RBH CinemaSITE Custom Home Theater System Review
- Product Name: CinemaSITE Custom Home Theater System
- Manufacturer: RBH
- Performance Rating:
- Value Rating:
- Review Date: August 19, 2005 20:00
- MSRP: $ 23422
Supported Loudspeakers - Front Cabinet Center speaker: SI-740/SI-760/SI-6100 Left/Right speaker: SI-740/SI-760/SI-6100 Subwoofer: SI-12/SI-12P/SI-1010/SI-1010P (powered) Dimensions - Front Cabinet Overall Width: 135.5" (11' 3.5") Overall Height: 95" (7' 11") Overall Depth: 17" (1' 5") Projection Screen Size: 92" - 110" (16:9 aspect ratio) |
Supported Loudspeakers - Surround Columns Left/Right speaker: SI-740/SI-760/SI-6100 Subwoofer: SI-12/SI-12P/SI-1010/SI-1010P (powered) Dimensions - Surround Columns Overall Width: 20" (1' 8") Overall Height: 90" (7' 6") Overall Depth: 8" Weight: Darn heavy |
- Custom install look and feel without the hassle
- Installs in around 4 hours
- Can be finished to match any décor
- Profoundly excellent sonic quality
- Flexible loudspeaker and subwoofer options
- Handles projection screens up to 110" diagonal
- Requires minimum 8' ceilings
- Customization limited to finish and speaker selection (size/width of unit is fixed at present)
CinemaSITE Installation
When I first saw the RBH Sound CinemaSITE at the 2004 CEDIA show I was instantly captivated by the sheer genius of the product. For years it was only possible to get the elegant look of a custom home theater by either a) having a one-off custom wood-worked cabinet designed and, or b) utilizing an existing furniture solution that allowed integration of speakers on shelves. The problem with either of these solutions can be summed up by a factor of cost, inconvenience and severely compromised sound quality. The RBH Sound CinemaSITE on the other hand has been completely designed from the ground up to serve as a custom install solution for housing their Signature Series line of in-wall loudspeakers. In addition to being sonically designed to hold the RBH Sound in-walls, the entire system is laid out in a way that makes installation a breeze. Try that with a custom product!
Just exactly
how
does one go about
creating a "custom" home theater system from scratch? Well, for starters it's important to have
solid goals. RBH Sound set out to craft a system that didn't just simply hold their in-wall
speakers. They wanted to address a complete custom solution that took into account a simple
installation process, speaker selection flexibility, and a design concept that would allow their
Signature Series in-wall speakers to closely mimic an in-stud installation without any CinemaSITE
cabinet resonance to produce optimal audio reproduction quality.
Our review system included components to put together a full 5.1 system, including the main front piece and two side surround columns. The CinemaSITE can be custom configured into almost any type of system - from an entry level SI-740-based 5.1 system to a full-scale T-2 equivalent 7.1 configuration. Here are the current loudspeaker options:
CinemaSITE 5.1 System
Starting at $17,900/system
System includes:
CinemaSITE front wall and two rear columns
5 each SI-740
2 each SI-12/P
Upgrades
Additional column (no speakers): $1,349/ea.
Upgrade 1 each SI-740 to a SI-760: Add $176/ea.
Upgrade 1 each SI-740 to a SI-6100: add $1,476/ea.
Upgrade 1 each SI-12/P to a SI-1010/P: add $370/ea.
The system configured in this review utilized three SI-6100s, two SI-1010P subwoofers (with dual SA-400 amplifiers), a pair of SI-760's for surrounds and a pair of 41-SEs for Back Surround channels.
Installation
In terms of steps, installation is a breeze. For
those installers who will place several of these systems into their clients homes throughout the
year this process will get down to about 4 hours - and almost mind-numbingly simple process that
should save countless hours in fitting loudspeakers into custom cabinetry and hunting down
vibrations and cabinet resonance issues.
I had the fortune to have RBH Sound's Designer, Shane Rich , and their Marketing Manager, Daren Egan on hand to help me install this system for review. RBH Sound developed a DVD video that takes the custom installer through the required steps to install the CinemaSITE system. M y comment after seeing the video was "Is that all?" Nothing demonstrated the system's ease of setup better than the fact that the installation video was a grand total of two minutes and 30 seconds in length.
We began with the first column and loaded both the SI-6100 loudspeaker and RBH Sound's brand new SI-1010 subwoofer. Pins attached to the sides of the SI-6100's allow it to simply slide through pre-cut grooves and lock tightly into place within the column of the CinemaSITE. In addition the pins provide isolation such that the in-wall speaker, when knuckle rapped, didn't seem to couple with the cabinet at all. The sub slides neatly behind the main speaker and is held into place through the use of dampening material on the sides which also eliminates resonance from the CinemaSITE columns. Each sub is powered by a separate SA-400 (400 watt RMS) class AB/G amplifier. I opted to utilize 12AWG Velocity Bulk Speaker Cable from Impact Acoustics to wire up the entire system and we ran the speaker wire behind the SI-1010 subwoofer such that the CinemaSITE could mount flush against the wall. We actually used Impact Acoustics cables for the entire Reference System 2's analogue audio and video cabling.
Next came the SI-6100 center channel which, again using pins, was
attached to the center channel bracket so that it could be held in place as well as angled up
towards the listening position from beneath the projection screen. The bracket itself is then
secured to the CinemaSITE using the supplied bolts and allen wrench. All of this is done with the
lower part of the center section lying face down on the ground. At this point the center section is
lifted up and the CinemaSITE starts to really take shape. The grooves which are cut into the sides
of the front columns allow for a snug and secure fit of the center section pieces. In fact, when
the top section was added, you could barely see the seam even though it ran nearly the entire
length of the CinemaSITE.
Editor's Note
Possibly one of the most impressive aspects of the CinemaSITE system and the installation process is the fact that you NEVER need to get behind the unit during installation. Through the thoughtful inclusion of removable decorative panels and carefully placed holes in the top part of the center section, all wires and final connections can be made without ever having to worry about being able to access the rear of the unit. This saves a tremendous amount of time and eliminates an untold number of potential headaches.
We next
attached the other front column after inserting the speaker and subwoofer. Finishing touches of the
main piece included anchoring the entire CinemaSITE to the studs of the wall with supplied plumber's
tape and screws. This assured me that the system wouldn't easily tip over, though we found that Daren
could hang almost 200 pounds off the front of the unit before it began to tip. This is likely due to
the presence of some very heavy rear-loaded subwoofers. In any case, it's always better to be safe
and RBH is very specific about this particular step to ensure customer safety.
Finishing touches included putting on the grill covers which are simply beautiful. RBH Sound has them made using a door casing process in Utah and it really shows. The attention to detail in this system is nothing short of breathtaking, from the crown molding to the available finishes (the review sample was a very rich mahogany that my wife fell in love with.) Other than a few natural knots (and I do mean only a few) the maple-based wood was flawless and of a very high quality.
CinemaSITE Listening Tests and Conclusion
Sure, it looks good - but what about the sound? Well, for starters the CinemaSITE we reviewed utilized three SI-6100 speakers across the front sound stage with dual SI-1010P subwoofers. This is the driver-equivalent of a full T-2 loudspeaker system in an in-wall configuration. Let me just say that there is plenty of horsepower to drive even a very large home theater room. We set up a microphone and calibrated the system as best we could after it was all put together. Once the RBH Sound guys departed I was able to do some additional tweaks and get the system leveled out quite a bit to where it had a very smooth frequency response and bass integrated within the room. We found that adjusting the phase of one of the subwoofers resulted in a more uniform low end frequency response at the primary listening positions overall and didn't appear to have any negative effects on bass response of the system.
Stereo and
Multi-Channel
Music
One of the first items I listened to was The Best of REM: In Time DVD-Audio disc , if only because I was so familiar with its content and it comes with both a 192kHz/24-bit stereo and 96kHz/24-bit surround M LP track. Listening to "Everybody Hurts" I found that the CinemaSITE's triple array of SI-6100s created a fully immersive and coherent sound stage with very good imaging.
One of the more amazing characteristic features of the SI-6100-based system is the absolute rock solid sound stage which is maintained regardless of whether you are sitting or standing. Why is this important? Well, if you are like me you appreciate a home theater with stadium seating and this system ensures that all seats in the house get phenomenal sound.
"Losing My Religion", with its tight drum mix and mesh of bright instrumentation, proved that the CinemaSITE had room to spare at the top end. At no time did the track sound compressed and sibilance was smooth, containing none of the grain generated by lesser tweeters.
To finish off this disc I skipped over to "E-Bow the Letter" which exercised the SI-1010Ps, and slammed me into my seat in rhythm with the powerful kick drum. Vocals were also crisp and clean and reverb slid off the SI-6100s like a sheet of silk.
I next queued up
Marillion's
Marbles on the
Road
Concert DVD in order to hear a live concert event which traditionally
has more "honest" vocals and a less produced sound. I was rewarded with
a veritable concert in my theater room. The CinemaSITE simply cannot be
overdriven - at least not with the SI-6100s across the front, and
certainly not in my room. Listening to "You're Gone" almost brought me
to my feet; the sound was so honest and revealing.
Steve
Hogarth's vocals were so very passionate and real coming from the
system you could almost feel him in the room. "Angelina" provided some
excellent reverberant vocals and a
Hammond
organ sound accompanied by enunciated lead guitar solos and a gentle,
rolling bass line. I'd have to say that this song was one of the most
well-rounded on the DVD and gave the CinemaSITE a nice blend with which
to fill the room - a task it performed flawlessly and without
compromise.
Movies and Soundtracks
We queued up XXX: State of the Union and settled back in to see how well the CinemaSITE would perform with a high-powered action movie. We weren't disappointed. The twin SI-1010P subwoofers did double duty on my sitting position as explosions frequently rocked the room (such as the scene where Darius Stone, played by Ice Cube, plays cat and mouse with another tank in close quarters.) The score by M arco Baltrami (who also did the score for I, Robot) came through with vigor and filled the surrounds. Fortunately for me, the overall soundtrack was not as ridiculously thin as the plot! Bullet ricochets, vehicles, and rock-solid punches made this movie increasingly better as time and events progressed. The RBH System really lent an immersive believability to the movie that fully enveloped me into the picture and helped me forget I was sitting in the home theater room. Quite simply, this is a better theater experience than anything I have heard lately in the M yrtle Beach area. It was particularly noteworthy that having the dual SI-1010P subwoofers allocated enough earth-shaking bass to easily fill my room and create plenty of tactile response at the seated positions. While I'm sure adding a ButtKicker would be fun, it really didn't feel needed in this system.
CinemaSITE Review Summary and Conclusion
The CinemaSITE is a revolution in custom home theater. This is not just another loudspeaker system; this is a breakthrough in simplifying the process of integrating a custom home theater solution into someone's home. The price, ease of setup, customization options, and sheer reliability of the system make it a no-brainer for those installers who have been using or looking into custom solutions for their clients. Having gone through the entire installation process I can say first hand that this system is going to make some customers VERY happy, while saving installers and dealers significant time and headaches. You really have to see and hear the CinemaSITE to believe it.
RBH Sound
382
arshall
Layton
Utah
84041
Phone:(800) 543-2205
Fax:
(801) 543-3300
http://www.rbhsound.com
About RBH Sound
A Utah based company with over 28 years of experience, RBH Sound has
taken loudspeaker manufacturing to the next level with their line of
freestanding and in-wall/in-ceiling speakers designed for custom
installation. RBH's highly acclaimed Signature Series is available in
over 30 high quality, genuine woodgrain veneers and was designed to
both look and perform beautifully. Since 1976, RBH Sound has been
designing, engineering and crafting high-performance loudspeaker
systems, delivering superior acoustic reproduction at sensible prices.
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Performance | ![]() ![]() ![]() ![]() ![]() |
Value | ![]() ![]() ![]() ![]() |
