Epson Pro Cinema 1080 UB First Look
- Product Name: PowerLite Pro Cinema 1080 UB
- Manufacturer: Epson
- Review Date: October 17, 2007 16:01
- MSRP: $4999
- Two HDMI 1.3 inputs
- 1600 lumens
- 50,000:1 stated contrast ratio
- x.v.Color (Deep Color) support with extended color gamut
- 96-degree vertical and 47-degree horizontal lens shift
- OptiCinema lens system takes advantage of 14 lenses
- 1:2.1 zoom ratio
- Six axis color adjustment
- 24 db fan noise
- Epson E-TORL Lamp
- Pearlescent black finish
- Spare lamp and ceiling mount included
- Optional: motorized anamorphic lens system and outboard Silicon Optix HQV scaler
- Three-year limited warranty
We got an up close and personal look at the new Epson PowerLite Pro Cinema 1080 UB projector at the 2007 Audioholics State of the CE Union event in Clearwater Beach, Florida. The "UB" stands for Ultra Black and by the looks of what we saw on the screen, the designation is not given lightly. While DLP insists on providing a color wheel and holding out its 3-chip designs for only the most high-end models, Epson and other 3LCD manufacturers are cleaning house in terms of bang for the buck. This under-$5000 projector features a healthy amount of lens shift (almost 100% vertical and 50% horizontal), two HDMI 1.3 inputs, Deep Color (x.v.Color) support, and a 2.1x zoom.
With a name like PowerLite Pro Cinema 1080 UB, I think Epson needs to drop some of its nomenclature or risk spraining some tongues, but all kidding aside the projector is fantastic. It's stated 50,000:1 contrast ratio may be a bit overstated in terms of real-world numbers, but you can bet that with their new D7 panels with C2Fine (a new inorganic substrate that uses 12-bit video processing and a new polarizing light filter) and 1600 lumens, the 1080 UB is no slouch.
The new UB model continues to have the same ISF certification of the Pro Cinema 1080 and sports the same low-noise 24dB fan system (in Eco mode) that makes this such a beautiful projector for home theater installations. The retail of the Pro Cinema 1080 UB is going to fall under $5000 and it should release in December. The Pro model also comes with a 3-year limited warranty (as opposed to 2-years) and also includes a ceiling mount and spare lamp.
In the demo we witnessed at the State of the CE Union event, Epson paired the projector with its optional motorized anamorphic lens system and outboard Silicon Optix HQV video processor. This would, supposedly, make this the "Epson PowerLite Pro Cinema 1080 UB HQV" but my tongue is already numb... With the anamorphic lens and scaler system (roughly an ~$8000 added cost), the picture was absolutely stunning. We saw clips from King Kong and Seabiscuit. Seabiscuit was absolutely stunning in terms of its color. Reds (as in the jockey uniform worn by Toby Maguire) absolutely jumped off the screen while holding on to their definition and detail. Skin tone was realistic and greens were actually green, not green-yellow as is often the case. King Kong demoed the incredible detail and black level reproduction that is possible with this projector (we saw the stampede scene and the rocks and cavern walls made for perfect video demo material). There was absolutely no ambient light in the room, save that reflected by the screen - but it was still apparent that the 1080 UB has massive potential and has overcome some serious hurdles in producing darker blacks.
The scaler allows the D7 chip to "fill" completely up with an anamorphic image from a 2.35:1 source found on a DVD or HD-DVD. This means that there are no pixels taken up by black bars and "wasted" on the LCD panels. The picture, as a result, is about 30% brighter and the anamorphic lens then expands the output of the lens to the proper 2.35:1 aspect ratio. At the demo we saw the output on a 2.35:1 Carada Criterion screen. There were no black bars and every pixel was being used to its utmost potential. This projection system makes a very nice picture. It was especially nice since Kevin Miller from ISFTV had been on hand earlier to personally calibrate the image to the screen and tweak out the projector to its fullest potential.
Keep your eyes peeled for this product towards the end of the year and start saving your pennies now. If you're a consumer, you'll want to check out the Home Cinema 1080 UB, but serious custom installers will undoubtedly want the ISF features of this model for their clients.
