Onix H34 Integrated Tube Amplifier
Introducing the Onix H34 tube integrated amplifier. The same quality, craftsmanship, and performance you've come to expect from Onix, in an all new form. Featuring a 4-RCA input preamp stage with 4 and 8 ohm outputs, the H34 integrated will shock you with it's holographic soundstage, crystal clear resolution, and warm midrange only tubes can deliver.
Exclusive to AV123, the H34 is a perfect match to your Rocket or Reference 2-channel system. With 45 watts of tube amplification (According to AV123, as a general rule of thumb, one "tube-watt" is equivalent to 2-3 solid-state watts), the H34 has the power to drive even the most demanding loudspeaker systems. Take a listen for yourself and see what your solid state system has been missing all these years!
Frequency Response: 18Hz to 30Khz
Power Rating: 45W x 2
Input Impedance: 100K Ohms
Output Impedance: (4 or 8 Ohms)
Input Sensitivity: 300 mV
S/N Ratio: > 90dB / T.H.D - 1%
Dimensions (WxHxD): 19" x 7.5" x 11.5"
Weight: 71 lbs.
Tube Compliment:
- 4 X EL34
- 2 X 6SN7
- 2 X 6922
- 2 X 12AT7
- 2 X 12AX7
Retail Price: $1295
Available now..
Available now for order and don't forget to use "Audioholics5" coupon code during the month of September to receive a 5% instant discount on orders!
