Bluetooth Headphones Review: ANYCOM BSH-100
- Product Name: BSH-100 Bluetooth Headphones
- Manufacturer: ANYCOM
- Performance Rating:
- Value Rating:
- Review Date: August 15, 2006 20:00
- MSRP: $ 199
Specification Bluetooth SIG: Bluetooth
1.2 |
Operation: 4 buttons for volume
up/down, call answered/end, redial/mute, next/previous title,
pause/start |
- Long battery life (plus dual Li-ion batteries)
- Most comfortable Bluetooth headphones we’ve used
- Easy to use and connect
- Works simultaneous with cell phone and PC
- Great range
- Poor, compressed sound quality
- Awkward volume buttons
- Unpredictable re-syncing issues when using with both phone and PC
- Unimpressive WindowsXP compatibility resulting in constant resyncing and loss of microphone use
BSH-100 Heaphones Overview and Range
If you’re like me, you spend a lot of time on the computer while also being
anchored to a nearby cell phone. With the advent of 802.11a/b/g/n and Bluetooth,
wires and PCs are now officially mutual enemies. So what’s the typical office
worker to do when trying to “decouple” oneself from all the cabling which
tethers you to your desk? Well, for one, get a pair of wireless headphones… and
a Bluetooth phone. Now make sure the headphones work on both at the same
time. What? That’s right, just like the new automobile Bluetooth systems can
interrupt audio playback for incoming cell phone calls, the ANYCOM BSH-100
headset can suspend audio from the PC for an incoming phone call. This goes
beyond the trendy, cool gadget and into the realm of the Truly Useful*. If
you’ve never experienced this, welcome to the next level.
*provided your phone is compatible and “releases” the Bluetooth connection as needed.
Form and Function
I immediately liked the look of the
ANYCOM BSH-100 headphones. They come with thickly padded
earphones and felt much more comfortable as a result. The
system is shipped with quite a bit in the packaging. In addition to the
headphones the packaging included an integrated, removable USB microphone, the
Audio Gateway, audio connection cable, USB DC charger, and two mini USB
cables.
The headphones collapse in the middle with a hinge. This unique feature allows them to be more easily stored and packed away, making them a bit more portable than many other models we’ve seen. The plastic headband wraps around the head and rests gently on the tops of the ears. I found that after wearing them for about an hour the tops of my ears began to get a bit sore. This is, unfortunately a result of both my particular head shape as well as the nature of a behind-the-neck headphone design (which I feel is trendy, but flawed).
I noticed the online description for these headphones said they would be suitable for jogging – I wouldn’t recommend that. Shake your head too much and the headphones will likely fall off or at the very least move away from the optimal ear position. For exercising, earbuds remain king.
Range
The range on
these Bluetooth headphones was very impressive. I was able to walk from my
office (the source and location of the USB-200 BT adapter) into the adjoining
room, then on to the dining room and further around another corner. By the time
the signal started breaking up I had about 30 feet and 2 plaster/drywall walls
between myself and the USB-200 transmitter. No matter how you slice it, that’s
pretty impressive for a Bluetooth device.
The only issues I experienced, in fact weren’t range related but with re-syncing the headset to both the PC and cell phone once one was out of range or shut down, severing the dual connection. This was a scenario that had no pattern and the only way to successfully reset everything back to “right” status was to restart the PC. To get the microphone to work with VOIP again I actually had to reinstall the software… and reboot… and reinstall the software… and reboot… you get the picture. I personally chalked it all up to the relative infancy of Bluetooth and the fact that it was basically grafted into WindowsXP. Perhaps the next edition of Windows will have somewhat better integration.
BSH-100 Headphones Use and Conclusion
Using the system as a headset means that you plug in the included USB microphone and don the unit for use with VOIP sessions and general computer chatting. I used the headset with Skype (both chat and VOIP) and found it to be completely adept at communicating with others. The mic had sufficient pickup and the headphones allowed me to hear conversations without creating the "echo effect" for other users - a common occurrence when doing VOIP with loudspeakers. It took me a bit of getting used to the Bluetooth methodology. For example, if the headphones go out of range for too long, go into standby, or the power dies, you have to "re-connect" under "My Bluetooth Places". For some reason, my WindowsXP machine would not automatically reconnect - and this again seemed to be a Bluetooth implementation limitation in WindowsXP rather than an issue with the BSH-100 headset.
As mentioned in the introduction, one of the coolest aspects of the BSH-100 was its ability to be paired to both the PC USB adapter and a cell phone at the same time. When an incoming call would arrive, the phone would switch over to the incoming cell phone and I could answer the call. By simply pressing the Multi-Function Button you switch back from the cell phone to the PC. This was very impressive when it worked, and rather frustrating when it didn't. As I mentioned previously, cell phone support varies, and the Bluetooth and WindowsXP protocols are not exactly the most user-friendly and robust systems on the planet and so expect to have to reacquire and fiddle with settings any time something changes (battery, power cycling, etc). The bottom line is that quite frequently you had to drop the ANYCOM BSH-100 from the cell phone in order to use the headset on the PC, and vice versa.
Headphones Only - Bluetooth High Quality Audio Mode
Stereo headphone use was a bit more critically reviewed than the headset mode - meaning that now I was listening for fidelity. I am sad to report that there isn't much. These headphones sound like a $0.50 driver with no highs, no lows, and lots of compression. A more robust description is as follows: harsh high frequency response with lack of detail and extension, absence of low frequencies and a boxy midrange. Male vocals appeared to come from behind a thick piece of paper. Upper midrange seemed to be the strength, but an abundance of compression ruined any of the potential positives. I don't mean to be so blunt, but while Bluetooth is not exactly the best thing to hit wireless audio, these headphones do a poor job at pulling out what quality does exist. It is possible that this is part of the trends we've noticed in the industry - providing progress and convenience at the expense of fidelity. If so, then each person will determine the trade-offs they are willing to make. I personally don't know of too many people who equate Bluetooth with quality - this is all about convenience and going "cable-free".
We utilized several source CDs in our listening session including Dave Matthews: Stand Up, Yes: Talk, and Peter Gabriel: So . Compression seemed to run the show and even though we had engaged and configured "Bluetooth High Quality Audio" the results were unimpressive. I checked and rechecked my signal strength (it was always in the "Good" range and not too strong or too weak) but for some reason it always seemed as if the Bluetooth protocol was periodically rendering glitches or compression artifacts on each of the CD tracks.
Gaming
Gaming was lots of fun with these headphones. I utilized the BSH-100s for various games and found that the BSH-100/USB-200 combo was compatible with OpenAL audio games (Quake 4, Unreal Tournament 2004, etc.) The games sounded good on these headphones and didn't require the fidelity we were looking for with the music evaluations. They won't rock your world with tons of low-end, but if you're looking for that, steer yourself towards a Buttkicker gamer or a 2.1/5.1 system with subwoofer.
The Audio Gateway represented a great way to add external audio sources to your headphones via Bluetooth. As with PC audio or CD sources, the fidelity was identical. It was nice to be able to quickly plug in my Creative Zen MP3 player and get instant wireless music - and I could even "beam" music from the living room into the office through the Bluetooth link. Overall, this is a nice feature. If you don't need this, you can possibly pick up a unit without and drop about $80 off the MSRP, so keep that in mind.
Recharging and Battery Life
The ANYCOM BSH-100 will run for a long time. I had it going for at least 10 hours continuous and switching out batteries is a breeze. Standby time is a ridiculous amount of hours (well over a hundred). Since you have the additional audio gateway which can recharge the drained battery while not in use, you merely swap out batteries as needed. This fact alone makes this an incredibly handy system to have. I can't impress upon readers enough the pain of having to take off your headset and charge it because you forgot the evening before. If you are using both units, simply recharge at night. These are Lithium-ion batteries so there will not be any memory effects.
I love the look and feel of the BSH-100 Bluetooth headset. I love the ease of use when using it for VOIP and the automatic call interrupt from a paired cell phone is worth its weight in gold (when it works). The Audio Gateway allows for remote sourcing of audio devices at up to 30 feet away (for real). The real negative is audio fidelity for music listening. These aren't audiophile headphones and that should be kept in mind. If, however, your goal is to get a very functional headset for VOIP and cell phone support and you can wrangle the Bluetooth beast - this is your product.
MSRP: $199
USB-200 Blue USB Adapter Bluetooth
MSRP: $34
http://us.anycom.com/anycom
About ANYCOM Technologies Inc.
ANYCOM Technologies, Inc. is headquartered in Newport Beach, Calif. Dedicated to manufacturing the latest
in comprehensive Bluetooth technology, ANYCOM offers a wide range of Bluetooth products, including
headsets, USB adapters and compact flash cards. For more information, please visit www.anycom.com.
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Build Quality | ![]() ![]() ![]() |
Appearance | ![]() ![]() |
Treble Extension | ![]() ![]() ![]() |
Treble Smoothness | ![]() ![]() ![]() |
Midrange Accuracy | ![]() ![]() ![]() |
Bass Extension | ![]() ![]() ![]() |
Bass Accuracy | ![]() ![]() ![]() |
Imaging | ![]() ![]() ![]() ![]() |
Soundstage | ![]() ![]() ![]() ![]() |
Dynamic Range | ![]() ![]() ![]() |
Performance | ![]() ![]() ![]() |
Value | ![]() ![]() ![]() |
