Integra New Products
DTR-10.5
A/V Receiver and DPS-10.5 Universal Player
During
our Day-2 coverage of CES, we were pleased to announce
the new line of Integra Research products. Today, we
are equally pleased to inform you of the AWESOME new
line of Integra products. These include the new, mighty
DTR-10.5 “Built-To-Order” THX Ultra2 Home
Theater Receiver and DPS-10.5 THX Ultra Certified Universal
DVD/CD Player. These new models, along with the Integra
Research models, are some of the first Home Theater
products to include an HDMI input and output that includes
Dolby Digital Surround, Dolby Digital EX and DTS-ES
audio. Competitive units we’ve seen during the
show seem to be only offering 2-channel audio output
from the HDMI. Another extremely exciting feature with
these products is that they include BNC video connections
between the Universal Player and Receiver. Note; this
is critical as you can now use a true 75-ohm cable to
hook your DVD player to your receiver and Monitor (provided
your HDTV monitor has BNC). Integra and Integra Research
are one of the few companies we’ve seen at CES
to have this feature!
DTR-10.5
“Built-To-Order” THX Ultra2 Home Theater
Receiver
MSRP $3500 (base)
The DTR-10.5 Receiver is the World’s first card
slot, upgradeable 7.1 channel, “Built-To-Order”
A/V receiver and is based on the same cards as the Integra
Research line. We are also the first to show you what’s
under the hood for these products, as seen in the following
pictures.
DTR-10.5 Amplification
THX Ultra2 Certified 7ch Amplier
• 150-Watts x 7 @ 8-ohm
• WRAT-Wide Range Amplifier Technology
• Linear Optimum Gain Volume Circuitry
DTR-10.5 Processing
THX Surround EX 7.1 Processing
• Dolby Digital EX and Pro Logic IIx
• DTS and DTS-ES, DTS Neo:6, DTS 96/24
• Dolby Headphone and Dolby Virtual Speaker
• Dual 32-Bit DSP Chips for Main and Zone 2
• VLSC-Vector Linear Shaping Circuitry
• Non-Scaling Configuration
• PC Set-up Application available via Ethernet
and RS-232
• Wolfson 192 kHz/24-Bit D/A Converters for
All Channels!
• Composite and S-Video Up-conversion to Component
Video
DTR-10.5 Connections (including optional cards)
High Definition Multimedia Interface (HDMI v1.0) –
2 In/1 Out for HD Video and Dolby Digital/DTS/PCM
Audio over a single cable
• iLink (IEEE-1394 or Firewire) – Digital
Input for DVD-Audio and SACD
• True 75-ohm BNC progressive component input
and output
• Three Zone Multi-room Capability
• Ethernet for Net-Tune Streaming Audio
• Bi-Directional RS-232 Port
• Five Assignable 12-VDC Trigger Outputs
• Independent IR inputs for all 3 zones w/12VDC
for IR receiver
• Speaker A/B for all 7.1 channels
• Bridging and Bi-Wiring Capable for FL/FR using
SBL/SBR
• 13 Digital Inputs
• 4 Digital Outputs
• Color-Coded 7.1 Multi-Channel Inputs
• Hardware and Software Upgradeable for Future
Additions
Integra
DPS-10.5 Universal Player MSRP $2500
The Integra DPS-10.5 THX Ultra Certified Universal Player
which will retail for around $2,500, looks like it’s
going to take the world by storm. This seems to be one
of the only DVD players to offer Dolby Digital output
through HDMI. Not to mention the build quality that
can bee seen from the picture below.
The
robust build and internals of the DPS-10.5 Universal
Player is not just simply for show. A high current torroidal
transformer and robust power supply will ensure that
all circuits perform at their best. The rigid aluminum
chassis, integrated stabilizer network, and solid aluminum
feet contribute to a beefy platform that will reduce
vibration during room-shaking playing.
Integra DPS-10.5 Universal Player General Information
THX Ultra Certified
• DVD-Audio and Super Audio CD Playback
Integra DPS-10 Universal Player Processing
Dolby Digital and DTS Decoder
• Exclusive Dual Direct Digital Path
• VLSC – Vector Linear Shaping Circuitry
• Wolfson 192kHz/24-Bit Audio D/A Converters
• Analog Devices 216 MHz/14-Bit Video DAC
Integra DPS-10 Universal Player Connections
High Quality HDMI Audio and Video Output for HD Video
• iLink (IEEE-1394) Digital Output for DVD-Audio
and SACD
• True 75-Output BNC progressive component output
• RCA Interlaced component output
• Optical and Coaxial Outputs
• S-Video and Composite Outputs
• Parallel Outputs – All Outputs Active
(including both progressive and interlaced component
video.
• 7.1 Multi-channel Analog Outputs
Integra DPS-10 Universal Player Video
OPlus FlexScaling for Upconversion to High Definition
(HD)
• HD Output via HDMI – 720p / 768p / 1080i
• Silicon Image Deinterlacing w/ 3:2 Pulldown
and “Veridic” Progressive Scan
• S-video and Composite Input for Scaling of
External Sources
Integra DPS-10 Miscellaneous Information
Plays DVD-A
Video, SACD, CD/DVD R/RW, JPEG CD,
MP3, VCD
• MP3 Playback with Onscreen Display
• Title/Chapter/Track/Group/Folder/Disc Repeat
• Onscreen Display
• Slow Motion DVD Playback\
• 4-Mode Display Dimmer
• Video Circuit On/Off Control
• Rigid Aluminum Front/Side/Top Panels and Stabilizer
Bar
• Backlit, Preprogrammed
Learning Remote
with Mode-Key LEDs
