RBH Sound EP1 Noise Isolationg Earphones Review
- Product Name: EP1
- Manufacturer: RBH Sound
- Performance Rating:
- Value Rating:
- Review Date: August 19, 2012 19:00
- MSRP: $ 149/pr (includes FREE Shipping)
RBH Sound EP1 Specifications
- Model Name: EP1
- Drive Size: 13mm Dynamic Dome
- Impedance: 16 Ohms
- Frequency Range: 14Hz~18KHz
- Sensitivity: 101dB
- Noise Isolation: 16dB w/Comply™ Foam Tips
- Input Connection: 3.5mm mini-jack
- Cable Length: 1.2m
- Color: Black/Pewter
- Great bass response
- Plays loud and clean
- Tangle free cord
- Noise Isolation
- Tricky installation of silicon ear cushions
- Doesn’t have all the bells and whistles of competitors
RBH Sound EP1 Introduction
I’m not a fan of earphones. Personally, I don’t like sticking anything in
my ears unless they are made of foam to protect my ears from loud concert
events or keep me isolated from my snoring spouse. But, when Chief Engineer Shane Rich from RBH
Sound paid me a visit to help install their new super Status Acoustics 8T
towers for review, he handed me a little black box marked EP1 and asked me to
check them out. Figuring it was some
sort of esoteric tweak, I opened it with reservation only to find RBH branded
earphones. Really?!? I thought to
myself, do we need more earphones on the market? Shane claimed these were a little different
and knowing the RBH reputation, I decided to give them a listen. Is there really room in the market for
another earphone manufacturer? Let’s find out.
Design Overview
The RBH EP1’s come housed in a black cardboard box with a magnetic opening flap. They have a foam insert to rest the drivers in and a carrying pouch to store the extra earbuds or to stow the earphones when traveling. They come with four pairs of ear cushions. Three of the four pairs are silicon type of various sizes (small, medium and large) and the 4th pair are foam from a company called Comply. The foam tips provide the maximum isolation from outside noise and from my experience they also produce the most powerful bass response as well. Extra pairs can be ordered from Complyfoam.com.
RBH EP1 Magnetic Package
Most run of the mill earbuds use 9mm transducers or worse they use dual smaller drivers to make them two-way designs. I’ve found two-way in-ear headphones to be at a disadvantage to good single driver designs since the smaller high frequency driver is often dynamically limited and by using two drivers in such a small enclosure, the bass response often suffers as well.
While the RBH EP1’s look similar to every other earphone on the market, they are in fact a bit unique in one regard. They have the largest transducers I’ve seen in earbuds before. A pair of really great Denon’s I own use 11mm drivers. The RBH’s use 13mm drivers. What does that mean? Bass. Deep extended bass with the ability to play louder than its smaller competitors. The EP1’s are also touted as noise isolating earphones providing up to 16dB of noise isolation when used with the foam tips. This allows the end user to lower the noise floor from their surrounding environment to hear more of the subtle details of their music.
A close examination of the EP1 earphones reveals that they are constructed with premium materials such as an aluminum housing, gold plated jack connectors and a nifty cloth woven cord that is not only more flexible than the typical PVC cable, but also is far less prone to tangling. They are rated at 16 ohms and 101 dB sensitivity. The impedance is a bit lower than I’ve seen from typical earbuds but I didn’t have any issue driving them to satisfactory levels from my laptop or IOS devices.
The user manual gives instruction on changing out the ear cushions which weren’t particularly helpful when I was trying to swap out the silicon ones. Let me warn you, these are a bit tricky to change out. I found the best way to accomplish this was to turn them inside out and squeeze the barrel while twisting it onto the earbud. RBH actually made a YouTube video about this to illustrate it.
I feel obligated to point out the legal disclaimers that RBH dedicated a great deal of real estate in their tiny user manual. They warn about prolonged exposure to >85 dB SPL, especially when using the foam tips which provide the best coupling mechanism directly to your ear drums. They want you to listen for life so keep the volume level in check. I found it mildly amusing that they suggested in the event if one of the silicon tips become lodged in your ear to immediately consult your Audiologist. I will keep his number on hand any time I use these babies J
Listening Tests
I used a variety of source equipment with the RBH EP1’s including the headphone output of my desktop computer DVD player, my iPhone 4 and the Micro preamp and DAC courtesy of Headroom. I did most of my listening using CD’s and Pandora.com streaming music services with a paid subscription for commercial free higher resolution audio playback.
Phil Collins I Don't Care Anymore (left); Rush Moving Pictures (right)
Peter Gabriel: Love Town
The opening bass track displayed nice deep extension that I typically don’t hear from in-ear headphones. Peter’s voice came out clear and distinct. The highs sounded a bit compressed when played through my iPhone but when I cued up the same track using my Ethernet connected PC and bypassed the internal dacs and preamp in favor of my Headphone DAC/Preamp, the sound greatly improved. For casual listening, its fine to use a smartphone but anyone serious about fidelity should feed these babies the best quality source material and audio components possible.
Phil Collins: I Don’t Care Anymore
How could I do a listening test with Gabriel without including Collins in the mix? After all they were old chaps back in the glorious days when super group Genesis was first formed. The bass drum had great body and you could hear Collin’s masterful skill bouncing the sticks off the toms.
Will Smith: Getting’ Jiggy Wit it
The EP1’s really showed off their bass prowess on this song. With the Comply foam cushions, the experience was akin to one of those bass cars. The silicon tips toned this down to a more balanced level while also tightening up the response. Will’s voice was forward and clear and the stereophonic reverb effect added to the recording was clearly pronounced.
Bass was warm and forward but a bit overpowering using the foam tips. Switching out to the silicon tips, the bass was less pronounced and allowed me to focus more on Lee’s incredible guitar work. The symbols were clear but didn’t have quite the airiness of extension as I’ve heard on the very best over the ear headphones. This should come as no surprise however as in-ear headphones are ALWAYS at a disadvantage to quality over the ear types. You’re trading ultimate sound quality for portability and convenience, but RBH managed this feat better than most, if not all, competitor in-ear headphones I’ve listened too.
Bob Marley: Jammin
Man if you’re body doesn’t get moving to this Bob Marley classic you need your pulse checked. I loved the female supporting vocals overlaid over Bob’s voice. One thing that always draws me to Bob Marley music is the bass. The RBH EP1’s didn’t disappoint here.
Celia Cruz: La Vida Es Un Carnaval
This is a classic among Latin folks and I really dig this tune. Celia has a distinct alto, almost masculine tenor voice that just draws you in. The constant trumpet hook in this song really captivates you and the percussive work is just fabulous. It’s no wonder Celia Cruz was one of the premier salsa artists of the 20th century and worked closely with legends like Tito Puente. She rocked!
Rush: Subdivisions
My all time favorite Rush tune, I simply can’t help but play air drums to this song when I hear it. I also typically run to my digital piano shortly afterwards to play the wonderful keyboard track that Geddy conjured up for this masterpiece. The RBH EP1’s gave me a convincingly enveloping experience with this song.
Emerson, Lake & Palmer: Pirates
Easily one of my all time favorite progressive rock songs, Pirates is epic. From the very beginning of this tune, you realize you’re in for a treat with one of the world’s finest keyboard players of all time. Emerson’s ability to combine signature electronic synthesizers blended with piano and a full orchestra is just mind boggling. I would have loved to experience this song live back in their hay day but I was still crawling in diapers at the time. Greg’s voice came through with great clarity though not as full bodied as I’ve heard on my reference Sennheiser over-the-ear headphones. For songs with somewhat anemic bass like this one, the Comply foam cushions worked better from my experience by yielding a much needed tonal shift to the lower spectrum.
RBH Sound EP1 Recommendations
You need to experiment with the variety of cushions in order to achieve the best sound to your ears with the RBH EP1 in-ear headphones. I achieved the best bass results using the Comply foam cushions but at times it was almost too powerful. The large silicon cushions worked the best for my ears. The smaller sizes just didn’t couple well with my ears and resulted in very poor bass response, verifying that achieving proper fit is very important. I also found that they way you insert the earphones into your ear made the world of difference as to how they would perform. I achieved the best results with the speaker driver oriented below the ear cushion when inserting them into my ears. When I did a first listen, I didn’t pay attention to how I was installing them in my ears and I was very underwhelmed with their bass performance as a result. Use care when installing the EP1’s in your ears. Most importantly, since the EP1’s can play extremely loud with low distortion, listen responsibly.
RBH EP1 Comply Foam Tips(left) & Silicone Tips (right)
The
RBH EP1s lack some of the features of competitor products such as volume
control and a microphone which for pure music listening shouldn’t be a show
stopper. As far as in-ear headphones,
the EP1’s are about the best set I’ve ever listened to. They produced excellent bass response
(assuming you pick the right ear cushions and positioning for your ears) and
were able to play cleanly at much louder than safe listening levels. Their overall tonal characteristics seemed to
be pretty well balanced though the midrange was a tad thin at times depending
on source material. Anyone looking for
respectably good performance from a pair of portable earphones would be remiss
not to check these babies out. While I still
adore my over-the-ear open-air Sennheiser HD 600 headphones, I wouldn’t dream
of bringing them on an airplane or to the gym.
The RBH EP1 in-ear headphones give you portability and good fidelity so
you can enjoy music on the go. They are
comfortable to wear, provide effective noise isolation and the woven cloth
cable prevents tangling, something I’ve always wrestled with when dealing with
conventional earbuds. Best of all, RBH
sells these babies direct for $149 (including shipping). They even come with a 10% off coupon
redeemable for a second pair purchase. This
is the first RBH product available for online sale and we certainly hope it
won’t be the last. Recommended!
MSRP: $149/pr (free shipping)
RBH Sound
382 Marshall Way
Layton, Utah 84041
General phone & FAX
Toll-free: (800) 543-2205
Local: (801) 543-2200
FAX: (801) 543-3300
About RBH Sound
RBH Sound, one of the older speaker companies in the USA, is still run and operated by the original founder - Roger Hassing. In 1976, RBH Sound produced its first loudspeaker. RBH soon began to OEM for McIntosh, (back in the days of Gordon J. Gow), providing cabinets for their speakers. This set the stage for doing a superb job since McIntosh didn’t worry about how to cheapen the product, but to make it better and, at least at the time, lead the class in performance. Later, RBH Sound began producing loudspeakers for a retailer in Los Angeles called Northridge Audio. They didn’t advertise or market these products to avoid a conflict of interest with their other OEM customers (i.e. McIntosh, Parasound, Fosgate, etc). People nonetheless sought them out because of their high performance, which lead to a good success story and response for their products. Over the years, RBH Sound was successful at helping other companies in achieving their goals. Based on their strong engineering background and sourcing ability, they took it upon themselves to enter the market under their own banner.
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Appearance | ![]() ![]() ![]() ![]() |
Treble Extension | ![]() ![]() ![]() ![]() |
Treble Smoothness | ![]() ![]() ![]() ![]() |
Midrange Accuracy | ![]() ![]() ![]() |
Bass Extension | ![]() ![]() ![]() ![]() ![]() |
Bass Accuracy | ![]() ![]() ![]() ![]() |
Dynamic Range | ![]() ![]() ![]() ![]() |
