Logitech Wireless Headphones for PC
- Product Name: Wireless Headphones for PC
- Manufacturer: Logitech
- Performance Rating:
- Value Rating:
- Review Date: May 17, 2006 20:00
- MSRP: $ 129.99
Headphone track controls work with:
- Decent battery life
- Convenient with small form factor
- Good wireless range
- Flawless connection and setup
- Works with nearly all media players
- Uncomfortable to wear over long periods
- Annoying beeps (low battery, track skip, standby warning)
- A tad lacking in upper-mid detail
- No configurable options
Installation & Build Quality
We made a commitment some time back to introduce a series of reviews on various headphones and accessories. While we haven't yet opened up "Headphonaholics" we have started down the road of evaluating basic headphone designs and listening to a number of units to determine what it is that makes a pair of headphones – in this case headphones – effective and good performers. The Logitech Wireless Headphones for PC (kind of like calling your dog "Dog" isn't it?) appeared to be exactly the sort of item we wanted to evaluate for those looking for a convenient way to listen to music, unencumbered, while at their PC. MP3 listening and gaming have exploded in the past several years and I haven't met too many people who like to be encumbered by wires – at least not at their PCs. The question on my mind, of course, was whether the wireless systems would perform in a manner that would make them a good value in comparison to their wired counterparts. Possibly more important, however (and more appropriate) is how they fare against other
Packaging & Installation
The Logitech Wireless Headphones for PC arrived in a nice retail package that showed off the major components of the Wireless Headphones. Installing the headphones consisted of plugging in the USB music transmitter and charging the headphones fully before the first use. WindowsXP handled the rest, installing all of the necessary drivers and making the experience a flawless one with no hitches. The headphones show up as “Logitech Music Anywhere USB” under the sound playback device and you can easily change this to your default sound card should you wish to output audio through your regular outputs. Logitech provides three flavors of these headphones with the other two being targeted for MP3 players and the iPod (the main difference is in the transmitter).
Headphone Design & Build Quality
The Logitech Wireless Headphones for PC are an open style with a behind-the-neck headband design. I’m not a big fan of this design as I think it’s more trendy than ergonomic or comfortable. I have yet to see a pair that will snugly fit my smallish head. As a result, they tend to dangle and place the weight on my ears. The headphones come with several nice features:
- Additional set of ear pads
- USB 2.0 extension cable & desktop stand
- USB 2.0 Bluetooth (Logitech dubs their flavor “Music Anywhere”) music transmitter
- DC power charger (plugs directly into the headphones (the USB 2.0 Bluetooth transmitter is powered by the USB port on your computer.)
The headphones weigh 3.3 ounces – which at first seemed light, but after a couple hours of use began to strain the ears as my head did not supply any relief for the weight of the headphones. I found that I could not comfortably wear the headphones for extended periods of time; however – since everyone’s ears are different – this may not be the case for other users.
The phones and USB music transmitter include a pairing button that doubles as a standby (think of it as an on/off) control. Volume, as well as track forward and back buttons, are also provided in a very convenient arrangement on the right side. The controls are more convenient than several other wireless headphones I have experienced and are easily accessed when the phones are worn. A DC charger connection is provided on the bottom of the right headphone driver as well. It is a custom 4-pin connection and makes putting in the connector upside down almost impossible due to a couple of well-placed detents. Using these headphones could not be any easier.
Headphone LED Indicators
The Logitech Wireless Headphones include a color coded LED system for identifying status during use:
Blinks Blue (sets of 3) – powered on and connected
- Fast, blinks blue – Powered on, not connected
- Fast, blinks red – Low battery
- Solid orange – charging internal battery
There is also an audible alarm beep which engages during periods of inactivity and as a low battery warning. I found the incessant beeping to be extremely annoying and wondered why Logitech did not include a control panel or application to disable or reconfigure this function. The volume of the beep could not be adjusted. If you keep the headphones charged and don’t wear them during periods of inactivity you probably won’t come across this often.
Two-channel Listening Evaluations
As is now typical in my evaluation of headphones I utilize a reference set of Etymotic ER-4 MicroPro Earphones and a cheap pair of $3 headphones as a top-bottom baseline comparison. The Etymotic earphones, while relatively flat, are not the most pleasing earphones to listen to (which is why Etymotic also makes the ER-6 and 6i Isolator Earphones) and they can be fatiguing over time. The $3 headphones, well, they put out sound… No highs, no lows (similar to a cube speaker we all love to hate), just a somewhat compressed and distorted mid-band. With that understood, the concept is to compare the frequency response of the review headphones against the flat reference set and use the $3 set as the worst-case quality (i.e. base rating of 1) for the “below minimum expectations” point. Other reviewers may have a different methodology, but this seems to yield a fair way to rate various types of headphones.
Toy Matinee: Toy Matinee (CD)
Queuing
up “Last Plane Out”, the first thing I noted on the Logitech Wireless
Headphones was the well-rounded bass. It was full and rich – perhaps
overly so – but in a pleasing way. The music sounded good – it was
quite enjoyable. The track’s vocals were somewhat muffled-sounding with
an obvious lack of top-end. It was during the dueling guitars that this
extra crispness of detail was really missed. “The Toy Matinee” provided
additional detail during the intro of the track and throughout the
chorus as each instrument seems to pick out a space within the
soundstage. There was an almost intimate vocal presentation. When I
switched back to the reference earphones I realized that the mix was
incredibly sensitive and that the Logitech’s had picked up on this. I
wished that some of the high end and upper mid detail was a bit more
present in the wireless headphones. Excessive reverb abounded in this
track, which on a detailed set of speakers is a torture test for both
room acoustics and your loudspeakers’ ability to handle detail without
blurring the track. In the case of the Wireless Headphones for PC, the
track came off a bit muddied, though still extremely pleasing to the
ear. There is some very low frequency bass material in this track and I
was surprised at how well it came through the Logitech Wireless
Headphones. “We Always Come Home” was the final track I queued up for
this album and I felt that the vocals took on a slight boxy feel
compared to my reference ER-4s. The low end was far more pleasing in
the Logitech phones, though I perceived that it was overaccentuated…
but I doubt anyone will be found complaining about that.
Seal IV
Perceiving
that the strength of the Logitech Wireless Headphones was its ability
to create a well-rounded frequency response with special consideration
for bass frequencies, I decided to pop in some Seal and listen to see
if the headphones would get overloaded and distort with too much bass.
“Get It Together” was the first track I put up for evaluation and I
immediately noticed the accentuated lower midrange, especially
noticeable with Seal’s vocals. The rolling bass notes were cool and had
a nice sound, though I wanted them to be much tighter. The Logitech
headphones still performed admirably overall. “Waiting for You” was
next and the headphones presented a nice thumpy bass line. It was about
this time that I really started to clue in that the Logitech headphones
are particularly easy to listen to. They are completely non-fatiguing
as far as the sound goes, meaning that I did not perceive audible
distortion. This was especially apparent on this album where I knew I
was feeding them subsonic frequencies they could not adequately
reproduce.
MP3s and iTunes
I
utilized iTunes and my massive music library to see how well MP3s would
sound on these headphones. I enjoyed the experience and played a wide
arrangement of tracks, including Country, Heavy Metal, Pop/Classic
Rock, Jazz and (gasp) Hip Hop. I was pleased with all that I heard,
though the Jazz again revealed the telltale lack of upper-mid detail
that I look for when reviewing loudspeakers and headphones. Hip Hop
tunes and anything with a truly low-end response sounded good, and I
was surprised to find that the headphones reproduced down to around
35Hz with reasonable ease (I measured down to 30Hz with a tone
generator before it dropped off in real audibility).
Gaming
I
think that perhaps gaming is the hidden calling of the Logitech
Wireless Headphones. Using these beauties with games such as Unreal
Tournament 2004 and Doom 3 was quite satisfying. These headphones do
well with bass, and here is where the massive explosions and low
frequency sound effects typical in gaming finds a good home. In
particular, when playing Unreal Tournament, the explosions and musical
score kept me entertained as I hurled rockets and countless rounds of
ammunition at my fellow players. Stereo separation was good and the
headphones worked well in helping me identify the location of other
players within the game.
Conclusion and Recommendation
It is obvious that Logitech put some time into designing and bringing the Wireless Headphones for PC to market. They handle a wide frequency response and do very well at allowing the user to listen for extended periods of time without fatigue – in fact, you will find the headphones get physically uncomfortable long before your ears tire of listening to them. The big question is: Do these style of headphones warrant the high price that is commanded for wireless Bluetooth sets? I would have to say that the answer will be up to the user to decide. For my part I believe this category of product to be somewhat overpriced as the market adjusts to a “budding” technology and competition has not yet blossomed. There is no question, however that the convenience of wireless headphones is undeniable and I don’t know a single person who would not give quite a bit of their hard-earned cash to become untethered from their PC. The final choice will be up to you. In the existing market, the Logitech option seems well-placed and quite competitive (with some other manufacturers pricing their products at almost twice the cost).
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Build Quality | ![]() ![]() ![]() |
Appearance | ![]() ![]() ![]() |
Treble Extension | ![]() ![]() ![]() |
Treble Smoothness | ![]() ![]() ![]() |
Midrange Accuracy | ![]() ![]() ![]() |
Bass Extension | ![]() ![]() ![]() |
Bass Accuracy | ![]() ![]() ![]() |
Imaging | ![]() ![]() ![]() |
Soundstage | ![]() ![]() ![]() |
Dynamic Range | ![]() ![]() ![]() |
Fit and Finish | ![]() ![]() ![]() |
Value | ![]() ![]() ![]() ![]() |
