Immersive Simmetry DVP
Filed under: Transports
HDTV Video Processor / DVD Video Player with SACD and DVD-Audio
Specifications:
DVD Player & Audio Specifications
- Plays Audio/Video CDs; DVD-Audio/Video; Super Audio CD; DVD+/-R/RW (conditional); Audio CD-R/RW; MP3 CD-R/RW (128 of higher kbps recommended)
- JPED photo file viewer, Kodak Picture CD and Fujicolor CD compatible
- 24/96 digital output; optical and coaxial
- Built-in Dolby Digital, DTS, DVD-Audio and discrete SACD decoders with 5.1 analog outputs
- Burr-Brown 24-bit, 192kHz DSD-1791 Audio DACs that decode PCM and DSD signals discretely with no down-conversion of DSD
- Rubicon Capacitors for a lower noise floor and audiophile performance
- Full Digital Bass Management for DVD-Audio/Video, featuring Analog Devices Melody 32-bit processor; 80 Hz crossover with 12dB high and 24dB low pass slopes; Adjustable delay time (0-15ms) and channel levels
Video Processing Specifications
- Faroudja DCDi™ Deinterlacing
- 50+ tap scaler that scales HD
- (3) DVI/HDCP Inputs (2 are DVI-I)
- (1) SD Component Input (BNC)
- (1) HD Component Input (BNC) (total of 3 HD component by using 2 DVI-I as analog inputs)
- (2) CVBS
- (1) SVHS
- RS232 Control
- DVI/HDCP and HD15 RGB Outputs
- (7) SPDIF Inputs (2 Out) with 0-300ms in Audio Delay available
- Output Resolutions 720x480, 852x480, 720x576, 800x600, 1024x768, 1280x720, 1280x768, 1280x1024, 1366x768, 1920x540, 1440x720, 1440x960, up to 1400x1050 (others available with field installable firmware)
Dimensions
- H: 6-1/8 "
- W: 17-1/8"
- D: 13-1/8" (center faceplate "bump" to chassis back panel)
- D: 13-13/16" (center faceplate "bump" to end of longest connectors)
- WT: 32 lbs unboxed
- WT: 34 lbs boxed
- Rack mount attachments included
