Impact Acoustics USB Superbooster Cat5e Extenders Review
- Product Name: USB Superbooster Cat5e Extender
- Manufacturer: Impact Acoustics
- Performance Rating:
- Value Rating:
- Review Date: July 10, 2008 15:35
- MSRP: $ 99 - $129
- Extends the distance of a USB device from a USB-enabled computer up to 150ft
- Ideal for use with USB cameras, printers, web cams, keyboard/mouse extensions, and any other USB device
- Bus-powered so no external power source is required
- Uses standard Cat5/Cat5E/Cat6 patch cord (not included) for ease of use and flexibility
- Compliant with USB Specification 1.1
- Connectors:
- Base Connectors: USB Type A Male; RJ45 Female (USB Type B for wall plate model)
- Remote Connectors: 2 x USB Type A Female; RJ45 Female (1 x USB Type A for wall plate model)
- Includes tool-less IDC RJ45 connectors (wall plate model)
- Easy to use
- Flexible, wall plate version or dongles
- Works as advertised
- Transmitter/receiver nomenclature a tad confusing
- Not USB 2.0-compliant
Impact Acoustics USB Superbooster Introduction
You may not spend hours and hours thinking of new ways to run long lengths of USB cable, but if you need it to occur, then it suddenly becomes the focus of your thoughts. USB has a practical maximum length of just 5 meters. If you're running an equipment room, remotely-located home theater PC, or even just a really long Guitar Hero III cable (more on this below), then a USB Superbooster is probably something you should investigate.
The way a USB Superbooster works is that it actively takes the USB data and transmits it over Cat5e cable. This effectively breaks the 5 meter distance limitation and nets you the ability to take it up to 150 meters. Not bad, considering the inexpensive price of bulk Cat5e cable. The other nice thing is that since USB includes power, these active solutions are powered by the cable and don't require external power. The exceptions are those products which have an extra USB port, effectively acting as a port doubler.
Impact Acoustics USB Superbooster Setup and Conclusion
This is one of those products that is better shown than
talked about. The connections are simple. For the wall plate models you simply
set up the transmitter (USB B-type connector) so that it is near the source
(typically a desktop or home theater PC). The other end is a standard A-type
female connector that can receive any USB 1.1 device which plugs into that type
of connection. Since the system pulls its power form the USB connection on the
transmitter (Computer) side, you don't need to worry about external power
supplies. It literally just works. We tested our configuration with a 100 foot
run of Impact Acoustics Cat5e cable and were able to upload and download
information from our Universal MX-3000 reference remote control and MRC-400
system controller. Transmission was quick and the computer never once asked to
install any drivers for the new USB components. That's a definite plus since it
essentially means that the system just works transparently as far as your PC is
concerned.
The physical characteristics of the wall-plate Superboosters include
Decora-style devices which have a recessed Cat5e port. Everything about these
products seems tailored to convenience and ease-of-use.
The USB Superbooster wall plates also come with a pair of tool-less IDC RJ45 connectors, so you can terminate your own bulk Caty5e/6 cable to any length you need. It's a nice little addition that gives is all that much more value to consumers who might purchase it (installers will presumably already have tons of connectors for Ethernet-type cabling).
The extender kit is similar except that it doesn't
feature the styling of a wall-plate. This system would be more useful for
installations where an entirely dedicated wall plate would be overkill. In this
way the transmitter and receiver can simply exist in-line with the components
and jump directly to a wall plate containing an RJ45 port. Our kit came with a
2-port receiver, so it may be advised to use the included DV power adapter.
We decided to test this out in the most practical application we could think of: Guitar Hero III. As we alluded to above, there may be situations, like mine where the Xbox 360 is located in a remote equipment closet - well separated from the theater room. How then is one to use a wired Guitar Hero controller? It's not hard if you sling up some Cat5e to a Superbooster and run it the distance you need. We did exactly that and, after setting some lag calibration settings (both audio and video well over 100 ms), we were able to rock out with no apparent problems or glitches. This USB Superbooster system is starting to become very convenient.
Everything you need is included and we were able to run everything in our tests
without using the included DC power adapter. Cool metal case not included...
You may not think much about USB, but when you need it, you need it. And if you need to get it from point A to point B without worrying about the limiting lengths of USB cables, then the Impact Acoustics USB Superbooster is a great solution that won't set you back much money. We found both products to be very well made and the "self-powering" aspect of the system is extremely attractive. We're sure there are more than a few enthusiasts and custom installers (you know who you are) who will find this type of product to be a true lifesaver.
Impact
Acoustics USB Superbooster Products
$99.99
- $129.99
Impact Acoustics
3555 Kettering Blvd
Moraine, OH 45439
937-224-8646
About Impact Acoustics
Impact Acoustics is a division of
Lastar, Inc., a leader in the computer connectivity industry since 1984. In
2002 Lastar created Impact Acoustics
in order to deliver its expertise in computer and data connectivity products to
the consumer and commercial communications electronics industry. For
information regarding Impact Acoustics
visit www.impactacoustics.com.
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Function | ![]() ![]() ![]() ![]() ![]() |
Network Features/Performance | ![]() ![]() ![]() ![]() ![]() |
Ease of Setup/Programming/Integration | ![]() ![]() ![]() ![]() ![]() |
