Paradigm MilleniaOne Speaker System First Look
- Product Name: MilleniaOne 5.0 Speaker System
- Manufacturer: Paradigm
- Review Date: May 10, 2011 01:10
- MSRP: $1,249 (5 satellites), $1,399 (sub)
- First Impression: Mildly Interesting
MilleniaOne Speakers
Design (each speaker including center channel |
2-driver, 2-way vented die-cast aluminum enclosures with integrated baffle and chassis. Low-diffraction grilles maximize imaging and ensure smooth dispersion. |
Crossover | 3rd-order electro-acoustic at 2.2 kHz |
High-Frequency Driver | 25-mm (1 in) S-PAL™ satin-anodized pure-aluminum dome |
Bass / Midrange Driver | 102-mm (4 in) S-PAL™ satin-anodized pure-aluminum dome |
Low-Frequency Extension* | 76 Hz (DIN) |
Frequency Response: On-Axis 30° Off-Axis |
±2 dB from 120 Hz - 20 kHz ±2 dB from 120 Hz - 18 kHz |
Sensitivity - Room / Anechoic | 89 dB / 86 dB |
Suitable Amplifier Power Range | 15 - 100 watts |
Maximum Input Power | 50 watts |
Impedance | Compatible with 8 ohms |
Height, Width, Depth (not including stand) |
19.5 cm x 11.5 cm x 14.5 cm 7-3/4 in x 4-1/2 in x 5-3/4 in |
Weight (unpacked) | TBA |
Finishes | Gloss Black, Gloss White |
MilleniaSub
Design | Dual driver, sealed box, vibration cancelling, built-in Ultra-Class-D™ power amplifier, built-in wireless receiver for wireless option, USB port for PBK equalization |
Amplifier: High-Current, Discrete Output |
900 watts Dynamic Peak / 300 watts RMS |
Amplifier Features | Auto-on, soft clipping, thermal monitoring |
Bass Drivers | Two 355-mm x 76-mm (14 in x 3 in) reinforced polymer cones, corrugated Santoprene® surrounds, 25-mm (1 in) voice-coils |
Low-Frequency Extension* | 21 Hz (DIN) |
Subwoofer Cut-Off Frequency | Variable 35 Hz - 150 Hz; Bypass Option |
Sub / Sat Phase Alignment | Variable 0° - 180° |
Line-Level Input | RCA Sub-Out / LFE-Out of receiver, processor or other line-level source |
Height, Width, Depth (horizontal, including feet) |
13.75 cm x 46.5 cm x 35.5 cm 5-1/2 in x 18-3/8 in x 14 in |
Height, Width, Depth (vertical, including stand) |
38.25 cm x 12.5 cm (stand width 17.9 cm) x 46.5 cm (15 in x 4-7⁄8 in (stand width 7 in) x 18-3⁄8 in) |
Height, Width, Depth (on-wall, including hardware) |
35.6 cm x 46.5 cm x 15.0 cm (14 in x 18-3⁄8 in x 5-7⁄8 in) |
Weight (unpacked) | 10.9 kg / 24 lb each |
Finishes | Satin Black, Satin White |
Accessories (sold sep.) | Paradigm PT-2 Wireless Transmitter (see below) Paradigm Perfect Bass Kit room correction system MilleniaSub Wall-Mount Bracket system |
What does your mom want for Mother's day more than a small speaker system? Well, probably just about anything but if you have to get her speakers, Paradigm may have an option for you. The MilleniaOne system has been out for a little while but we haven't taken a close look at it. We're about to remedy that.
As you can see from the picture above, the satellites are tiny. At 7.75" tall, 4.5" wide and 5.75" deep, they'll fit just about everywhere. They feature a die-cast aluminum enclosure with a high gloss finish and silver drivers. They have an oval shape with a 4" Satin-Anodized Pure-Aluminum Bass/Midrange driver paired with a 1" tweeter constructed out of the same material. While the tweeter looks like it is mounted co-axially inside of another woofer, it isn't. That's just a stylized baffle that probably functions as a bit of a horn. The speaker have matching grilles (you can get the MilleniaOne speakers in either white or black) and look to be a metal mesh. Paradigm promises that the grilles are low-diffraction and won't affect imaging and dispersion.
With a small, satellite speaker system you are most worried about two things - placement and performance. With the MilleniaOne system, placement is not an issue as they include not only stands but wall mounts. Performance is helped not only by superior drivers but also a vented design. As you can see in the exploded view above, Paradigm is using an extended port to increase the bass output of these small speakers. Paradigm promises a low end extension both on and 30 degrees off axis down to 120Hz at +/-2dB. Not super impressive but they also specify a low frequency extension down to 76Hz "DIN". DIN, apparently indicates -3dB in a typical listening room. So... we don't know. We'd suggest crossing over the MilleniaOne speakers at 120Hz and lower the crossover until you hear dropouts.
If you want to add a sub, your Paradigm dealer will likely recommend the MilleniaSub. The MilleniaSub is a diminutive 14" by 18.375" by 8.875" and a paltry 24 pounds. Like the speakers it comes in either white or black but with a satin finish rather than high gloss. It has a 300 watt class D amp and a built in wireless receiver for use with the Paradigm PT-2 transmitter (you'll need to buy that separately). It an RCA style input, variable 35Hz to 15Hz crossover with a bypass option, and a variable phase control. It has a USB port for use with the Paradigm PBK-1 Perfect Bass Kit which is a room correction system which, you guessed it, is sold separately. And while you're at it, if you want to wall mount the MilleniaSub, you can buy the bracket system as well.
The real story here are the drivers. In such a small enclosure, you're going to need to maximize the driver space. The MilleniaSub looks more like an external hard drive than a sub and they've utilized both sides installing a driver on both. The enclosure is sealed and designed to resist vibration and is constructed out of 5mm thick extruded aluminum. The dual 14" by 3" reinforced polymer cones are held to the box by an over-molded corrugated Santoprene surround and have 1" voice coils. The drivers fire in opposite directions which also helps reduce vibrations and resonances. Unlike the satellites, Paradigm doesn't give a specification for how low the sub will go. All it lists is the DIN measurement which puts it down to 21Hz. That we would like to see... hear... feel. As you can see from the graphic above, placement options are numerous.
Paradigm has a great reputation for sound but they also have a reputation for price. The satellites are not overly expensive at $499 for a pair or $1249 for a 5.0 set (the per speaker price is listed at $249 but you can only buy them in sets). The MilleniaSub, on the other hand, is commanding $1399, more than the 5.0 speakers. If you are really into home theater, you might not think spending as much (or more for some of us) on a sub as all the rest of the speaker is unusual but for the average consumer, it is shocking. We'll have to see how they react. The fact is that the speakers are small, should perform well, and the sub is probably one of the most easy to place on the market. If they had thrown in the wall bracket and the wireless transmitter the price would seem better.
For more information, please visit www.paradigm.com.
