MCM Custom Audio 50-908 5.0 Speaker System Review
- Product Name: 50-908 Speaker System
- Manufacturer: MCM Custom Audio
- Performance Rating:
- Value Rating:
- Review Date: February 22, 2009 20:15
- MSRP: $ 36.95/pair, $103.85/5.0 system
50-9085 Bookshelf Features: |
50-9080 Center Channel Features:
- Price
- Size
- Performance
- What else is there?
- None at this price point
MCM Custom Audio 50-908 Full Review
When
getting into the home theater game, the biggest stumbling block for early
adopters is price. Justifying a display purchase is fairly easy. People can
understand a bigger screen and a clearer picture. You can see it. It requires
no explanation. Speakers, on the other hand, take a little more understanding
and experience. It is hard to explain to some what an effect surround can have
on their TV/movie watching experience. If you don't have a friend with a decent
surround system (and many don't) then that experience is hard to come by. What
you need is an "entry level" speaker system. Something that will
convince your significant other of the value of surround without breaking the
bank. That way you can bump up to a better system once you "work on them" a bit more. MCM Custom Audio may have the
solution for you
First Impressions and Build Quality
The MCM Custom Audio 50-908 speakers consist of the 50-9085 bookshelf speakers and the 50-9080 center channel. Together, the five speakers barely top $100 MSRP and you can add the 50-7660 subwoofer for just over $100 more. My personal opinion is that you should spend about as much on your sub as you do the other 5 speakers (at least at the lower price points). The price of the MCM Custom Audio is pretty much as low as you could ever expect for used speakers much less new ones.
The 50-908's are constructed
out of 3/8" MDF with a very thin piece of polyfil inside. The edges are
glued and the exterior is covered in a black woodgrain vinyl wrap. The grills
fit tightly on the chrome posts. The 50-9085 bookshelf speakers come with a
metal keystone wall mount or sticky rubber feet that can be affixed to the
bottom. The 50-9080 center channel only has the sticky rubber feet without the
keyhole wall mounts.
The speakers are quite small, though not as tiny as some of the cube systems out there. The bookshelves are sealed (regardless of what it says on the MCM website) which should make placement a bit easier (especially useful for neophytes that don't understand why the initiated insist that you shouldn't put bookshelf speakers in a bookshelf). The center channel has shielded drivers which are actually pretty useful at this price point. Usually, I mock shielded drivers as frivolous but mostly that is because anyone spending many hundreds to thousands of dollars on a speaker certainly isn't putting them on top of a CRT. The MCM speakers are at a price point where this could certainly be the case. I took the speakers into my office and held them up to the ancient CRT monitor that I should have replaced years ago. The smaller bookshelf speakers caused visible distortion but the center did not - verifying MCM's claim.
The back of the speakers
sport plastic spring clips which really only accept bare wire. You will
probably be limited to 16 AWG wire though with a little persuasion and perhaps
some trimming 12 AWG might work. The tweeter is mylar and the woofers are poly
cones that are painted to look aluminum. The overall look of the speakers is
nice especially when you consider the price. MDF is a huge step over the tiny
plastic enclosures that you might see in a competitor. The drivers take up most
of the real estate on the front baffle of the bookshelves and the center is
wide and short which will hopefully make placement in a number of different
type of cabinets easier.
Set-Up
The MCM Custom Audio 50-908 speakers were set up in a smallish room with the mains about 9' from the listening position. Stands were used for all the speakers and the center was placed inside of a Diamond Case Theater Tech TT-400 Credenza. The speakers were powered by my Denon AVR-2307CI. A Denon DVD-3910 universal player did source duties with cabling from Impact Acoustics and Blue Jeans wiring everything together. An Axiom EP-500 provided the low end - a sub that costs over 10x's the entire 5 speaker MCM set.
While the specs suggest that these speakers play down to 60Hz, I think
you're going to want to cross them over a bit
higher than that. I grabbed my trusty Rives
Test CD II and played the 1 kHz test tone. I upped the volume until I had
about 75dB on my SPL meter and moved down the frequency range until the
response started to fall off. At 100Hz I had pretty good output which fell off
by about 10-15dB at 80Hz and 63Hz. Part of this very well may be room
interaction but not the totality of it. I suggest crossing these speakers over
no lower than 100Hz (which is what I did).
The speakers seemed pretty indifferent to placement at least in respect to toe-in. This is a huge plus as speakers in this price range are often going to be placed non-optimally. The soundstage was flat but wide. My positioning of the speakers about 8' apart was a bit too wide and presented a "gappy" center image in two-channel mode. I'd place this speakers a little closer together (no farther than 6') for two-channel use. In a multichannel environment, I experienced none of these problems. The addition of a good sub will help with the soundstage depth but it won't be a panacea. Imaging was much better than I expected with very good movement from speaker to speaker. I found the vocals were generally well anchored in the center. To be honest, I found the imaging to be much better than I had hoped and 10x's better than I expected.
Listening Evaluation
I listened to a number of albums/movies with these speakers including Yello
– the eye, Michael
Buble - It's Time, and movies like The
Dark Knight. The MCM Custom Audio 50-908 series speakers performed
admirably well considering their price point. Movies were of course by far the
most forgiving especially considering the quality of the subwoofer I was
working with. The high end was attenuated and the overall presentation was a
bit tinny and flat. But the soundstage was wide and the imaging remarkable for
speakers this size and price.
I found female vocals to be very well realized with the MCM speakers.
Male vocals (at this crossover point) often dipped into the range of the sub,
which meant I had a harder time evaluating the 50-908's performance. Without
the sub, the speakers did an admirable job full range (but not something I'd
recommend) and I heard no audible distortion or bottoming out of the drivers.
This might be because of the size of the room, though, and how high I had to
turn them up to be subjectively loud. In a larger room, I can easily see these
having major problems. In my room, the 50-908's managed to pump out enough bass
that even some of the lower bass runs which I use to torture larger speakers
came through. Not strongly, mind you, but it was there. That alone is a huge
success in my mind.
The speakers really sounded best at a moderate volume. While I was able
to turn them up without catching them on fire (or melting a voice coil or
something), the highs started to break up and the overall presentation was
strained. While you can place these speakers in any size room you like, I'd
suggest small to medium sized rooms. The larger the room, the more strain
you're going to put on the speakers and the lower the quality of the output
will be. In a larger room, you're going to want to use these for low to
moderate volume levels. In a smaller room, you can push them harder but be
careful and experiment fist. While the speakers weren't overly taxing to my
amp, I did notice that they presented a harder load than even some of my
floorstanding speakers. Since you won't be able to turn up the speakers too
much without audible distortion, this shouldn't prove to be much of a problem
in actual use.
As an entry level speaker, the MCM
Custom Audio 50-908's blew me away. While they are obviously limited by their
price point, what they do manage to do is overperform. For just over $100 you
can have a 5.0 system that will not only introduce you to surround sound but not
break the bank at the same time. Imaging was decent and the soundstage was
wider than I expected. As an entry level "gateway" system, you can
look to the MCM Custom Audio 50-908's as a good first step that will make a
great hand-me-down when you decide to step up to a better system.
MCM Custom Audio 50-9085 Bookshelf Speakers
$36.95/pair
MCM Custom Audio 50-9080 Center Channel Speaker
$29.95/each
MCM Electronics
650 Congress Park Drive
Centerville, Ohio
45459
Phone: 1-800-543-4330
About MCM Electronics
MCM
Electronics is a broad line distributor of electronic components, equipment and
accessories for the consumer electronics industry. MCM's products include:
computer hardware and peripherals, security and surveillance, wire and cable,
audio and video equipment, tools, test equipment and much more. MCM is part of
the Marketing Distribution Division within Premier Farnell plc.
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Build Quality | ![]() ![]() ![]() |
Appearance | ![]() ![]() ![]() ![]() |
Treble Extension | ![]() ![]() ![]() ![]() |
Treble Smoothness | ![]() ![]() ![]() ![]() |
Midrange Accuracy | ![]() ![]() ![]() ![]() |
Bass Extension | ![]() ![]() ![]() |
Bass Accuracy | ![]() ![]() ![]() ![]() |
Imaging | ![]() ![]() ![]() ![]() ![]() |
Soundstage | ![]() ![]() ![]() ![]() ![]() |
Dynamic Range | ![]() ![]() ![]() |
Fit and Finish | ![]() ![]() ![]() ![]() |
