Wayne Kerr 4230 LCR Meter
by September 09, 2004
Filed under: Technology
4230 LCR METER
Key Features include:
  • 0.1% basic measurement accuracy
  • 200kHz continuous frequency range
  • Simple straightforward operation
  • Low Cost
  • Comprehensive range of measurement functions
  • RS232, GPIB, and Bin handler interfaces
  • Wide AC drive level
  • Small physical size
Comprehensive measurement functions to suit all requirements
The 4230 LCR Meter measures all the parameters you would normally expect, including Impedance (Z), Series and Parallel Resistance (R), Capacitance (C), Inductance (L), Dissipation Factor (D), Quality Factor (Q), Phase Angel (?), and a few you might not. These include Reactance (X), Conductance (G), Subsceptance (B) and DC Resistance (DCR).
1J4230
4230 LCR Meter supplied with user manual, power cord, and Kelvin lead (AC-6870K1)
Accessories
FX-0000C1
4 terminal component fixture
1EVA40100
Kelvin clips (fine jaw)
1EVA40180
Kelvin clip (large jaw)
1EVA40120
SMD Tweezer
1EV1006
BNC to 4 terminal component fixture
Flexible, full remote control
Providing control and output capability the 4230 LCR Meter offers three useful interfaces as standard, including RS-232, GPIB and Bin Handler, making remote control and printing straightforward.
Fast, accurate repeatable measurements
Testing electronic components is easy with the 4230 LCR Meter. Just connect the component and the LCR meter accurately measures the component value displaying the selected primary and secondary value, with a basic accuracy of 0.1%. Connection to the component is made using one of a range of 4 terminal Kelvin connectors.
Variable Frequency Range from 100Hz - 200kHz
Providing a variable frequency from 100Hz to 200kHz the 4230 LCR Meter can test all components at the desired test frequency, allowing a component to be tested at actual operating frequency.
Unbeatable performance… Unbeatable price
The 4230 LCR Meter provides unbeatable performance, with 200kHz continuous frequency range, 0.1% basic accuracy, comprehensive measurement functions and GPIB, RS232 and Bin Handler as standard. All this performance is provided at an unbeatable price.
Key Specification
Function
4230
Frequency range
100 Hz - 200 kHz in 390 steps
AC test signal level
50mV, 100mV, 250mV, 1Vrms
DC test measurement level
0.5V
DC bias
2 V .
Measurement parameters
Z, R, X, G, B, C, L, D, Q, Ø, DCR
Basic accuracy
0.1%
Interface
GPIB, RS-232, Bin Handler
Size
Height 150mm, Width 320mm, Depth 300mm
Weight
6kg
Order Information:
1J4230
Accessories
FX-0000C1
1EVA40100
1EVA40180
1EVA40120
SMD Tweezer
1EV1006
Pricing:
Model
Price (USD)
4230
$1,499.00
Contact Information:
Wayne Kerr Electronics
165L New Boston Street
Woburn , MA 01801
781-938-8390
www.waynekerrusa.com
