Yamaha SRT-1000 Pedestal Soundbar Preview
The Yamaha SRT-1000 pedestal soundbar.
  • Product Name: SRT-1000
  • Manufacturer: Yamaha
  • Review Date: September 26, 2014 05:00
  • MSRP: $499.95
  • Output Channel: 5.1-channel
  • Output Power: 136 W total power: 2 W x 8 beam drivers + 60 W (30 W x 2) woofer + 60 W (30 W x 2) subwoofer
  • Beam Drivers: 1-1/8” x 8 beam drivers
  • Woofers: Dual 1-1/2” × 4” woofers
  • Subwoofer: Dual 3-1/4” subwoofers
  • Digital Optical: 2 in
  • Digital Coaxial: 1 in
  • Analog Audio: 1 in
  • Subwoofer Output: 1 out
  • UniVolume: Yes
  • Clear Voice: Yes
  • Dolby Digital: Yes
  • DTS: Yes
  • Wireless Music Streaming: Yes (with Bluetooth)
  • Bluetooth Version/Profile: (Version) Ver. 2.1 + EDR (Profile) A2DP (Audio Codec) SBC, AptX®
  • App Control: Yes
  • Learning Function: Yes
  • Power Consumption: 24 W
  • Standby Power Consumption: 0.2 W (Bluetooth standby off)
  • Dimensions (W x H x D): 30-3/4” x 3” x 14-5/8”
  • Weight: 19.4 lbs.
We understand that not everyone has the space or desire for a surround sound system. Dealing with five speakers plus a subwoofer, an A/V receiver, not to mention a mess of wiring can be a daunting task. But what happens if you’d like an audio experience a few notches beyond what your TV speakers can provide? Yamaha’s new SRT-1000 pedestal soundbar might worth a look. Priced at $499.95, the SRT-1000 is built around Yamaha’s digital sound projector technology and features a pair of built in subwoofers. Want to know more? Keep reading.
The Design
So just what is a digital sound projector? In the case of the SRT-1000, Yamaha utilizes eight 2.8cm drivers to create beams of sound which are steered toward the walls of your room. These reflections are then bounced towards you, creating a surround effect that in our experience is a class above most “virtual surround” solutions. To back up the “beam drivers”, the SRT-1000 also boasts a pair of 4cm x 10cm woofers, as well as a pair of down-firing 8.5cm subwoofers in separate ported enclosures. Each beam driver is fed by a 2W amplifier, while the woofers and subwoofers are driven by 30W apiece. Of note, system response is rated from 45Hz-22kHz, though no tolerance is provided.
Beams
In our experience, Yamaha's digital projector technology is the next best thing to a discrete surround sound system.
As previously mentioned, the SRT-1000 is a pedestal soundbar. Unlike a conventional soundbar that’s placed in front of your TV or wall mounted, you’re meant to place your TV on top of the SRT-1000. The enclosure measures 30-3/4”W x 3”H x 14-5/8”D, and Yamaha states that it is sturdy enough to hold a 55” flat screen TV.
Driver Layout
The SRT-1000's driver layout.
The Features
In addition to the hardware provided, the SRT-1000 sports quite a few features worth mentioning. First and foremost, the Yamaha boasts a remote learning function, allowing you to power cycle, adjust volume, and mute the SRT-1000 with your TV’s remote. The system also boasts integrated Bluetooth with AptX for streaming music from a smartphone or tablet, and Yamaha offers their home theater controller app for iOS and Android to control the SRT-1000.
Control App
Yamaha's controller app offers you a wide range of functionality including the ability to custom tune the SRT-1000 to your room.
Beyond Bluetooth, the SRT-1000 offers a modest array of connection options. Unlike some of Yamaha’s more advanced (and much costlier) soundbars, inputs are limited to a pair of optical digital inputs, a digital coaxial jack, and analog stereo. We’d expect in most cases, you’ll opt to connect the SRT-1000 to your TV with an optical digital cable, and let it handle source switching. Taking a closer look at the rear panel, one will also find a subwoofer output jack, which is a nice touch for those that would like an extra helping of low end fun.
Under TVAnalysis and Summary
Looking at the $500 class of soundbars, there’s no shortage of competition. Pioneer has their SP-SB23W soundbar at $400, which has the benefit of being designed by speaker guru Andrew Jones. There’s also the SpeakerCraft CS3, which is a pedestal soundbar boasting a pair of 5.25” down-firing woofers and a low end response of 35Hz. While both options are undoubtedly worthy competitors, neither offers Yamaha’s digital sound projector technology. Frankly, if you’re looking for the best surround experience short of a discrete surround system, the SRT-1000 seems like a good bet. Add in goodies like remote learning and a subwoofer output, and Yamaha’s latest soundbar looks even sweeter in our opinion.
Steve Munz is a “different” addition to Audioholics’ stable of contributors in that he is neither an engineer like Gene, nor has he worked in the industry like Cliff. In fact, Steve’s day job is network administration and accounting.
