Onix A-60MkII & A-120MkII Integrated Amplifiers
With 120/w/ch @ 8ohms, the A-120MkII will deliver a soundstage that is simply phenomenal - wide yet precise and layered just the way instruments are on the concert stage.
Improvements over the previous generation A-120 includes much better cone control...tighter bass...better definition. Extended highs...more detail and a wider soundstage. Remote volume control (yay!). The CD input and the speaker output terminals are solid
![[a120back2]](../../../audioholics/images/a120back2_th.jpg)
A-120MkII (MSRP: $695)
Dual Mono Integrated Amplifier
Power output: 120W per channel @ 8 ohms and 180W per channel @ 4 ohms
Torodial Transformer: 315VA x 2
THD at rated power: 0.01%
Line input sensitivity: 350mV
Frequency response: ±1dB (20Hz-20kHz)
Signal-to-noise ratio: 105dB (A-wtd)
Function crosstalk (1kHz): -90db
Damping factor: greater than 100
Line Input Sensitivity (mV): 350
Dimensions (WxHxD): 17" x 4.25" x 12.5"
Weight: 32 lbs shipped
Power consumption: 350 watts
For budget minded consumers who demand value and performance, check out the A-60MkII.
Power output: 60W per channel @ 8 ohms and 120W per channel @ 4 ohms
Torodial Transformer: 216VA
THD at rated power: 0.02%
Signal-to-noise ratio: 100dB (A-wtd)
Weight: 27 lbs shipped
Power consumption: 250 watts
Available now for order and don't forget to use "Audioholics5" coupon code during the month of September to receive a 5% instant discount on orders!
