Denon AVR-5805 Features
Front view of the AVR-5805 Back View of the AVR-5805
Gene, Jeff Talmadge, Tica, and Clint in front of an AVR-5805 integrated into the wall.
Denon AVR-5805 Receiver Features Chart Provided by Jeff Talmadge from Denon USA
*Preliminary - subject to change*
Denon AVR-5805 Feature/Specification |
þ = Yes |
· Expected Release Date |
November 2004 |
· Suggested Retail Price (SRP) |
$6,000 |
· Equal Power Amplifiers - Left/Center/Right/Surround Right 'A'/Surround Right 'B'/Surround Left 'A'/ Surround Left 'B'/Surround Back Right/Surround Back Left/Zone 2 Mono |
10ch |
· Power Output; Watts Per Channel @ 8 Ohms, 20hz to 20kHz |
170 Watts |
· Worlds' First 10 channel Equal Power A/V Receiver, featuring Fully Configurable Amplifiers - Some Options: · Dual 5.1 Discrete Zones (including DVD-A/SACD) · 5.1 Main Zone with all channels Bi-Amplified · 5.1 Main Zone, Zones 2 and 3 Stereo, Zone 4 Mono · 6.1 Main Zone, Zones 2 and 3 Stereo · 7.1 Main Zone, Zone 2 Stereo, Zone 3 Mono · 7.1 Main Zone, Front L/C/R Bi-amplified · 9.1 Main Zone, Zone 2 Mono |
· All Channels Rated @ 0.05 T HD |
· THX Ultra2 -Certified |
· Low Impedance Drive Capability - 3.2 ohms as specified by THX Ultra2 certification |
· High-Current/Discrete Amplifiers |
· Independent Power Supplies |
6 |
· T oroidal Power T ransformer |
· Storage Capacitors for amplifier section |
132,000uF |
· Dynamic Discrete Surround Circuit - D.D.S.C |
ALL NEW |
· Dolby Digital, dts, THX and DSP Modes - Texas Instruments TMS320DA610 |
x3 for Main Zone |
· Dolby Digital, dts and DSP Modes - Analog Devices HammerHead SHARC |
x1 Second Zone |
· DSP Bit Depth and T ype |
32-bit Floating |
· Dolby Pro Logic IIx - with Cinema, Music, Game Modes |
· T HX Post-Processing - DPL (4.0), DPL2 Cinema, DD/D T S (5.1), ES Discrete (6.1), ES Matrix, Neo:6 Cinema |
ALL |
· T HX Ultra2 7.1 Cinema and Music Modes |
· T HX Surround EX Decoding |
· Dolby Digital (Surround) EX Decoding |
· dts ES Discrete 6.1 Decoding |
· dts ES Matrix 6.1 Decoding |
· dts Neo:6 Stereo-to-Surround Cinema and Music Modes |
· dts 96/24 5.1 for DVD-Video Processing |
· Dolby Headphone |
· HDCD Decoder |
· MultEq XT by Audyssey Auto Setup Calibration - New, up to 6 position Multi-Point |
· New Crossover Point Detection/Set per channel in Auto Setup |
· MultEq XT by AudysseyAuto/Manual Room Equalization - New, up to 6 position Multi-Point |
· New Advanced AL24 Processing - All Channels |
· 24-bit/192-kHz DACs - Burr-Brown PCM-1792 - Differential mode configuration |
2 per 16 Channels |
· Analog-to-Digital Conversion - Bit Depth/Sampling Rate - Burr-Brown PCM-1804 x 8 |
24/192 |
· Variable High/Low Pass Crossover Points (12/24dB) 40/60/80/100/120/150/200/250 |
· True 24-bit/192-kHz Digital Input Capability |
· DENON Link 3 rd (SACD Ready) |
· IEEE-1394 Digital Audio Ports |
2 |
· High Resolution Digital Multi-Channel Audio decoding from Denon Link (DVD-A only), IEEE-1394 (DVD-A and SACD), HDMI (DVD-A Only) |
· Assignable Digital Inputs |
· 8-Channel Parallel Digital Input Capability for un-compressed digital signals - For Professional Post-Production, Studio and Authoring facilities |
· Digital Inputs: Coaxial |
6 |
· Digital Inputs: Optical |
6 |
· Digital Outputs: Optical |
3 |
· Analog Audio Inputs, Incl. T uner |
14 |
· Phono Input |
· Analog Record Outputs |
5 |
· Composite Video Inputs |
8 |
· Composite Video Outputs |
5 |
· S-Video Inputs |
7 |
· S-Video Outputs |
5 |
· Front Panel A/V Inputs - Composite and S-Video |
with Optical |
· Component Video Inputs x Bandwidth - Assignable |
6x100 (1 BNC) |
· Component Video Outputs - Parallel for Main , Second Zone Discrete Source Capable |
2 (1 BNC) Main Zone 1 Second Zone |
· Video Conversion -Composite to S-Video to Component and down (Interlace only) |
Main and Second Zone |
· TBC (Time Based Corrector) for Composite and S-Video Sources |
· DVI/HDMI Video Inputs - HDMI features SiL9031 Multi-Channel Audio Receiver Chipset |
1/3 |
· DVI/HDMI Video Outputs |
1/1 |
· Permits DVI video signal input to HDMI video output and vice versa |
· Faroudja DCDi Scaling (480p/720p/1080i) to Component Output - Main Zone Only |
· Discrete Dual Surround Mode Speakers |
· Icon-Based On-Screen Display - Independent/Discrete for Main and Second Zone |
· Front Panel System Setup Control |
· Personal Memory Plus |
· System Setup/Surround Parameters Lockout |
· 6-Ch. External Analog Input - Main or Second Zone |
· 10-Ch. External Analog Input - Main Zone |
· Audio Signal Delay (Sync. Audio with Video signal) - Independent Main and Second Zone, Adjustable to individual input sources |
· Pure Direct/Direct/Stereo Modes on Digital/Analog inputs w/Pure Analog Path |
· Multi-Channel Stereo Mode (No DSP or Delay effects) |
5/6/7/8/9 Channel |
· Video Game Mode |
· Wide Screen 7.1 Mode |
· Mono Movie Surround Mode |
· Rock Arena Surround Mode |
· Jazz Club Surround Mode |
· Matrix Surround Mode |
· Auto Surround Mode (Analog or Digital Input T ype) |
· Active Center Channel In All Surround Modes |
· High Grade Speaker T erminals, All Channels |
· Cinema EQ |
· 56 Station Auto-Preset Memory Tuning |
· Radio Data Services (RDS) Compatible |
· Tuner Station Labeling |
· Volume Control Un-muting |
· Selectable Muting Levels (Full/-40/-20) |
· Video Select Control |
· Input Labeling |
· Audio Input Level Memory - User Defined |
· Multi-Zone Volume Level Limiter - User Defined |
· Power On Volume Level Memory - User Defined |
· Digital input signals to Analog conversion for Multi-zone applications |
· RS-232 Ports - 1 Rear for Controllers, 1 Front for PC Setup |
· Ethernet Port - For control and/or upgrades |
· Dedicated Front Panel Port for future DSP Upgrades |
· IR Serial Remote In/Out terminals |
· Assignable Remote T urn-on Triggers - 12Volt, 250mA |
4 |
· Assignable AC Outlet Triggers |
3 |
· Pre-Amp Outputs |
10 |
· Subwoofer Pre-Amp Outputs |
3 |
· Multi-Source/Multi-Zone |
4 Source/4 Zone Audio3 Source/3 Zone Video |
· Multi-Zone Crossover (Fixed 80Hz), Tone and Balance Controls |
· Multi-Zone Pre-Amp Outputs - Selectable Output Levels |
· Discrete Second Zone Video Outputs |
Composite, S-Video, Component |
· Discrete Third Zone Video Outputs |
Composite, S-Video |
· Discrete Remote Power On/Off/ S ource Select/ V olume for Main and Zones 2/3/4 |
· Detachable Digital and Video Block Construction for future upgrades |
· Microprocessor User Re-set |
· Relay-Controlled Protection Circuits |
· Detachable Power Cord |
· Subwoofer Peak-Level Limiter |
· Advanced Pre-programmed/Learning EL Remote with Backlighting and Punch T hrough Commands |
· AC Line Amperage Requirement |
20amp |
· Weight: In Pounds |
90 est. |
· Dimensions (Inches) Width/Height/Depth |
17.1"w x 12"h x 20.5"d |
Whew! That's a lot to read, but in conjunction with our processor/receiver checklist it should serve to demonstrate that the Denon AVR-5805 is about the most feature-packed receiver available... Now if only the furniture companies would capitulate with our request for support of 13" tall shelves!
