GoldenEar Triton Seven Tower Speakers Review
by May 16, 2016
GoldenEar Triton Seven HVFR Tweeter
  • Product Name: Triton Seven Tower
  • Manufacturer: GoldenEar
  • Review Date: May 16, 2016 01:00
  • MSRP: $ 1400/pair
  • Tweeter: One - HVFR™ High-Velocity Folded Ribbon Tweeter
  • Mid/Bass: Two - 5-1/4˝ High-Definition Cast-Basket Drivers
  • Passive Radiator: Two - 8˝ Planar
  • Width: 5-3/4˝ (front), 7-1/4˝ W (rear), 10-1/2" (base)
  • Depth:11˝ (tower), 14-1/2" (base)
  • Height: 39-3/4˝
  • Weight: 32 lbs (product) / 42 lbs (shipping)
  • Frequency Response: 29 Hz - 35 kHz (manufacturer ratd)
  • Efficiency: 89 dB
  • Nominal Impedance: Compatible with 8 ohms
  • Spacious sound that casts a huge image and makes them easy to place
  • Smooth, non-fatiguing response across the frequency range
  • Looks can be love it or hate it depending on who you talk to.
GoldenEar Triton Seven Introduction
The GoldenEar Triton Seven speakers are the least expensive tower they offer at about $700 each ($1,400 for a pair).  GoldenEar has gained a lot of buzz in audiophile circles for offering audio quality that rivals many much more expensive speakers.  Additionally, they produce truly flagship speakers like the large Triton One which features a large powered bass section.  Because we have a soft spot for the audiophile “gateway drugs”, we wanted to see what GoldenEar could offer folks on a tight budget, and how much of that Triton One tech might have trickled down to the Triton Seven.
One thing that the Triton Seven have in common with the other GoldenEar models is the tweeter which is a folded ribbon tweeter that GoldenEar calls the HVFR or High Velocity Folded Ribbon.  This is the exact same tweeter featured in all of their tower models, all the way up to the flagship Triton One.  The tweeter is flanked on the top and bottom by a 5.25” cast basket woofer.  Cast baskets are usually a sign of great build quality as they are more rigid, and thus, can handle high dynamic drivers better than most stamped baskets.  There are no powered drivers in the Triton Seven, but on either side of the speaker enclosure is an 8” Planar Sub-Bass Radiator and no other ports, which make the tower a quasi-ported design.  The full driver compliment is rated by GoldenEar to reproduce a range from 29 Hz - 35 kHz (no tolerance given).
These drivers are hidden behind a sock of speaker cloth that wraps the entire enclosure and is gathers with a drawstring below the glossy black, plastic top cap and anchored at the bottom by a non-removable glossy black, wooden base emblazoned with the GoldenEar logo.  The base is threaded on the bottom for use with the included spikes or rubber feet.  The speaker cloth can be removed with some effort, but it’s not designed to be used that way.  The enclosure under the cloth is not finished in a way that is aesthetically perfect, so you’ll just want to leave the cloth on.
Triton Seven Grill Cloth
The Triton Seven Grill Cloth
Beauty in the Eye of the Beholder?
The appearance and aesthetics of the Triton 7 is a divisive conversation.  The shape of the speaker is a 40” tall, narrow column that is slightly wider at the back than the front with slightly curved edges.  The design is decidedly minimalist, which some folks like and others don’t.  Personally, I like the fact that they disappear into a dark room with few reflective surfaces, which makes them perfect for home theater.
Looking for second opinions, I showed them off to some visitors.  I was told they look like “skyscrapers”, which is a good thing if you have a modern decorating scheme, but a bad thing if your home is finished in something more traditional.  One thing is for sure, all GoldenEar speakers have an appearance that is uniquely their own and won’t be mistaken as anything other than GoldenEar Speakers.  From a functionality standpoint, the finish choices are polished, yet economical, no doubt allowing GoldenEar to deliver sound that punches above their price point by focusing investment in the sound-producing materials.
GoldenEar Triton 7 Listening and Conclusion
GoldenEar Triton 7 hero shotFor listening, I drove the GoldenEar Triton Seven with my standard Onkyo TX-SR706 THX Select rated AVR, and the more modest, but fantastically versatile, RBH BT-100 which is a 2 x 25 watt Class D bluetooth amp.  I listened in smaller, closed rooms similar to a bedroom or office, and a larger, open family room.
The Triton Seven worked well in all these environments, but worked really well in the smaller room due to the tonal character I heard.  If I were asked to describe the sound of the Triton Seven in two words it would be “spacious” and “smooth”.  In both rooms, the Triton Seven cast a huge, spacious image.  This was especially apparent in the small room where narrow spacing, and close walls can make a system sound small and constrained.  That was not the case with the GoldenEar Triton Seven.  The stereo image extended far to either side of the speakers, and created a wall of sound that filled the front of the room and beyond.
That spacious sound was especially apparent on my go to track, My Brightest Diamond’s “Be Brave.”  Through the Triton Seven, the placement of woodwinds and strings trading riffs before the bridge unfold in a wide soundscape that sounded so much bigger than these slender speakers in a small room should.
 My Brightest Diamond - ALL THINGS WILL UNWIND: Be Brave
Of course, in that same track, the smooth sound of the Triton Seven all render the delicate bells with a natural decay, clear harmonics, and appropriate air, but without a hint of harshness, no doubt due in large part to the HVFR tweeter.  Ribbon tweeters are know for limiting high-frequency breakup above 10kHz, which can be common with dome tweeters.  As a result, all GoldenEar speakers feature a clear and clean high-frequency reproduction.
That natural sound reproduction extends to the low end of the frequency spectrum as well.  While the Triton Seven will lose in a low-end tug-o-war to the larger Tritons with powered bass sections, the fully passive Triton Seven feature a robust mid-bass reproduction before rolling at the lowest bass frequencies.  In Bjork’s “Hyberballad”, there’s a repeating bass line that is essentially three heavy synth bass notes.  Through the Triton Seven, these notes were all present and resonant, and while the track would have benefited from the addition of subwoofer like the GoldenEar ForceField series, I found the Triton Seven alone perfectly acceptable for bass-heavy styles of music, as long as you temper your expectations from these slender speakers.
 The Hunger Games: Mockingjay Part 2 Official Trailer – “We March Together”
Two words to describe the sound of the Triton Seven are "spacious" and "smooth".
The same held true for movies.  While the dialogue in the Hunger Games: Mockingjay Part 2 was clearly reproduced by the articulate mid woofers and accurate tweeter, and the snap of artillery fire in action scenes was dynamic yet non-fatiguing, the modestly sized towers were adequate, but not visceral in the low frequencies.  All of this is well within expectations given their size and price point.
GoldenEar Triton 7 TerminalsThe Triton Seven tower speakers represent a low barrier of entry to the highly praised GoldenEar sound.  They offer a remarkably spacious stereo reproduction, and smooth frequency response.  Their low-frequency reproduction is understated, but far from anemic, and the Triton Seven make for a terrific 2.0 system in smaller rooms.  While their looks may not be everyone’s cup of tea, it’s tough to argue with the performance for the price, assuming the landscape of the modest priced tower doesn’t change too much in the coming year.
Do you own any GoldenEar speakers?  If so, please share your experiences in our related forum thread below.
  • StarStarStar — Good
  • StarStar — Fair
  • Star — Poor
MetricRating
Build QualityStarStarStarStar
AppearanceStarStarStar
Treble ExtensionStarStarStarStar
Treble SmoothnessStarStarStarStar
Midrange AccuracyStarStarStarStar
Bass ExtensionStarStarStar
Bass AccuracyStarStarStarStar
ImagingStarStarStarStar
SoundstageStarStarStarStarStar
Dynamic RangeStarStarStarStar
ValueStarStarStarStar
Marshall is an Educator by trade, and currently lives in Oregon. He was lucky enough to grow up in a musical household, and though the AV equipment wasn't the greatest, it was always on. His dad introduced him to Queen, Paul Simon, and Sgt. Pepper's, and his mom played Lionel Richie and Disney Soundtracks. When Marshall was 14, his uncle passed down a pair of JBL towers and Marshall finally had his own system. Having enjoyed podcasting and video production over the past 10 years, Marshall is happy to be contributing at Audioholics.
