Human Touch HT-1650 AcuTouch Massage Chair Review
- Product Name: HT-1650 AcuTouch Massage Chair
- Manufacturer: Human Touch
- Performance Rating:
- Value Rating:
- Review Date: June 08, 2009 01:05
- MSRP: $ 3999
- Upright Chair Dimensions: 62"L X 38"W X 49"H
- Reclined Chair Dimensions: 80"L X 26"H
- Weight: 245 lbs
- Seat Width: 22"
- Distance to Wall: 20"
- Recline Angle: 105-165 Degrees
- Massage Range: 27" (height Control/Width Control)
- Massage Robot: 3 motor, Quad Roller
- Chair Recline Operation: Power
- Auto Shut-Off: 15 minutes
- Warranty: 5 Years limited
- Shipping Box Dimensions: 64"L X 40"W X 30"H
- Excellent massage
- Multiple massage modes
- Seat massage
- Variable height settings
- Quiet (when arm massage disengaged)
- No cup holder option
- Arm massage kind of useless & loud
- Not inexpensive
HT-1650 Build Quality and Use
Home theater chairs are the finishing polish on a room that really makes an impact. While a good audio and video system is imperative to a quality experience, having a good set of leather chairs will really make a big splash on your guests. They really differentiate the dedicated theaters from those who simply shove a bunch of gear into a room. For the do-it-yourselfer, shopping for home theater chairs can be an exercise in getting the best bang for the buck. Those building a high-end dedicated room from scratch, however, are faced with so many options that it can take a lot of time and consideration to find just the right model. Since some of these premier chairs can run upwards of $3500 each, we've found another option that we feel should be tossed into the mix: massage chairs. To test out our theory, we received a high-end massage chair from Human Touch and set about evaluating it for use in a home theater setting.
Leather and All the Trimmings
The Human Touch
HT-1650 is a full-size massage chair that has an elegant and classic look. It
features top-grain leather, with leather match on areas not touching the body.
A beautifully finished hardwood trim adorns the base of the chair. The chair's
main body area features a mix of leather and fabric, to allow a vigorous Robotic
Massage that includes neck and shoulder areas. Dual-lumbar heat provides warmth
during massage - and excellent feature for sore muscles. What sets this chair
apart from others is its full-sized built-in foot and calf massager that can
retract completely into the chair when not used. Flip it over 180 degrees and
you get a leg rest that can be used when not being massaged. Underneath your thighs,
an air impulse massager fires off 8 different points into the seat which makes
for an incredible full-body massage.
The chair weighs a hefty 245 pounds and came delivered in full recline position with a thick cardboard box surround. The chair came in on a truck and the delivery company brought it into my home and removed all of the packaging. The chair is available in black and dark chocolate top-grain leather (we received the latter version). Once unpacked and delivered it was merely a matter of unpacking the user manual and power cable to get it ready. We plugged it into the wall and turned it on.
Using the Chair
There is a blue LED that lights up when you turn the chair on with the
rear rocker switch. We left it on all the time since the chair automatically goes
into shutdown once a program completes or the massage time reaches the maximum
15 minute cycle. The rear of the chair also features an accessory or
convenience outlet that is rated to 1A with a fuse. We enjoyed using the chair
as a "home base" while working on the laptop. In fact, we worked on
much of this review while sitting in the chair. The other part of the
electronics control system is the remote control, which is a tethered device which
has buttons on the top and left sides. We felt it a good decision to go with a
wired remote since a wireless product would most likely get lost in no time -
something that would be tragic with a chair featuring no on-board hard
controls. The remote is daunting at first, until you get a handle on the
controls and what each function does. The basic breakdown is that there are a
set of automatic program modes as well as manual controls for each aspect of
the chair.
- Full
body sore muscle relief
This ultimate stress relief program involved a heated full-body massage that included a 3-minute warm up, 9 minutes of high-intensity massage, and a 3-minute cool down. This mode actually spent a lot of time (for me at least) running the massage wheels over my shoulder blades - a particular annoyance I preferred to avoid. - Sports
back therapy
Focusing on areas most often affected by athletic training and back, this heated back/calf/foot massage included a 3-minute warm up, 9 minutes of high-intensity massage, and a 3-minute cool down. It was a nice mode that favored the lower body. - Leg
foot hip therapy massage
This program was seemingly designed to concentrate on massaging your rear leg muscles, calves and feet and maintained its intensity from start to finish. - Neck
shoulder relief
This heated upper-back massage included a 3-minute warm up, 9 minutes of high-intensity massage, and a 3-minute cool down. It was nice to have a mode dedicated to the neck and shoulders and this one got a lot of use in our home. - After
work stretch
A heated mid/lower-back massage plus a gentle body stretch included 3-minutes of warm up, 9 minutes of medium-intensity massage, and a 3-minute cool down. This mode seemed a bit underpowered since the chair was not designed to do a full inversion. - Morning
wake up
The morning program could be used at any time, but involved a heated full-body massage program includes a 3-minute warm up, 9 minutes of medium-intensity massage, and a 3-minute cool down. It's an ideal program when you don't want anything terribly rigorous. - Night
time soothing
This gentle and relaxing mode was one of my favorites for guests trying out the chair. It combined a heat with a full-body massage and included a 3-minute warm up, 9 minutes of low-intensity massage, and a 3-minute cool down. If there was one mode that got the most use, this was it. - Massage
demonstration
The demo mode gave a nice overview of all different types of massage techniques. I used this on guests quite a bit as it did a good job of demoing the chair's full capabilities.
Since the remote allows both pinpoint targeting of the robotic mechanism and a "Zone" massage, it was possible to target very specific areas with particular massage methods and get the most out of this chair. Even in manual modes the chair sets a 15 minute limit, though if you change into a preset mode or stop and re-start, the timer will reset as needed.
HT-1650 Home Theater Application and Conclusion
One thing that we
really liked about the Human Touch HT-1650 was its variable height settings.
The chair provides three different height settings that will vary the top-end
positioning of the robotic massage unit for neck and shoulder massage. This is
extremely important as a person who is 5' 6" and another who is 6' 6"
are going to have a hard time using the same massage path for their needs. What
I quickly discovered about the HT-1650 was that the chair could also be
inclined to allow for "in-between" height positions that didn't
necessarily fit to the three height settings provided. We weren't making up
numbers when we gave the height ranges above. We had lots of people come
through to try out the chair and it accommodated the entire range. The only
person left partially out of the fun was a wonderful neighbor who is only about
5' 2" tall. She was unable to fit her legs fully into the calf massager
and still get her back into the corner of the chair for a massage. In
situations like that we simply flipped the foot and calf massage system over
into a standard leg rest.
The Home Theater Experience
We could easily
envision placing several of these chairs side-by-side in a room. In fact, with
a larger custom theater room it would make all the sense in the world to
provide a nice massage during the previews which often fill up the first 15
minutes of a new Blu-ray movie. I mean, that's just the perfect amount of time
for a full massage cycle, isn't it? We used the Human Touch HT-1650 Massage
Chair in one of our theater rooms and found the noise levels to be far above
what we'd want during an actual screening, however (with the arm massage mode
off) it was indeed quiet enough to use the chair during the non-critical
previews section of each disc. In addition, the motorized recline, leather head
pillow, and retractable foot rest made this chair quite a bit more comfortable
than my entry-level Berklines. One thing Human Touch could add to its
collection would be a modified version of the HT-1650 which provided a shorter
back to allow better sound transmission from the surround speakers to your
ears. It would also do better to allow for multi-row seating configurations.
Another nice option would be for the massage chairs to be purchase in groupings
of 2, 3 and 4 chairs in preconfigured straight or arced arrangements. That
might be wishful thinking, but I see a market that's just waiting to be tapped
into.
Human Touch has delivered the very best it has to offer in the HT-1650 Massage Chair. Its versatile programming and convenient automatic massage programs make this one of the easiest-to-use, and also the most customizable massage chairs for the money. Putting those two attributes together isn't easy and means high praise in a very competitive market. We'd love to see Human Touch and others enter the home theater and custom A/V installation market with chairs well-suited for the needs of retailers and designers. As audio and video components evolve into more sophisticated products, why should home theater seating be any different? It's time consumers demand more from their chairs than motorized recline mechanisms. It's time for a massage chair revolution!
Human Touch HT-1650
$3999
Human Touch
3030 Walnut Ave.
Long Beach, CA 90807
(800) 742-5493
www.humantouch.com
About Human Touch
Human Touch is the leading provider of high quality
innovative lifestyle products and experiences that deliver indispensable, life
changing benefits to an ever growing number of consumers.
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Performance | ![]() ![]() ![]() ![]() ![]() |
Ergonomics & Usability | ![]() ![]() ![]() ![]() ![]() |
Ease of Setup/Programming/Integration | ![]() ![]() ![]() ![]() |
Features | ![]() ![]() ![]() ![]() |
Remote Control | ![]() ![]() ![]() ![]() |
