug Speaker Terminals, All Channels
Yes
Yes
Yes
Yes
Yes
Cinema EQ
Yes
Yes
Yes
Yes
Yes
AVR
486S
AVR
686S
AVR
786S
AVR
886S
AVR
985S
Front A/B Speaker Selector
Yes
Yes
Yes
Yes
Yes
56 Station Auto-Preset Memory Tuning(FM Only)
Yes
Yes
Yes
Yes
Yes
Direct Function (Tone Bypass)
Yes
Yes
Yes
Yes
Yes
Volume Control Un-muting
Yes
Yes
Yes
Yes
Yes
Video Select Control
Yes
Yes
Yes
Yes
RS-232 Port - Third Party Remote Controllers
Yes
Yes
IR Remote In/Out terminals
Yes
Yes
Yes
Yes
+12v Trigger Output - Assignable
Yes
2
Pre-Amp Outputs
Sub
Sub
All (8)
All (8)
All (8)
Multi- S ource/Multi- Z one (*Uses REC OUT)
1S/2Z
2S/2Z
2S/2Z
2S/2Z
2S/3Z*
Pre-amp Outputs for Multi-Zone
Yes, w/Video
Discrete Remote Power On/Off, Source Selection and Volume for Main and Second/Third* Zones
Yes
Yes
Yes
Assignable Amplifier Configuration of Surround Back Channels, for Multi-Zone amplification
Yes, with Volume
Yes, with Volume
Yes, with Volume
Yes, with Volume
Speaker Time-Delay and Level Controls: L/R, Sub, C, Surr. L/R, Surround Back
Yes
Yes
Yes
Yes
Yes
Relay-Controlled Protection Circuits
Yes
Yes
Yes
Yes
Yes
Detachable Power Cord
Yes
Yes
Yes
Yes
Yes
Pre-programmed (10 Devices) Glow Key Remote Control with Punch Through Commands
Yes
Yes
Yes
Yes
Yes
Pre-programmed/Learning Glow Key Remote with Punch Through Commands
Yes
Weight: In Pounds
21
22.9
25.8
25.8
28.7
Dimensions (Inches) Width/Height/Depth
17.1
5.8
16.4
17.1
5.8
16.4
17.1
5.8
16.4
17.1
6.7
16.4
17.1
6.7
16.4
