Da-Lite Multi-Mask Imager
Da-Lite Screen Company, Inc., introduced the latest addition to its line of masking systems, the Multi-Mask Imager. The Multi-Mask Imager is a fixed frame screen that features both horizontal and vertical masking and is available with a choice of all eleven of their projection screen surfaces. With all masking retracted, the screen is a 16 x 9 HDTV (1.78:1) aspect ratio. With masking, you can achieve 4 x 3 NTSC Video (1.33:1), Letterbox (1.85:1) and Cinemascope (2.35:1) formats. Da-Lite's Multi-Mask Imager is standard with the Pro-Trim finish, which is a fabric frame covering that aesthetically enhances the appearance of the installation while absorbing light that surrounds the viewing area.
Pricing is $6,342 for a 92" diagonal screen.
