Mitsubishi HD4000 DLP Projector Review
- Product Name: HD4000 DLP Projector
- Manufacturer: Mitsubishi
- Performance Rating:
- Value Rating:
- Review Date: April 16, 2006 20:00
- MSRP: $ 3995
Display Technology: Single 0.65-inch DarkChip2 DLP technology from Texas Instruments Resolution: 1280x768 Brightness: 2000 Lumens Contrast Ratio: 2500:1 Noise Level: 37dB typical 31db low lamp mode Lamp Life: 3000 Hours standard Horizontal Scan Rate: 15-80 kHz Vertical Scan Rate: 50-85 Hz Image Size: 40-inches to 275-inches Throw Ratio: 1.63 to 1.97 (Distance/Width) Uniformity: 90% Or Better |
Keystone Correction: Horizontal and Vertical Video Compatibility: NTSC, PAL, SEACAM, EDTV, HDTV Computer Compatibility: UXGA, SXGA, WXGA, XGA, SVGA, VGA I/R Pickup Receivers: Front and Rear 12-Volt Trigger Dimensions: 12.20” W x 3.90” H x 9.60”D (310 x 100 x 215 mm) Weight: 6.5 Pounds (2.8kg) Power Supply: 100-240 Volts 50-60Hz Projection Methods: Front, Rear, Ceiling Mount, Table Top Warranty: 3-Year Limited Warranty; 90-Day Lamp Warranty |
- Very bright
- Excellent black level and color
- Very good internal video processor
- Excellent 3-year warranty with Express Replacement, 24-hour rapid swap out.
- No lens shift
- Remote has sporadic operation
- Excessive rainbow effect (RBE)
- Lacks fine image detail
- Average build quality and generic styling
- HDMI will not sync with HTPC
- Low performance to price ratio
Build Quality and Remote
The HD4000 is well packed from the manufacturer to prevent shipping damage. The projector includes the following accessories: one RGB cable, one RS-232 cable, one power cord, a backlit remote, AAA batteries, filter cover, attached lens cap, user instruction manual and quick start guide.
Physical Characteristics
The Mitsubishi HD4000 won't win any awards for styling. The rectangular rather ordinary case looks like many of the plain gray business type projectors on the market. The top case contains the power button, auto position, keystone, video, computer, enter, and menu buttons. Toward the front, above the lens is the manual focus and zoom adjusters.
Located on the bottom of the projector are three threaded leveling feet and the mounting holes for the optional ceiling mount. The mount holes are located in conventional configurations that carry the weight of the projector evenly, so the use of a universal mount should not be a problem with this projector. The projector lamp assembly is located under the square panel on the left side for easy access. We would say that we were a little disappointed inthe overall build quality, fit and finish of the HD4000.
Remote Control
The backlit remote supplied with the HD4000 is fairly ergonomic, but those with large fingers may double push buttons due to the small size and spacing of the buttons. The remote is backlit and we liked the inclusion of contrast, brightness, color temp, gamma, and sharpness buttons on the remote. The remote also has three A/V memory buttons from which to choose.
We found that remote operation was pretty sporadic; many times we had to aim and continually push buttons to get the projector to respond. We found it very difficult to make on the fly adjustments. As with previous projectors reviewed, this could be a result of the remote, IR pickups, or IR pickup location on the projector housing.
Setup, Installation, User Menus, and Test Results
The Mitsubishi HD4000 has a good selection of inputs. On the back of the projector you will find one HDMI input, one component video input, one S-video input, one composite input, one RGB D-SUB 15 pin computer input, one RS-232 serial port, and a single 12 volt trigger.
The USB port located on the back of the projector is for service only.
Installation Consideration
Throw distance is the amount of distance you will need between the screen and the projector's front lens to fill the screen with the projected image. The HD4000 has a zoom factor of about 1.26x, meaning that on a 100-inch diagonal screen the projector would need to be installed at a minimum of about 12 feet and a maximum of about 14.5 feet. If you don't feel like doing the math, Mitsubishi provides a distance calculator for download on their website, but unfortunately the HD4000 is not listed in the calculator.
Another very important consideration when contemplating a front projection installation is the projector offset. The HD4000 is a fixed lens projector, which means it has no mechanical lens shift and it must be installed at a predetermined height for proper installation geometry. This is somewhat disappointing as other models sold at this price now include this feature. The Mitsubishi HD4000 does include vertical image shift that moves the image up and down within the panel, but this should not be confused with a mechanical lens shift function. The marketing brochure that is distributed from Mitsubishi is very confusing because it states that the projector has vertical lens shift, as does the website specification PDF.
The fixed projector offset for this projector would be 49-inches for a 100-inch screen, meaning the center of the lens needs to be placed approximately 49-inches above or below the center of the screen.
User Menus
The HD4000 user menu is fairly easy to operate and comprehend. The user controls are expansive and should enable the user to get good calibration results in the menus. The user menu contains four headings labeled: Image, Installation, Feature, and Signal.
Under the Image menu you will find: Gamma Mode, Contrast, Brightness, Color Temp, Color, Tint, Sharpness and Brilliant Color when using the interlaced input.
The menu heading Installation contains: Screen Size with the selections of aspect ratios of 15:9, 16:9,4:3, and 2:35:1; Vertical Location moves the image up or down on the screen within the panel; and Lamp Mode allows the user to select either standard or low, Low should be the correct setting for home theater applications. Additional settings are: Auto On, Auto Off, Splash Screen, Back Color, Image Reverse, Trigger Out On/Off and Cross Hatch Pattern.
The next menu heading is labeled Feature and contains: Aspect with selections of Auto, 4:3, 16:9, Zoom 1, Zoom 2, Stretch and Real. The next setting found under Feature are: Password Function, Menu Position, Cinema Mode (Auto or Off), Video Signal, and WXGA. The next setting in this menu needs some explaining: Set Up (Auto, Off, 3.75% and 7.5%). This is an important setting for correct calibration and in our opinion is placed in the wrong section of the user menu system. This setting changes the IRE level of the projector and we would think this setting would be placed in the Image section instead of its obscure location. The next settings are: Scart, Language, and Reset (this resets the projector back to factory default settings).
The last Menu heading is Signal and contains: Horizontal Position, Vertical Position, Fine Sync, Tracking, Computer Input, Hold, and User.
480i Component Video Connection
Perfect Score is 130: the HD4000 scored an 85
Test |
Max |
Component |
Component |
Color Bar |
10 |
10 |
Pass |
Jaggies #1 |
5 |
5 |
Pass |
Jaggies #2 |
5 |
5 |
Pass |
Flag |
10 |
5 |
Pass |
Detail |
10 |
5 |
Pass |
Noise |
10 |
5 |
Pass |
Motion adaptive Noise Reduction |
10 |
5 |
Pass |
Film Detail |
10 |
10 |
Pass |
Cadence 2:2 Video |
5 |
0 |
Fail |
Cadence 2:2:2:4 DV Cam |
5 |
0 |
Fail |
Cadence 2:3:3:2 DV Cam |
5 |
0 |
Fail |
Cadence 3:2:3:2:2 Vari-speed |
5 |
0 |
Fail |
Cadence 5:5 Animation |
5 |
5 |
Pass |
Cadence 6:4 Animation |
5 |
5 |
Pass |
Cadence 8:7 animation |
5 |
0 |
Fail |
Cadence 3:2 24fps film |
5 |
5 |
Pass |
Scrolling Horizontal |
10 |
10 |
Pass |
Scrolling Rolling |
10 |
10 |
Pass |
Total Points |
130 |
85 |
Comments on HQV Testing
This is the second projector we have evaluated that incorporates the new Texas Instruments DDP-3020 processor. Once again we were very surprised to see such a capable video processor in this projector.
Viewing Evaluation and Conclusion
Using the Denon DVD-2910 DVD player, set for HDMI and 720p output, we began our viewing evaluation in a totally dark room. Powering up the projector we found that the HD4000 had no auto source detection which means you must manually select the input that you are using. This is somewhat disappointing considering the cost of the projector and we think that it should not have been omitted. As the projector began to warm up in the dark room, we did note a small amount of light leakage emanating from the side fan discharge vent. This would not be a problem if the projector was ceiling mounted but may be a distraction for individuals that install the projector on a tabletop in front of the viewing position. We also noted that the projector was significantly louder than the previous projector we reviewed, the Optoma HD72 .
We selected the DVD The Legend of Bagger Vance . This older DVD has beautiful cinematography, wonderful color, and a great inspiring story line. The HD4000 displayed wonderful color and black level, but the image looked soft, lacking fine detail. We also detected a small amount of posterization and solarization in scenes that were bright. These anomalies were pretty easy to detect in the shots that contained the sky or the sun.
A pot of gold?
We can tell you for sure that this legend is false because we viewed so many rainbows evaluating the HD4000; we have become experts on the subject manner. The simple fact is that this fatal flaw is more than prevalent when viewing video material on this projector. We believe that even those that are not sensitive to the RBE phenomenon would be able to view them when using the HD4000. We can only assume that this must be due to a slow color wheel speed, a timing issue with the color wheel, processor, and/or light engine.
We thought it would be fitting to select Mission Impossible 2 as our next evaluation DVD in anticipation of the sequel Mission Impossible 3. Once again the Mitsubishi displayed nice deep blacks and rich vibrant colors, but the rainbow effect (RBE) completely overwhelmed us to the point that we could no longer proceed with the evaluation. The RBE displayed by the HD4000 is very disappointing considering it is being marketed as a multi-media projector.
Operation report
The HD4000 never failed to start nor did it shut down. The projector recognized all interlaced and progressive signals when using the Component, Composite and S-Video inputs. The HD4000 also had no trouble syncing to a computer resolution of 1280x720 @ 59.94 Hz with the RGB input.
We did run into some trouble with the HDMI input. We tried many different resolutions and refresh rates with our G-Force based HTPC connected to the HDMI input and we were unable to establish sync with any of them. We have had no trouble synching with other projectors previously reviewed and the Optoma H-72 had no trouble syncing with the same HTPC with multiple resolutions and refresh rates.
In the past, we have been strong proponents of the Mitsubishi brand. The manufacturer has a strong track record of producing some of the best video display devices in the industry. Unfortunately this wasn't the case with the HD4000. Although it produced very bright vibrant images and nice deep inky blacks, we found the images' fine detail lacking. The HD4000 produced the dreaded rainbow effect more often than not and at times became almost painful to watch.
The HD4000s lackluster build quality, fit and finish, and the ho hum aesthetic characteristics of this projector made it look more like a board room projector than one suited for home theater applications. The lack of updated technical data and misinformation on both the Mitsubishi website and the marketing material had us wondering if the projector had been rushed to market.
We feel that this projector should have performed much better considering its relatively high price point and Mitsubishi track record. The Mitsubishi did produce very bright images and it has a 3-year warranty but other than that we don't believe this projector would be suitable in the home theater environment. We must say that we were disappointed with the HD4000's video performance and feel there are much better alternatives at much lower prices. The Mitsubishi HD4000 fell well short of our expectations and it is therefore NOT recommended.
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Detail and Resolution | ![]() |
Contrast and Black Levels | ![]() ![]() ![]() |
Color Reproduction | ![]() ![]() ![]() |
Calibration Options | ![]() ![]() ![]() |
Build Quality | ![]() ![]() |
Ergonomics & Usability | ![]() ![]() |
Features | ![]() ![]() ![]() |
Performance | ![]() ![]() ![]() |
Value | ![]() ![]() ![]() |
