The Speaker Company T300 Subwoofer Review
- Product Name: T300
- Manufacturer: The Speaker Company
- Performance Rating:
- Value Rating:
- Review Date: June 11, 2009 15:05
- MSRP: $ 379.97
Type: 10" Powered Subwoofer (x2)
Woofer(s): Two 10” (25.4cm), side firing
Cone Material: Aluminum
Driver Surround: Rubber
Port: Front Slot
Power Modes: On / Off / Auto Sensing / Standby
Inputs: Speaker Level, 2ch RCA, LFE RCA
Amplifier Type: BASH - Class D
Dynamic Power: 1200 Watts
Peak Power: 600 Watts
RMS Power: 300 Watts
Frequency Response: 19 -150Hz +/- 3dB
Crossover Frequency: Variable Low Pass Filter 50Hz-150Hz @ 18dB/oct
Width Height Depth: W14 1/2” H15 1/4” D18 1/2"
Weight per speaker: 36 lbs
Finish: Black
- Price
- Bang up performance for smaller rooms
- Disappears in a darkened room
- Great build quality
- Chuffing/Port noise at higher volumes
- Not suited for larger rooms
tSc T300 Build Quality
I don't know how I became the budget gear reviewer here at Audioholics but I'm glad I am. Trying to tell the differences between a $7000 sub and a $9000 sub is a lot harder than between a $300 and $500 one. Honestly, though, even that's getting harder as more companies are offering great deals at unbelievable prices. The Speaker Company (tSc) has already shown us that they can do just that. At under $400, a sub that does most anything is a great deal. From what I've learned of The Speaker Company, the T300 will probably do much more. Gene Della Sala (Audioholics President) has already sung the praises of the budget ASW-8 tSc sub so I really was excited with the T300 showed up for review.
Build Quality
The tSc T300 sub arrived
double boxed and well packed. In full retro fashion, they even had packing
peanuts. The interior box was branded and marked but the exterior was plain. I
prefer this as it doesn't give away to the shipping company (who may decide to
leave the box on your doorstep) any indication of what is in the box. It was marked with "Fragile,"
"This End Up," and "Caution, Heavy" stickers (not that I
think they pay those the least bit attention). Regardless, the sub arrived
undamaged by shipping and ready for battle.
The T300 isn't especially large (a plus for placement and moving around). It is only 14 1/2” wide and 18 1/2" deep. The depth is really the only dimension that should give consumers pause. As always, when buying a subwoofer online, construct a box out of cardboard of the same dimensions and make sure it will fit your space. The T300 features a flat black, slightly textured finish and rounded corners. The stock picture on the website shows a seam on the front but the review unit did not - the front face was smooth. There are two side firing (one from each side) woofers and a front firing slotted port. The bottom has pre-attached rubber feet which are fairly short. There are no provisions for carpet spikes.
The
T300 weighs in at a paltry 36lbs. While this isn't the lightest sub you're
going to come across, it does make it very easy to move around. There are two
side-firing 10" aluminum drivers, a front slot-style port, and a rear
mounted amp. The grills are actually mounted through four of the holes that
would be used for mounting the drivers. This leaves four (instead of eight)
connection points for the driver to the enclosure. My first concern was that
those holes might be predrilled and allow extra avenues of escape for air other
than the front port. I did multiple tests during playback and found no evidence
that any air was escaping any of the holes.
The grills fit snuggly but not tightly. This means that they won't be falling off on their own but they also won't resist the prying of curious little fingers. The front slotted port is wide but unobtrusive. In fact, if I had to describe the T300 in a word, I'd say it was unobtrusive. The flat black blends well with the shadows and the overall look doesn't exactly draw the eye. It does pick up fingerprints fairly easily but they aren't easy to see in a darkened room. The driverless front of the T300 should get most the credit. However for those that like to see their subwoofer work during those intense action scenes, you'll have to turn the sub or just make due with what you can see of the rubber surrounds moving.
The amp sports 300 watt Bash Class D amplifier and all the usual
connections and controls. Variable volume and crossover control (50-150Hz) are
present. Phase switch (0-180 degrees), stereo RCA and LFE inputs and high level
inputs also there. One thing I wasn't expecting was not only a Standby/Off
switch but also an On setting for those (like me) that don't trust auto-sensing
functions.
The only fit and finish issue I found was a bit of a crack along the bottom of the box. It was right along the edge along the side at the bottom. While this particular imperfection was invisible to the owner, it might indicate a systemic problem. New owners should be aware and check out their new purchase thoroughly. With free return shipping and a 30 day trial, this shouldn't deter any potential buyers.
Opening up The T300, we see two drivers in a 3/4" MDF enclosure. The drivers sport stamped rather than cast baskets which is probably not unreasonable considering the price. The drivers also aren't magnetically shielded so you'll need to keep the sub away from any legacy CRTs or other magnetically sensitive equipment. The cabinet has modest stuffing and only a minimal reinforcement at the corners. One thing I was really impressed to see was total dampening of the internal wiring. Each wire was covered with foam tape so that any possible internal noise would be eliminated. A really nice touch at this price point.
Setup
Setting up the T300 was just as easy as you'd think. All I did was connect my Impact Acoustics SonicWave Subwoofer Interconnect from my Denon AVR-2307CI to the sub. I did listening tests with both the Velodyne SMS-1 engaged and not. The T300 was set atop an Auralex SubDude isolation platform. My room is fairly small but open to the rest of the house. On top of that, I have a number of DIY acoustic absorption panels and six GiK Tri-Traps. The room has been acoustically analyzed and tuned by Auralex through the Room Analysis Plus service. Together, this makes for a room that looks a lot bigger to a sub than it really is. For all intents and purposes, I have a large room.
T300 Measurements and Conclusion
For laboratory measurements I used the Sencore SP395A FFT Audio Analyzer. Placing the subwoofer outside, I did groundplane measurements at 1 meter. During the test, when pushed hard I noticed some chuffing from the port and a bit of rattling from the amp.
Listening Tests
My first step was to
send a few test tones with the Rives
Test CD II. The Speaker Company claims a usable frequency response down to
19Hz. That's got a lot of bass heads real excited - especially at this price
point. Using my Radio Shack SPL meter placed on a stand at my listening
position, I measured 81dB at 1kHz. Yes I know the sub isn't playing at 1kHz but
I wanted to get a relative measure of loudness in my room with my other
speakers. This told me that if the T300 was really giving good output down to
19Hz, I should be able to measure something close to that dB level with a lower
test tone. When I bumped the Radio Shack corrected tones down to 20Hz and even
25Hz, I got about 76-78dB. Not bad until you consider that it was all port
noise and chuffing. It wasn't until the 31.5Hz tone that I got clean output.
Now, as I said, my room is heavily treated and is therefore much larger to a
sub than the dimensions would suggest. In a smaller room, the 19Hz claim might
be valid but in mine, I probably wasn't seeing much usable output under 30Hz.
DVD: Star
Wars Episode 2: Attack of the ClonesThere is nary an
Audioholics without a mental (sometimes physical) list of their favorite bass
scenes. One of my personal favorites (mostly because it gives so many
subwoofers problems) is the flyover scene at the beginning of Episode 2. Sure
the acting and questionable and the direction… well, I've beaten that dead
horse enough. The T300 did a good job holding up to this demanding scene. At
medium volumes the sub sounded very linear and deep. While it didn't have
nearly the visceral impact of my reference Axiom EP500, it hit fairly deep and
linearly. When pushed, I could hear a bit of strain and compression during the
loudest/deepest portions but overall it held up well.
DVD: Dark
Knight
I love it when a movie
like this comes out - great action flick with lots of reference material. The
most recent in the "Christian Bale does it better" line of sequels delivers
with a gritty flick and arguably Heath Ledger's greatest performance. This
particular movie I watched at "wife reference" level. This equates to
as loud as I can turn it without having the wife come out and yell at me for
waking her up. You'd probably call it "almost loud enough." At this
volume, the T300 real shone with tons of extension and impact. It blended well
with the rest of the system and was forceful when it needed but not
overpowering when it wasn't. Honestly, about half way through the movie the
thought occurred to me that I might consider switching out the EP500 for it.
While it didn't have the chest-thumping ability of the larger sub, its smaller
size and ease of moving it around seemed to be a good tradeoff. Or so I
thought.
Blu-ray: SerenityDuring the review of the
T300 my AV Rant home theater podcast sponsored PS3 arrived. I
thought about holding out on my first Blu-ray purchase for something meaningful
(like the extended versions of Lord of the Rings) but when I saw Serenity on
sale for $16.99, I couldn't resist. DTS Master Audio didn't hurt either. With the
wife and kids out of the house and my system cranked, I settled in for a wild
ride. Well, the T300 provided a few bumps right away. At the beginning of the
movie there are a few really low notes that had the sub chuffing and clanging
like a train. I'm pretty sure I bottomed out both the woofers. I tried
recalibrating my system and even defeating the Velodyne SMS-1, but nothing
helped. Nothing except lowering the
volume. The T300 had clearly met its match - at least in my room. In a smaller
(or at least enclosed) room, you're probably not going to run into these
problems and honestly, for 90% of my listening I didn't either. But throughout
the movie I could hear the sub straining and compressing even at lower volumes.
Don't get me wrong, the T300 seems to be a great little sub, but it just isn't
going to be able to fill up a large room by itself. Of course, at this price
you could get two or four…
For a comparison, I decided the hook up my Axiom EP500 to see how much better a sub at 3x's the price could do. I was a bit surprised to find that I could also hear the EP500 strain a bit with this passage. This was only at the loudest volumes and even then the rattling of the dishes in the kitchen and pictures in the hallway nearly completely covered it up. Suddenly, this piece has become my new subwoofer killer.
My experience with the T300 was pretty well bourn out through all my listening tests. With music, in particular, the sub was great… as long as I didn't turn the volume up too much. As soon as I did, the output would compress and start to sound flat and boomy. At normal listening volumes, the sub was musical and performed very well. It just couldn't take the lowest or the loudest. What is obviously in need here is a subsonic filter. This feature, often bemoaned by bassheads, essentially limits the lowest output of a subwoofer to protect it from bottoming out or distorting. In my opinion, it is better to have a sub that only hits down to 25Hz but does so cleanly rather than a sub that tries for 15Hz with nothing but distortion or port noise below 25Hz.
Given my previous experience with tSc, I probably had unrealistically high expectations for the T300. For the price, it has really impressed me. Usually, with an online retailer, a well performing sub is either huge in size or huge in price. The T300 manages to pack a lot of performance in a very small box. I'd like to report that the T300 passed all my tests with flying colors… but it didn't. For a smaller to perhaps medium sized room, the T300 is too good of a deal to pass up. For larger rooms, you're going to need a bit more, perhaps two or four T300s. The 19Hz extension claim, while possible when in the right room at low SPL levels, probably won't be realized for users in larger rooms. At this price point, you're going to have to expect some tradeoffs. But if the tradeoff is, "don't put it in a huge room," you're getting a great bang for your buck. The Speaker Company has another great deal on their hands, for the right buyer.
tSc T300 Subwoofer
$379.97
The Speaker Company
100 Corporate Drive
Mahwah, NJ
07430
www.thespeakercompany.com
About tSc
We offer quality speakers and speaker systems at discount prices. From
towers, satellite speakers, in-walls, bookshelves and surround systems as well
as headphones and iPod Docking stations The Speaker Company offers a full line
of speakers & accessories.
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Bass Extension | ![]() ![]() ![]() ![]() |
Bass Accuracy | ![]() ![]() ![]() ![]() |
Fit and Finish | ![]() ![]() ![]() |
Ergonomics & Usability | ![]() ![]() ![]() ![]() |
Features | ![]() ![]() ![]() ![]() |
Value | ![]() ![]() ![]() ![]() |
