Niles Audio ZR-6 Recalled Due to Fire Hazard
The following product safety recall was voluntarily conducted by Niles Audio Corp. of Miami, Florida in cooperation with the Consumer Product Safety Commission (CPSC). A failure in the Niles ZR-6 MultiZone receiver's internal components can cause connected loudspeakers to overheat and cause a fire, posing a fire hazard to consumers. Consumers should stop using the product immediately unless otherwise instructed and follow the instructions below to repair or replace the product. About 3,800 units are affected.
Name of Product: Niles ZR-6 MultiZone Receivers
Units: About 3,800
Distributor: Niles Audio Corp., of Miami, Fla.
Hazard: A failure in the receiver’s internal components can cause connected loudspeakers to overheat and cause a fire, posing a fire hazard to consumers.
Incidents/Injuries: The firm has received reports of three incidents of connected loudspeakers overheating. No injuries have been reported.
Description: This recall involves Niles® ZR-6 MultiZone Receivers. The receivers are black with a blue LCD display on the right side and the Niles logo in white on the front center. The receivers measure 17 inches wide x 3.5 inches high x 15 inches deep. The model number ZR-6 is located on the lower left side of the front panel of the receivers.
Sold at: Audio/video/home theater custom installation professionals nationwide from July 2008 through November 2009 for about $2,000.
Manufactured in: China
Remedy: Consumers should immediately stop using the recalled receivers and contact Niles for a free repair kit. The repair kit includes a software update for the receivers. Niles is directly contacting consumers who purchased the recalled receivers.
Consumer Contact: For more information, contact Niles at (800) 667-3991 between 9 a.m. and 6 p.m. ET Monday through Friday, visit the firm’s Web site at www.nilesaudio.com/ZR6Info, email the firm at ZR6Info@nilesaudio.com, or write to Niles Audio Corp., Attention: ZR-6 Recall, 12331 SW 130 Street, Miami, Fla. 33186
