Denon HEOS Soundbar Preview
- Product Name: HEOS Bar
- Manufacturer: Denon
- Review Date: April 12, 2017 10:00
- MSRP: $899
Audio
- Dolby TrueHD, DTS-HD Master, Dolby Digital, Dolby Digital Plus, DTS Decoding
- Auxiliary Analog Line Input
- IR Remote Learning
- 4x HDMI Inputs and HDMI Output
- Class D Digital Amplification
Music Formats:
- WMA Up to 192kbps
- AAC and MP3: Up to and including 320kbps
- FLAC, WAV and ALAC: Up to and including
- 24-bit/192kHz
- DSD 5.6 (streaming)
Picture Formats:
- JPG, PNG, BMP and GIF album art picture formats
Networking:
- 802.11 networks (dual band "N", "AC")
- RJ-45 LAN port
Dimensions (H x W x D):
- On the shelf: 2 7/8 x 43 3/8 x 5 7/8 inches; 72 x 1100 x 148 mm
- Wall mount: 5 7/8 x 43 3/8 x 2 7/8 inches; 148 x 1100 x 72 mm
Weight:
- 10.58 lbs; 4.8 kg
Power Supply:
- 100-240 Volts AC, 50/60 Hz
Denon
has gone all-in on its HEOS wireless speaker systems this year by
introducing a new line of Wi-Fi audio products, including a new sound
bar. This April, the HEOS Bar will take its place alongside the HEOS
HomeCinema soundbar and will retail at $899 - that’s $100 more than the
HomeCinema, which presently sells for $799. But is the Bar truly a step
up?
The
new HEOS Bar is a 3.0 channel soundbar featuring built-in left, center
and right channels. The unit itself is beautiful, with futuristic curves
that make it look as if it’s ready to blast into hyperspace at any
moment. Hardware-wise, the HEOS Bar is flexible and can be wall-mounted
or sit on a shelf. It has nine separate drivers along its three and a
half feet of width, all of them aimed at a 45-degree angle. This design,
Denon says, makes it sound equally great sitting in a shelf or hanging
from a wall. Unlike its closest competitors, including Sonos Playbar,
Denon has baked expandability and flexibility into the HEOS Bar, with
four HDMI ports that support 4K UHD and ARC (Audio Return Channel). The
system can use popular audio codecs, including Dolby TrueHD, DTS-HD
Master, Dolby Digital, Dolby Digital Plus and DTS Decoding. Absent are
Dolby Atmos and DTS:X.
But
despite its flexibility and stylish form, one thing that is sure to
disappoint many is that the $899 price won’t include a wireless
subwoofer like Denon’s previous soundbar HomeCinema did. The omission of
the sub may actually be a mixed blessing, however. Most budget soundbar
systems include a wireless active-subwoofer that is really a subwoofer
in name only. Many aren’t really capable of the kind of low rumble you
really want for the home theater experience, and are only included to
round out the anemic sound from their system’s tiny speakers.
HEOS
solves the lack of subwoofer problem with an another new product for
2017 called HEOS Subwoofer. It’s an independent HEOS product intended to
integrate with any HEOS system. According to Denon it adds “...deep,
powerful bass to any HEOS device with best-in-class sound quality. It
suits any room and any setup.” The HEOS Subwoofer, also available in
April will carry an MSRP of $599.
So
to sum it up, rounding out your 3.0 HEOS Bar into a 3.1 sound system
with the HEOS Subwoofer is a $1,500 commitment. Depending on your
perspective, it could be a bold move by Denon to forgo a subwoofer just
to make the system seem complete. It could be seen as a move to allow
the company to free-up resources that can go into making the soundbar
itself much better. Or, the move could just be seen as a poor excuse to
get you to buy multiple premium-priced Denon products. Either way, the
HEOS Bar isn’t cheap and we’ll reserve judgement until we’ve actually
tested both products.
Wireless Expandability to 5.1 Surround
On
the subject of buying add-on speakers for your HEOS Bar, it turns out
expandability and flexibility is one of the key features that makes the
system pretty cool. Pick up an extra pair of HEOS speakers for the back
of your media room and you’ve turned HEOS Bar into a complete 5.1
system. Any pair of HEOS speakers will do the trick, but for a truly
wireless surround system that includes no power cable, you’ll need to go
with the HEOS 1 model ($199/ea). The tiniest of the HEOS lot, these
speakers are the only HEOS speakers to date that are battery powered.
While the HEOS 1s leaves the smallest footprint of the Denon’s wireless
line, they run the risk of sounding thin while performing surround
duties for the HEOS Bar and its nine drivers up front. The HEOS 3s (MSRP
$299/ea.) could be better candidates to fill the sweet spot between
performance and size, with a flexible form factor allowing them to be
positioned it on their side, standing up or wall mounted.The
new HEOS Bar system from Denon gives you plenty of options for an
upscale soundbar system that promises to bring flexibility to a setup
that’s easy to setup. Like all HEOS speaker systems, it can playback
from a variety of wireless options including Wi-Fi or Bluetooth. The
HEOS app let’s you control audio from your phone directly to HEOS Bar as
a standalone sound system or as part of a multi-room system, giving you
the power to stream separate sources into each room. You can use the
HEOS app to stream music from a variety of online sources too, including
Spotify, Pandora, TuneIn, TIDAL, SiriusXM, iHeart Radio, SoundCloud and
Amazon Music.
The
$1,500 price tag for the HEOS Bar plus HEOS Subwoofer puts it into the
premium soundbar category, so it’s expected that it will perform with
great sound for both music and movies. Although there may be some
compromises when comparing it to a similarly priced AV receiver-based
system, soundbars offer competitive room acoustics in an unobtrusive
package and the HEOS systems we’ve seen so far at Audioholics have been
consistently well-received.
The
possibilities for upgrading your sound system with added speakers and
flexibility of adding sources with its four HDMI ports, makes the HEOS
Bar more than most standalone soundbars. Denon looks like it has a
product that is poised to win hearts, minds and ears for 2017 and
beyond.
