2004 Denon DVD Player Comparison Chart
by September 09, 2004
Filed under: Transports
[denon1815]
A fleet of Denon's Newest DVD Players with the DVM-1815 Changer pictured on the right
[3910back] [denon3910front]
The backview of the new Denon DVD-3910 Front View of the DVD-3910 (Silver Chassis)
The DVD-3910 supports i.Link, Denon's own Dlink Ver3, HDMI and DVI-D.It even has separate DAC's and RCA outputs for downmixing 5.1 music sources to two channels to be used in another room! According to Denon Jeff, the DVD-3910 has the exact same audio and video stages as the DVD-5900 but with a slightly scaled down power supply. This player will serve as a replacement to the DVD-5900 for the time being.
This chart compares the latest DVD Players from Denon and allows you to take a look at the features and specifications to see which one fits your needs and budget.
Feature/Specification: þ = Yes
DVD 1710
DVM 1815
DVD 1910
DVM 2815
DVD
> 2910
DVD
> 3910
· Expected Release
Now
Now
Now
Now
Sept. '04
Now
· MAP/SRP
$169
$329
$269
$469
$679
$1299
· Silver Availability
X
X
· DVD-Video
X
X
X
X
X
· DVD-Audio
X
X
X
· Super Audio CD
X
X
· THX Ultra Certified
· Music/Video CD/CD-R/CD-RW Playback
X
X
X
X
X
X
· DVD-R/RW Video - Conditional
X
X
X
X
X
X
· DVD+R/RW Video - Conditional
X
X
X
X
X
X
· Kodak Picture CD Compatible
X
X
X
X
X
X
· Fujifilm Fujicolor CD Compatible
X
X
X
X
· JPEG Photo-File Viewer
X
X
X
X
X
X
· WMA9 Playback
X
X
X
X
X
X
· Single Disc Play
X
X
X
X
· Multi-Disc Play
5
5
· Progressive Scan
X
· DCDi ™ by Faroudja Progressive Scan Decoding Engine
FLi2200
FLi2301
FLi2200
FLi2310
FLi2310
· True Progressive Scan, featuring Enhanced Genesis Decoding Engine
· Noise Shaped Video ™- Interlace and Progressive
X
X
· 3:2 Pull down Detection
X
X
X
X
X
X
· Chroma Upsampling Error - 'Chroma Bug'
NO
NO
NO
NO
NO
NO
· 10-bit, 27MHz Analog Devices Video DAC (480i)
X
X
· 10-bit, 54Mhz Video DAC (480p)
X
X
· 10-bit, 54MHz Video DAC (480i/480p)
X
Dual, Discrete
· Dual, Discrete 12-bit, 216MHz Analog Devices Video DACs (480i/480p)
X
X
· Super Sub Alias Digital Filter
X
X
X
X
X
X
· Buffer Memory to decrease Layer change
2MB
2MB
2MB
2MB
8MB
8MB
· Multi-speed DVD-ROM Drive - 2X for DVD, 4X for CD
1.5x/4x
1.5x/4x
1.5x/4x
1.5x/4x
X
X
· Digital Bass Management for DVD-Audio/MLP/SACD, High (12dB) and Low Pass (24dB) with Speaker Configuration/Level Control and Delay T ime Control
· *Crossover Slopes: DVD-A/V, 12dB High and 24dB Low - SACD, 6dB/12dB
80Hz
DVD-A Only
80Hz*
No Delay Control for SACD
Selectable 40/60/80/
100/120
· Burr-Brown 24/192 Audio DACs
PCM-1756
PCM-1756
PCM-1791
PCM-1796
· Burr-Brown 24/192 FL/FR, 24/96 C/SL/SR/Sub
X
X
· HDCD Decoder
X
X
· Built-In Dolby Digital, dts, DVD-Audio, SACD* Decoders with 5.1 outputs
X
X *
X *
· WMA 9 (Audio only), MP3 Audio Decoder for CD-R/RW, DVD-R/RW Discs
X
WMA8
X
WM8
X
X
· Mosquito, 3D, Block, Noise Reduction Adjustments
· Picture Mode Adjustments
X
· 4:3 Aspect Ratio Shrink and Zoom Adjustments for 480p
Zoom
Zoom
Zoom
Zoom
Zoom
X
· Pure Direct Modes (User Selectable - Video/Digital/Display Off)
X
X
· Composite Video Output
X
X
X
X
X
X
· S-Video Output
X
X
X
X
X
X
· Component Video Output
X
X
X
X
X
X
· Coaxial and Optical Digital Outputs
X
X
X
X
X
X
· Parallel Digital/Analog Audio Outputs
X
X
X
X
X
X
· Parallel Video Outputs
X
X
X
X
· IEEE-1394 Audio Outputs (PCM/DSD compatible)
X
· T rue 24-bit/96kHz Digital PCM 2-Ch. Output
*24/192 on DLink, IEEE-1394
X
X
X
X
X
X *
· DENON Link 3 rd Edition - Proprietary digital, fully balanced output of DD/dts/DVD-Audio/PCM/SACD *
X
· DVI-D (HDCP Compatible) - With Selectable Scaling - 480p/720p/1080i
X
X
X
· HDMI (HDCP Compatible - SiL9030) - With Selectable Scaling - 480p/720p/1080i
Multi
> Channel
Multi
> Channel
· Black Level Adjustment
X
X
X
X
X
X
· Passes Below Black for Monitor Calibration
X
X
X
X
X
X
· Discrete Power On/Off
X
X
X
X
X
X
· RS-232C Port for Third Party Controllers
X
· Remote I/O Ports
X
X
X
X
X
· Auto-Power Off
X
X
X
X
X
Selectable
· On-screen Display
X
X
X
X
X
X
· Disc Exchange during Play
X
X
· Virtual Surround Sound
X
X
X
X
SRS
SRS
· Lock Drawer Mode (Store Demo)
X
X
X
X
X
X
· Weight (Pounds)
4.8
9.5
5.3
9.5
11
18.7
· Width
· Height
· Depth
17.1
3
8.3
17.1
3
14.4
17.1
3.2
9.7
17.1
5.2
13
17.1
4
12.5
17.1
5.2
13
*Denon is anticipating the approval for transmission of Super Audio CD through the DENON Link by the time these products are delivered to market . however, Should the approval not come, these units will have DENON Link SE, but will be upgradeable to 3 rd edition when formal approval is granted.
