Wait
a minute, a speaker company making cables? Well, who
better than a company who has proven itself to be a
no-nonsense manufacturer of quality products to make
no-nonsense "sensible" cables. When Axiom
offered to send us a set of their new cables to examine,
we accepted, anxious to see if the quality they put
into their speakers showed up in their cables. This
article gives you a sneak peek into the look and build
quality of these cables.
If
you've read any of our other Speaker
Cable articles, you'll know that we have done
extensive testing on various cables. People may
not realize, but
we actually acknowledge the fact that speaker cables
and analog interconnects can sound different.
The problem,
however is that many so-called exotic speaker cables
can
colorize the sound, resulting in a perceived
tonal change at the expense of transparency and/or
accuracy. Our view is that the best cable is a transparent
cable.
There will be a companion article that will address
the measurements for the Axiom analog interconnects
and speaker cables and we'll see how they line up with
some other brands.
General
Comments on Interconnects
Examine the Axiom Audio analogue interconnects and you
will find gold-plated, stiff RCA connectors that comfortably
grip when attached without risking damage during insertion
or removal. They have a secure connection, yet are removable
without much difficulty. Of all our samples, all had
excellent solder connections
Now
let's take a look at this sneak peek complete with photos
and comments:
Analogue
Audio Interconnects
These cables are attractively made, with a beautiful
casing and solid construction. Open them up and
you'll find clean solder joints and clear shrink
tubing around the positive conductor. This is
a first-class cable and is made as good as anything
you'll find by other better known companies. The
cables are further protected from the outer casing
by a thick plastic guard. There is no chance of
shorting or bleed here. Price: $58 (3 feet/1 meter)
Digital
Audio Optical Toslink SPDIF Cables
Not only are these cables well-built, they are
attracticely presented with one of my favorite
features - an attached protective plastic cap
that guards the surface of the optical connector
when not in use. This ensures that the surface
of the connector isn't damaged in transite, and
when you remove the cable, you can actually find
the cap since it never leaves the connector. Price: $48 (3 feet/1 meter)
Component
Video Cables
These cables are built to handle the demanding
50-100MHz requirements of HDTV (more info on these
specifications will be available in our related
cable test article.) They are color coded for
easy matching to the appropriate Y, Pb, and Pr
video connections. The strain relief built into
these cables is excellent and ensures they will
not unduly stress any of the solder or mechanical
connections. Price: $78 (3 feet/1 meter)
Coaxial
Digital/Composite Video Cables
Built with a bit more gusto than the analogue
audio interconects, these coax digital cables
can also be utilized for composite video connections.
They are equipped with sufficient spring strain
relief and (as are all Axiom's cables) are wrapped
with a high quality braided cover. Shielding is
excellent and I noticed they made a solid connection
to my coax SPDIF connections. Price: $70 (3 feet/1 meter)
S-Video
Cables
The solder connections on these s-video cables
impressed me as being very solid and well-protected.
Often, cheaper s-video cables can suffer from
having poor solder connections in close proximity
to one another - almost touching. These cables
feature individually-shinkwrapped connections
so you get absolutely discreet connections for
each pin. Price: $44 (3 feet/1 meter)
Speaker
Cables
The Axiom Audio speaker cables come with both
ends having spade lug connectors. If your
receiver/power amp
has 5-way binding posts this will serve to
make a solid connection, however many
receivers
may make connections
difficult or impossible.
In
response to this, Axiom Audio is working
on
two things. First, an adapter to securely mate
the spade lugs to a banana connector, and
secondly,
they will eventually be offering these cables
with banana connectors. Price: $59 (9 feet/3 meter)
Axiom Audio has once again provided a solution for
those looking for excellent quality crafted cables
without spending
a fortune. If you are looking for solid cables at a
sensible price, then Axiom appears to be a great
place to
start. One important thing to note is that you can
actually unscrew all of the Axiom Audio interconnects
and take
a look inside at the excellent solder quality and shielding.
I've noticed that many other cable manufacturers
tend to make their cable terminations inaccessible
to inspection, yet tout superior build quality.
It's nice to be able to see the craftsmanship underneath
the hood.
With these cables, nothing is hidden - you know
exactly what you are getting.
We
will be providing hard data and analysis on these
cables, but this sneak peek at least gives you an
idea as to what to expect from these new offerings
from Axiom Audio.
