Wayne Kerr 6420 Impedance Analyzer & LCR Meter
6420 Precision Impedance Analyzer and LCR Meter: Comprehensive Measurement Functions
The Wayne Kerr 6420 serves as the Audioholics primary test equipment device for measuring and analyzing cables!
Key Features
0.1% Basic Accuracy Up to 10MHz Frequency |
1 Hz Frequency Step Resolution |
Comprehensive measurement functions |
Straight forward intuitive operation Optional DC Voltage and Current Bias |
Graphical sweep mode (impedance mode) |
GPIB,RS-232, Printer Port interfaces |
Comprehensive measurement functions. |
Providing all the well-known measurement parameters: Impedance |Z|, Admittance |Y|, Phase Angle(?), Reactance(X), Conductance(G), Susceptance(B), Inductance(L), Capacitance(C), Quality Factor(Q), Dissipation Factor(D), DC Resistance(DCR). |
Continuous frequency range from 40Hz -10MHz |
Providing a continuous Variable frequency from 40Hz~ 10MHz at 1Hz step resolution, test all components at the desired test frequency, allowing a component to be test at a actual operating frequency. |
Graphical sweep |
Graph the parameter against frequency or AC drive level. Characterize a component graphically, helps the engineer understand how the component perform under different conditions. |
Fast! Accurate! Repeatable! measurements |
Testing components is easy with 6420 Impedance Analyzer. just connect the component and the analyzer accurately measures the component value displaying selected primary and secondary. with a basic accuracy of 0.1%. Connection to the component is made using one of a range of 4 terminal Kelvin connectors. |
Excellent performance !! Frequency up to 10MHz !! |
With excellent performance, 40Hz to 10MHz continuous measurement frequency, 0.1% basic accuracy, comprehensive measurement functions and GPIB, RS-232 and handler interfaces. The 6420 Impedance analyzer provides you total solutation. |
Flexible, full remote control |
Providing control and output capability. The 6420 offers three useful interface as standard. GPIB, RS-232, Handler and Printer Port , Making remote control and printing straightforward. |
6420 Impedance Analyzer & LCR Meter Specifications
(Wayne Kerr Electronics Inc. reserves the right to change specification without notice)
Measurement Parameters
Any of the following parameters can be measured and displayed:
DC Functions |
Resistance (Rdc). |
AC Functions |
Capacitance (C), Inductance (L), Resistance (R), Conductance (G), Susceptance (B), Reactance (X), Dissipation Factor (D), Quality Factor (Q), Impedance (Z), Admittance (Y) and Phase Angle ( q ). |
The following display formats are available:
Series or Parallel Equivalent Circuit |
Series Equivalent Circuit Only |
Parallel Equivalent Circuit Only |
Polar Form |
Test Conditions
AC Drive |
Frequency Range |
Resolution: 5 digits |
Drive Level (AC & DC Measurements)
Open Circuit Voltage |
Short Circuit Current |
Frequency Range |
10mV to 2V rms |
100µA to 20mA rms |
DC to 5MHz |
10mV to 1.2V rms |
100µA to 12mA rms |
5MHz to 10MHz |
Signal source impedance: 100O nominal |
Resolution: 10mV |
AC Measurement Speeds
Four selectable speeds for all measurement functions. Selecting slower measurement speed increases reading resolution and reduces measurement noise by averaging.
The following measurement periods apply for AC measurements ³ 1kHz.
Maximum speed» 80ms |
Fast speed» 150ms |
Medium speed » 450ms |
Slow speed» 600ms |
DC Measurement Speeds
Four selectable speeds for Rdc measurement function. Selecting slower measurement speed increases reading resolution and reduces measurement noise by averaging.
Maximum speed» 30ms |
Fast speed» 60ms |
Medium speed » 120ms |
Slow speed» 900ms |
Display Ranges
R, Z , X |
0.01mO to 1GO |
G, Y, B |
0.001nS to 1S |
L |
0.001uH to > 100kH |
C |
0.001pF to > 1F |
D |
0.00001 to > 1000 |
Q |
0.01 to > 1000 |
Rdc |
0.01mO to > 100MO |
Modes Of Operation
Measurement
Selection of any measurement parameter and test condition. |
Single-level function-menu controlled by keypad and soft keys. |
Single and repetitive measurements displaying major and minor terms. |
Analogue scale with configurable Hi/Lo limits giving PASS/FAIL indication. |
Multi-Step
Measurement parameters and test conditions set using MULTI-STEP SET MODE. |
Up to 30 steps with configurable limits. |
Graph (Optional)
Measurement parameters and test conditions set using GRAPH SET MODE. |
Graphical sweep vs. frequency with selection of start frequency, stop frequency and step size. Linear/log scaling available on all measurement parameters. |
Graph may be directly plotted on a printer or saved to a file over GPIB. |
Measurement Connections
4 front panel BNC connectors with the screens at ground potential. |
Terminals withstand connection of charged capacitor up to 5V, either polarity. |
General
Power Supply
Input Voltage |
115V AC ±10% or 230V AC ±10% (selectable) |
Frequency |
50/60Hz |
VA rating |
150VA max |
Input fuse rating |
115V/230V operation: 3AT |
The input fuse is in the fuse holder drawer integral to the IEC input connector. |
Display
High contrast black and white LCD module 320 x 240 pixels with CPL back lighting. |
Visible area 115 x 86mm. |
Printer Output
Remote Control
Remote Trigger
Rear panel phone jack with internal pull-up, operates on logic low or contact closure.
Mechanical
Height |
150mm (5.9") |
Width |
440mm (17.37") |
Depth |
525mm (20.5") |
Weight |
10kg |
Environmental Conditions
Temperature Range
Storage: -40°C to +70°C.
Operating: 0°C to 40°C.
Normal accuracy: 15°C to 35°C.
Relative Humidity
Altitude
Installation Category
Pollution Degree
Safety
EMC
Pricing:
Model |
Price (USD) |
6420 |
$4,888.00 |
6420A |
$7,388.00 |
6420B |
$9,888.00 |
6420C |
$12,388.00 |
Contact Information:
165L New Boston Street
Woburn , MA 01801
781-938-8390
