Standout Designs Majestic Angle e5822 TV Cabinet Review
- Product Name: Standout Designs Majestic Angle e5822 TV Cabinet
- Manufacturer: Standout Designs
- Performance Rating:
- Value Rating:
- Review Date: May 27, 2009 22:38
- MSRP: $ 1,399 and up
- Wood Parts
- Solid 4/4 Pennsylvania White Ash (Black and Espresso)
- Solid 4/4 Pennsylvania Soft Maple (Cinnamon)
- Finished Panel Thicknesses
- Top, bottom, ends, partitions, 13/16"
- Door frames, back panels, side shelves, 3/4"
- Glass Door - Tempered Safety, 1/8", seamed edge
- Glass Shelf - Tempered Safety, 1/4", pencil edge
- Feet - Steel, nickel plated, brushed satin finish
- Knobs - Aluminum, nickel plated, brushed satin finish
- Hinges - Salice 6-way adjustable cup, nickel finish
- Wheels - 50mm diameter, fixed, polyurethane
- Low VOC water-based stain
- Conversion varnish topcoat
- Sherwin-Williams industrial/professional
- All surfaces finished, including backs and interiors
Dimensions:
- Overall Cabinet: 22 x 58 x 22
- At the widest: 18 x 19-3/4 x 16-1/4 (each)
- At the deepest: 18 x 16-1/16 x 19-5/8 (each)
- Side Shelf Areas: 18 x 7 x 8-1/2 (each)
- Distance from wall to midpoint of back: 17-7/16"
- Distance from front corner to start of taper: 10-3/8"
Weight Capacities
- Total Weight: 450 lbs max
- Top Shelf: 200 lbs
- Glass Shelf: 50 lbs each
- Bottom Shelf: 85 lbs each side
- Beautiful design
- Comes fully assembled
- Very flexible installation options
- Smallish cut outs for routing cabling
Introduction
The most often forgotten about component in a home theater system is the
storage device in which your precious equipment is contained. Some folks choose to place their gear in
metal racks while others favor more decorative solutions that blend in with
their room décor. One thing that always
irks me about A/V furniture is the assembly process. I’ve assembled so many of these in the past
that I no longer have the time nor inclination to do another one. Enter Standout Designs, a premium A/V
furniture company that ships fully assembled A/V racks. Unlike most no name prefab stuff sold at
department stores, their products actually don’t suck. The Majestic Angle e5822 was actually
designed to accommodate real A/V gear and not the pretend cardboard box cuts
outs that are often shown on the display floor.
Read on to take a tour of the Majestic Angle and find out why I think
it’s truly a unique product for its genre.
Design Overview & Set-Up
The Majestic Angle e5822 TV
Cabinet (what a mouthful) by StandOut Designs is not like your run of the mill
A/V furniture. The Angle is made from Pennsylvania solid lumber
chosen for its beauty, strength and sustainability. You won't find any cheesy particleboard,
MDF, veneer, or laminates on this product.
Even the back panel is made from responsibly-harvested American solid wood. On that topic, I find it refreshing that not
only is StandOut Designs producing green friendly products, but they are
building them right here in the USA! Now
that is something you rarely find these days.
The Angle comes in 3 finish options (black, espresso, or cinnamon for a
$50 upgrade option). I chose Cinnamon
for my review sample.
Since the Angle comes fully assembled (sans the glass shelves and door covers), it shows up on a large truck in a very big and heavy box. The delivery company had a lift gate to unload this furniture which was quite hefty. The cabinet with the glass weighs approximately 125 lbs in Ash and 115 lbs in Maple. Total shipment weight is about 185 due to the pallet. Packaging is all recyclable. My review unit came undamaged thanks to the very thorough packing job of StandOut Designs. Once I got all the packing off the cabinet, I gazed at the beauty of the real wood and workmanship of this product. I then noticed the silver feet hoping that they had hidden wheels to make my job of moving this cabinet into position on my parents' hardwood floor easy and stress free. StandOut Designs didn’t disappoint. The Angle's stylish brushed nickel feet feature concealed fixed wheels plus levelers adjustable from inside the cabinet making moving and leveling on floors easy. Now that is how I like to roll, and it is obvious StandOut Designs is on page with me.
The Angle comes standard with clear glass doors but they also shipped me their upgrade glass tint and speaker grill covers. They also offer wood panels for the doors which I don’t recommend unless you are using an IR repeater system to control your equipment. I installed the tinted glass in the doors because they looked fabulous.
A close inspection of this
cabinet revealed to me that a lot of thought went into its design to allow the
end user great flexibility for installing their A/V gear. For one, the cabinet depth was over 19
inches. Most A/V furniture I’ve seen is
no deeper than 16 inches making it impossible to install anything but an entry
level receiver and have enough depth to run wiring. I didn’t have this problem with the Angle as
I installed a mid priced Denon A/V receiver into it with with ample room to
spare. Peering
inside the Angle, I was plesantly surprised to find many drilled out holes to
route cabling between shelves and the two equipment bays. I did however
sometimes wish the bottom holes were a bit larger or perhaps oval shaped to
accommodate the myriad of thick speaker cables and power cords I routed to
connect my system.
I was happy to see venting holes at the bottom of the cabinet as well as thermistor controlled fans in each equipment bay. Each enclosure bay features a thermo-controlled exhaust fan that spins at 1000 RPM, emits less than 16 dBa, yet moves nearly 40 CFM. Controllers turn fans on at ~87 F and off at ~80 F using an external probe at the source. StandOut Designs claims the fans feature quiet, long-lasting SONY-designed fluid dynamic ball-bearings. That sounds cool to me, no pun intended. You can mount the fans on the outside of the cabinet should you require more cabinet depth to accommodate bigger gear. I left the sensor probes behind the gear instead of on top. During my testing, I didn’t hear the fans come on at all as the ambient temperature just didn’t get high enough to warrant them.
The glass shelves have a big circular hole in the center for ventilation and even routing cabling if you need to. This again demonstrates the installer friendly mindset of StandOut Designs.
During the installation process,
I was getting a bit annoyed of snaking cabling through the smallish holes and
wished that the backpanel would come off.
I was perplexed by the removable screws on the backpanel so I took them
off to see what would happen. The result
was nothing. The back panel seemed affixed
to the cabinet regardless of the screws being on or off. I continued doing the install and noted that
I would list this as a con in my review.
Finally I have something genuine to complain about… or so I
thought.
When I went on StandOut Designs website to get some product info, I noticed in their bulleted features that the back panel was in fact removable. They even proved it with a picture. In speaking with StandOut Designs, they instructed me how to remove the backpanel more easily. Using the screws as a lever, you simply slide the panel to one side while lifting out which is admittedly is not easy if the fan panel is in place. I will revist this on my next trip to my parents' house and bring along my rubber mallet to give it a few whacks just incase the panel doesn’t come off for me.
Despite the back panel being removable, I do wish the manufacturer would have provided a larger cutout on it to route cabling through. All of the speakers in my parents A/V system are in-walls and thus their cabling is terminated on the wall behind where the cabinet resides. It would have been easier for me to route all of the speaker cables throught the back as opposed to snaking them throught the bottom of the cabinet. A wide cut out towards the bottom of the back panel that spans both equipment bays would have been ideal especially since most people would likely place their A/V receiver and power conditioner on the bottom shelves like I did. StandOut Designs informed me that they try to keep openings in the rear to a minimum in order to force the fans to draw air from the front of and through the cabinet. They are however considering offering larger openings for easier cable routing in future iterations of this product.
I also noted towards the back sides of the cabinet, behind the storage area for CDs/DVD’s, there is a considerable empy area on both sides of the unit that probably could have been more cleverly utilized for cramming cables intofor tidying up the install. There, I am glad I finally found a valid cricism or two of this fine product.
For those wishing to integrate a home theater system into their family
or living room and are mindful of blending it into their room décor, the
Majestic Angle e5822 from StandOut Designs may be the product for you. Its
construction and quality of materials are light years beyond much of the run of
the mill junk you find at department stores.
Despite the fact that so many people wall mount their flat panel
displays these days doesn’t negate the necessity of a storage place for their
A/V equipment. The Angle gives you the
option of placing itself under your wall mounted display or placing your
display on top of it. I installed a
brand new 52” Samsung 1080p on top of the Angle with no issues and in fact
could have even placed a larger display on it as the top shelf is rated to hold
up to 200lbs. Considering the thoughtfulness of design that went into
making this product a truly dedicated A/V furniture rack and the fact that it’s
not only affordable but made in the USA, means it gets my highest
recommendation!
Standout Designs Majestic Angle Summary
Standout Designs
700 Hepburn Street, Suite 17
Milton, PA 17847
(877) 325-9663
http://www.standoutdesigns.com
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Ease of Setup/Programming/Integration | ![]() ![]() ![]() ![]() ![]() |
Features | ![]() ![]() ![]() ![]() |
Appearance | ![]() ![]() ![]() ![]() ![]() |
Performance | ![]() ![]() ![]() ![]() ![]() |
Value | ![]() ![]() ![]() ![]() |
