Impact Acoustics HDMI Selector Review
- Product Name: 2-port 5-port HDMI Switchers
- Manufacturer: Impact Acoustics
- Performance Rating:
- Value Rating:
- Review Date: July 16, 2007 15:05
- MSRP: $ 129.99 (5-port); $84.99 (2-port)
- HDMI Inputs: 5 (Rear)
- HDMI Outputs: 1 (Rear)
- Fully HDCP compliant for use with High Definition Movies and Broadcasts
- Supports 480i, 480p, 720p, 1080i and 1080p video resolutions
- Supports DDWG standard for HDMI-compatible monitors
- Discrete Code infrared remote control (discrete on/off on 5-port only)
- Infrared Extender Jack (5-port only)
- LED display
- IR remote or front panel control
- LED displays video source selected
- Discrete input selection
- Small form factor
- Easy to use
- Affordable
- No discrete power on 2-port version
- Remotes may get lost in couch
Impact Acoustics 2 and 5 Port HDMI Switches Introduction
The
thing about HDMI switchers is that you don't need one until you need one and by
then, you REALLY need one. Some people have made the plunge and bought an HDMI
receiver but there are plenty of people still on the fence. For them, they'd
like to get the very best picture quality out of their HDMI capable transports
and display but many displays only have one or, if you're lucky, two HDMI inputs.
If you find yourself with digital cable, a Playstation 3 or one of the newer
Xbox 360's, and a high def player or upconverting DVD player you're going to
spend a lot of time switching cables or settling on non-digital outputs.
Frankly, that's no good. Rather than deal with that, Impact Acoustics has come out with two
HDMI switchers, either of which will surely fit your needs. Best of all, they
are priced for the consumer and not just installers!
Impact Acoustics HDMI Selector Build Quality and Conclusion
The
main differences between the 5-Port HDMI Selector Switch and the 2-Port (aside
from the number of inputs) is the 5-Port has an IR Extender jack and discrete On/Off
codes. What does this mean? The 2-Port doesn't have discrete On/Off codes so you'll
probably want to leave it on all the time if you are putting it into a system
and utilizing a universal remote. The 5-Port does have discrete codes for On/Off
and the IR Extender input means there's no need to add an IR flasher to the
front of the unit - eliminating the worry about missed commands. From an
installer's perspective, this is a very desirable addition. Both units have
discrete input selection via the remote. The front of both units sport a couple
of LED lights that let you know a) that the power is on and b) which input is
currently being routed to the output. There is a selection button on the front
of each unit that cycles though the inputs.
Both of the units are constructed out of
steel or heavy gauge aluminum and feel heavier than they look. Sturdy? Oh yeah.
Little rubber feet adorn the bottom and keep it from scratching your furniture.
The inputs on the back are well spaced and easy to use. The power cable has a
small plug rather than one of those big square transformer types that takes up
three slots on your surge protector. The IR Extender input is very close to the
power input on the 5-Port Switch but you should have more than enough room to
access it. The front green lights are fairly bright and powering off the unit
doesn't extinguish the power light (only unplugging the unit does that). There
is no dimmer option.
Setup
Setting up a switcher is nearly the easiest thing you can do. Power everything down, connect all your transports to the switcher's inputs, connect a single cable from the output to the display, plug in the power, and turn everything on. Both of the Impact Acoustics switchers are HDCP compliant so if you have an older cable box or HDMI 1.0 receiver and are having handshake issues these devices may be a solution for you.
Of course, one of the main substantive differences between the two switchers is the number of ports. While you may think you'll only need 2 ports, I suggest you think a little about this decision. The 2-Port is really designed as particular solution, perhaps to be utilized in an installation that requires a specific 2-way switching application. The 2-way switcher will be more difficult to program into a universal remote system because of its lack of discrete IR codes so be sure that you're prepared to utilize workarounds. Two ports may seem like enough for now, but as the upgrade bug hits, you'll find yourself with more and more HDMI capable devices. Impact Acoustics has notified us of a 3-Port version that will be released soon which will include discrete codes.
The 5-Port switcher has enough ports that
you'll probably never have to upgrade again. With receivers still sporting only
2 or 3 HDMI inputs, you very well could be using this switch for years to come
- and it keeps you from having to upgrade. Both of the switchers will pass
480i, 480p, 720p, 1080i, and 1080p. My tests showed that they passed all these
flawlessly with no discernable alteration to either the video or audio stream
and no HDCP handshake issues.
Remote
The
remotes for the 2 and 5-Port HDMI Selector Switchers share a lot of the same
styling cues. Lightweight to the point of ludicrous, they feel insubstantial in
your hand. I've never met, seen, or hear of a couch that wouldn't swallow these
remotes in a millisecond. The smaller of two remotes for the 2-Port switcher
has a tiny loop on the end that could presumably be used to attach something
larger and heavier to keep it from getting lost (or tying to a stray thread on
the side of your couch I suppose). The remotes ship with a plastic cover over
the positive battery terminal to ensure they will power up when you start to
use them. Each sports a dedicated button for each input and, while the 2-Port
only has a toggle power button, the 5-Port has discrete 'On' and 'Off'. I had
no problem controlling either of the units from my normal seated position.
Recommendations
There really isn't anything to dislike about these switchers. The remotes are sort of flimsy but that's par for the course - especially since you can program the commands into any universal learning remote. I'd like to see a dimmer on the LEDs or just reduced light output but that's about it.
When working with multiple sources, a switcher is your only option. But what if you just want to extend the life of your display or receiver? For $130 bucks you can have an HDMI switcher that will allow you to use your 5 year old receiver for a few more years as you wait for the prices of HDMI receivers to come down. While there are plenty of switchers out there priced in the multiple hundreds, Impact gives you everything you need at a price that just about everyone can afford. If you're on the market for a switcher, you need look no further than Impact Acoustics.
Impact Acoustics 5-Port HDMI Selector Switch
$129.99
Impact Acoustics 2-Port HDMI Selector Switch
$84.99
Impact Acoustics
1501 Webster St.
Dayton, OH 45404
Phone: 877-AV-EXPERT (877-283-9737)
Fax: 800-331-2841
About Impact Acoustics
Since 1984, Lastar has been a leader in
the computer connectivity industry. Under the brand name Cables To Go, Lastar
created a line of computer connectivity products known for quality and value.
CTG uses the finest components and the latest construction technologies to
maximize cable performance and ensure compliance to industry specifications for
each cable and its designated application. From PC Cables and Adapters to
Networking and Data Sharing products, Cables To Go has delivered the best
products at an always-competitive price.
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Video Performance | ![]() ![]() ![]() ![]() ![]() |
Ergonomics & Usability | ![]() ![]() ![]() ![]() |
Ease of Setup/Programming/Integration | ![]() ![]() ![]() ![]() ![]() |
Remote Control | ![]() ![]() ![]() |
