Aperion Audio Intimus 5B Bookshelf Speaker Review
- Product Name: Aperion Audio Intimus 5B Bookshelf Speaker
- Manufacturer: Aperion Audio
- Performance Rating:
- Value Rating:
- Review Date: July 31, 2009 22:56
- MSRP: $ 450/pr (free shipping)
- Frequency Response: (+/-
3dB) 75Hz to 20,000Hz / (+/- 6dB) 62Hz to 20,000Hz
- Impedance: 6 ohms
- Sensitivity: 84dB
- Recommended Amp Power: 25-200 Watts
- Tweeter: 1" Audiophile-grade Silk-Dome Tweeter
- Woofer: 5.25" Woven-Fiberglass Mid-Woofer
- Driver Configuration: 2-Way
- Enclosure Type: 1" HDF, Ported
- Dimensions: 12" H x 6.75" W x 8" D
- Weight: 14lbs
- FREE SHIPPING - a $33 value per pair*
- FREE lifetime technical support
- FREE speaker care kit
- Beautiful cabinetry
- Excellent fidelity
- Generous trial and return policy
- Excellent value
- Low sensitivity
- limited bass output
Intimus 5B Product Overview
Aperion Audio is yet another online loudspeaker
company, albeit a very successful one at that.
Although their name isn’t exactly thrown around as frequently as some of
the other online companies on the audio forums, I believe they are a sleeping
giant. There is a reason behind their
growing success. Rather than offering
gimmicky limited time sale offers, or pandering to fan boys on A/V sites, they
focus on quality of products and services.
Over the years we have watched their website and product line expand at
an impressive rate and to date none of the products we’ve reviewed for them
have disappointed. It’s been awhile
since an Aperion Audio product hit my sound lab so I was eager to check out
their latest offerings. Enter the Intimus
5B, a two-way speaker system and the middle model in their bookshelf lineup. The Intimus 5B looks surely impress from the
pictures displayed on their website. I
was eager to fire them up in my own listening room to determine if their sound
measured up to their appearance.
The Aperion Audio Intimus 5Bs showed up well packaged
(individually boxed and then boxed together) which I thought was overkill until
I saw the sheer beauty of their cabinet work.
It wouldn’t be high end without the infamous silk sock which Aperion Audio
wrapped each of the speakers in. This
was quite a sexy blue sock that really added a touch of class to the product.
The Intimus 5B is a pretty standard bass reflex (ported) design boasting a 5 ¼” woofer and 1” tweeter. The drivers are recessed into the front baffle as they should be. You would be surprised to know that even some of the more prestigious brands today don’t take this measure to reduce unwanted diffraction between the driver faceplates and cabinet surface.
The 5B is
rear ported and sports a single pair of 5 way binding posts. The enclosure is constructed of 1” high
density fiber board (HDF) which is unusually thick and high quality for such a
budget priced speaker. The sheer thickness
of this relatively small enclosure self braces itself virtually eliminating all
major cabinet resonances and producing a consistently deadening thud sound when
knocked on any surface.
Aperion Audio products are offered in two finishes: high gloss black and cherry. I chose cherry for my review samples. The cabinetry of these babies is among the best I’ve seen regardless of price. There are no seams to be found anywhere on the cabinet as the veneer wrap seems to flow as one piece. Aperion Audio states that their products feature a furniture grade finish. I don’t doubt this one bit. If you take a moment and really examine these speakers, you will find that they paid meticulous detail to fit and finish. Even the grill is constructed of finished wood instead of flimsy plastic that you usually find in products of this price class. The grill cloth is a very tightly woven mesh which again is something we rarely find in budget type products.
Build Quality
The Drivers
The 5 ¼” woofer is
magnetically shielded and sports a woven fiber cone with butyl rubber surrounds
and a cast aluminium basket. The
faceplate of the woofer basket is flatted on both sides which is done purposely
to allow the design engineer to place it closer to the tweeter for better
crossover integration. Aperion Audio
missed that subtlety and unfortunately oriented the woofer 90 degrees likely
for aesthetic purposes.
The tweeter is a 1” silk dome with neodymium magnet. Normally I am not a big fan of these type of motor structures simply because they tend not to have a low enough free air resonance to allow them to extend down in frequency for proper blending with a woofer. They usually tend to thermally saturate quicker than standard ferrite magnet motor structures when played loudly as well. I didn’t find this to be the case with these speakers, and it quickly became obvious to me that the little Aperion tweeter was quite a performer. It is a low profile design that utilizes a waveguide to control dispersion. Again it’s a shame that Aperion didn’t take advantage of bringing the drivers closer together since that is a big advantage a tweeter like this has over a conventional one with a much larger motor structure.
The Crossover
The 5B
crossover is affixed to the speaker terminal and is split up into two separate
circuit boards. The bottom circuit board
features the woofer's low pass filter (LPF) consisting of an iron core inductor
and two 100V electrolytic capacitors which I’d guess is configured as a 2nd
order filter. The second circuit board
features the tweeter's high pass filter (HPF) which again appears to be a 2nd
order design like the LPF but features a higher quality air core inductor and
polypropylene capacitor. Personally I
would have preferred higher quality parts in the
woofer section, here but they seemed to serve their function well from my
listening tests and they didn't skimp on the capacitor in series with the tweeter which is most critical for audibility.
Aperion Audio 5B Drivers (left pic) ; Crossovers (middle pic); backview (right pic)
The Backside
The Intimus 5B is rear ported directly behind the
tweeter with the exit chamber of the port flared on both sides. There are two milled holes below the port
which is compatible with the B-tech
mounting bracket they sell on their website as an accessory for this speaker. This comes in quite handy for mounting as a
surround speaker. I didn’t test these
brackets but I’ve had excellent success with B-tech products in the past so I’d
expect no different here. The 5-way
binding posts are gold plated and recessed into the plastic terminal cup.
Intimus 5B Set-up & Listening Tests
I tested
the Intimus 5Bs in two scenarios:
- Office - as a nearfield monitor on my computer desktop (10’ x 6’ office)
- Theater room - two-channel utilizing the reference gear and premier listening space in the Audioholics Showcase home
In the first scenario, I used my Headroom micro preamp and DAC connected to a Panasonic SA-XR50 class D 5.1 receiver. In my opinion, this is actually a poorly executed product but I bought it as a reference for how bad Class D can be if not designed properly. It does manage to work fairly well to power computer speakers and I now use it for that function normally since its low profile and efficient.
For the second scenario, I placed the 5B’s on my 30” sand-filled Plateau speaker stands which puts the tweeter right at about ear level on my Continental theater seats. The speakers were positioned about 5ft from sidewalls and around 8ft from the back walls and spread apart about 10ft from each other which was about two feet shy of the distance from my primary listening position. After experimenting, I found they sounded their best with minimal to NO toe-in for reasons I will get to later in the review. I used my Denon AVR-5805mkii 10-channel A/V receiver to power them and my Yamaha MCX-2000 digital server as the source. All interconnects were furnished by Blue Jeans Cables (1694A Coax) and Kimber 8PR speaker cables with WBT compression banana plugs.
Listening Tests
Unless otherwise stated, all listening tests were conducted without a subwoofer in two-channel configuration with the Intimus 5Bs set to “large” in the A/V receivers bass management.
Office Room utilizing Pandora.com
To start off my listening tests, I began with the setup in my main office where I do all related works for Audioholics. I usually write my articles with music playing in the background courtesy of the FREE services of Pandora.com. With that, I captured some of my listening experiences with the following source materials.
Eagles – I Can’t Tell You Why
The guitar
coming from the left speaker sounded so expansive that it went beyond the
lateral plane of the speakers. This was
my first hint that the Aperion’s were ready to show off their ability to
image. This is a trait I love about
small bookshelf speakers that large towers usually never come close to
matching.
Crosby Stills & Nash - Just
a Song Before I Go
I had the
same experience as the Eagles. The
guitars seemed more expansive than I anticipated. Sound was very relaxed and inviting much more
so than the JBL Pro III speakers I normally use on my desktop. I enjoyed the sonic chops the 5B’s were
displaying so much that I didn’t skip this song when Pandora chose it for me
despite I am not a huge fan.
Beatles – Come Together
This was
the re-mastered mix used for Cirque du Soleil .
The Intimus 5Bs exhibited excellent stereo imaging with the cymbals
pushed all the way to the right speaker while the guitars beamed from both
speakers in unison.
Riverside – Conceiving You
If you’re a
Progressive Rock fan like I am and never heard of this band, run to Pandora
(after reading this review of course) and create a channel to start listening. The Bass was a bit thin coming from the 5Bs,
but cymbals were clean and the vocals were very natural sounding, not conveying
that “cupped” sound so commonly exhibited by small speakers.
Riverside -Voices in My Head
The stereo
guitar effects at the beginning of this track were chilling. The 5Bs did a great job rendering some of the
low bass tones cleanly although tactile response was severely lacking to
accurately reproduce it. A powered sub
would have really helped here.
U.K. – Nevermore
Bill Bruford's
tom rolls, and cymbals sounded excellent.
Wetton's voice came through concisely and was tonally very
accurate.
U.K. – Dead of Night
Another
great tune from a band long forgotten by most, this song displays Bill
Bruford’s genius on the drums. They just
don’t make rock music like this anymore.
Cymbal crashes were clear and distinct and stereo separation again was
excellent.
Joes Pass – Blues for Fred
The jazz
guitar snuck up on my with its realism.
Very pleasant listening experience, just one man and his guitar. The twang sound from the guitar and the
reverb came in very clearly exhibiting the 5Bs ability to extract all of the
detail from a recording..
Steely Dan
– Any Major Dude Will Tell You
I really
loved the way the acoustic guitars sounded on the Intimus 5Bs. The cymbals were crisp and tonally the 5Bs
were a bit top heavy but everything sounded very pleasing nonetheless. Donald Fagen's vocals sounded great reminding
me just how excellent Steely Dan recordings sound when played back on good
equipment.
Theater Room
CD:
Special EFX – CollectionThis is a must-have CD when doing A-B
testing for revealing sonic differences of electronics or speakers. It’s a must-have in my opinion. It’s
excellent accessible jazz and Chieli Minucci is simply a fabulous and
inspirational guitarist.
Track #2 “Jamaica, Jamaica” showed off the 5B’s excellent ability to extract all of the details within the recording. Bass was a bit anemic and really could have used supplementation with a subwoofer. The rainsticks were a bit more narrowly focused then I’ve heard on other systems but they were just as detailed.
Track #4 “Summers End” displayed the 5B’s ability to portray soundstage depth beyond the plane of the speakers with the very detailed top end response. There is so much going on in this song via various layers of percussion, vocal harmonics and electric guitar. The Intimus 5B’s didn’t mush it all together like I’ve heard on lesser designed systems. Instead they did a bang up job of preserving the separation rewarding my ears with the rich complex and tantalizing sounds of Special EFX.
CD: Pat Metheny / John
Scofield – I Can See your House from Here
This is one of my favorite Jazz CD’s featuring two
guitar greats playing real jazz you won’t hear on the so called “smooth jazz”
radio stations that are more akin to playing what I refer to as “jazzac”. Track #7 “Say the Brothers Name” is the
highlight track on this CD for me at least.
On a good speaker system, it transports you into a cozy jazz club
sipping a dry martini. The Intimus 5Bs
put me in that mindset for the most part but bass was again a bit lacking. The cymbal decays were well sustained like
I’ve heard on the very best systems.
Most speakers simply don’t reveal all of the subtleties this well, score
one for the Aperions. The trumpets
sounded much larger than expected coming from such a diminutively sized speaker
system. Scofield’s guitar beamed at me from
the left side of the room while Metheny’s melodic playing on the right set the
ambience persuading me to continue listening to more cuts from this CD. Dynamic passages played back at high
listening levels proved too much for the little 5 ¼” woofers of the 5Bs which
was not only evident with audible cone break up but also loud popping sounds
when the woofer bottomed out. Crossing
these speakers over at 80Hz and engaging one of my Velodyne DD15s helped to
eliminate this issue, increase system dynamics and restore the bass that the
5B’s just weren’t capable of producing.
These speakers proved to be far more rewarding when bass managed and
played in concert with a quality subwoofer.
CD: Dianne Reeves Never Too Far
Yes I use this disc often but I know exactly what to listen for when I pop it in so expect to see me continually using it as a reference, especially for loudspeaker reviews. In track #2, “Never too Far”, the chorus sounded pleasantly expansive but not quite as much as I’ve heard on larger systems. I had to bass manage the 5Bs when played at loud levels in my theater room as the woofers simply couldn’t handle the bass on this disc. The Intimus 5B’s showed off their uncanny ability to image on Track #3 “Come In’. The rim shoots really stood out more than I seemed to remember when listening on other speakers. This is yet another tribute to the 5B’s very good tweeter design.
Although this CD is a bit bright sounding, I did notice the 5B’s seemed to really bring this out a bit more than I preferred. Mating these speakers with a sub really helped to better balance the sound but on bright recordings, I wouldn’t be afraid to knock the treble control down a dB or two to achieve more neutral sound.
Intimus 5B Measurements & Analysis
Impedance / Phase Measurements of the Aperion Intimus 5B
The Aperion Audio 5B speakers appear to be tuned into the 50Hz region as indicated by the saddle point in the impedance graph. This explains why these speakers were prone to bottoming at high SPL levels when playing bass heavy music. There is an impedance minima of around 7 ohms in the 200Hz range and phase stays within +-30 degrees for the entire audio band. Although these speakers aren’t very efficient, they are an easy load for any modestly powered receiver to drive.
In-room 1 meter SPL vs Frequency Aperion Intimus 5B (1/3rd octave smoothed)
At 1 meter, I measured around 84dB sensitivity which is what Aperion Audio claims for this product. It’s a bit on the low side for a speaker of this size. I’d be curious to see if they could have improved system efficiency response by using a lower mass cone material for the woofer and tuning the system a bit higher. The system appears to start rolling off around 70Hz with a sharp rolloff of around 18dB/octave below 50Hz. Given the box size and driver used in this system, there really is no good reason to not roll these speakers off at 80Hz and recommend using them in concert with a subwoofer to increase dynamic range and usable bass extension.
In-room 1/2 meter SPL
vs Frequency Aperion Intimus 5B (1/12rd octave smoothed)
Brown trace: on-axis; blue trace: 15 deg off-axis; pink trace: 30 deg off-axis
The Intimus 5B’s measured quite linearly, measuring +-5dB from 70Hz to 20kHz in-room. I did notice a slight dip around 2kHz at the crossover region which probably could have been improved slightly by bringing the drivers closer together and tweaking the crossover design a bit. The tweeter level appears to be a dB or two elevated compared to the woofer which can at times lead to a more forward top end sound but not overly bright since the tweeter employed here is quite good.
Intimus 5B Conclusion
Don’t
expect to run the Intimus 5Bs as a full range monitor. Because of the Intimus 5B’s low sensitivity
and rather anemic bass response, they aren’t an ideal speaker to use as a
nearfield monitor either. Their physical
size simply restricts the amount of usable bass they can produce below
80Hz. This is a knock on the laws of
physics, not the design of this product.
Given their low sensitivity, it is recommended to use at least a decent
midline A/V receiver or better to power them.
The Intimus 5B’s are best utilized as front-channel monitors or surround
back channels in small to medium sized rooms, bass managed to a subwoofer
complimenting an entire Intimus speaker system for a full fledged high fidelity
multi channel experience. I achieved the
best sonic results with very slight toe-in which not only broadened the
soundstage, but tonally made the speakers sound as neutral as possible. I recommend experimenting and positioning to
preference.
There is little not to like about the Intimus 5B bookshelf speaker system. The Intimus 5Bs have the ability to disappear into a room thanks to their excellent imaging capabilities and very detailed open sound. Aperion Audio proved in droves that they could combine great sound, aesthetics (score one for the wives) and build quality into a compact package that most budding audiophiles can afford. Although the color options offered are limited, Aperion Audio chose the two most commonly requested colors (cherry and gloss black) and masterfully executed the fit and finish of the cabinetry making these pieces of furniture that just happen to sound really good. Mated with a powered subwoofer, you’ve got audiophile performance and aesthetics on the cheap. Considering their very liberal return policy, FREE 30 day home trail program and FREE shipping (both ways) I can’t say anything else other than “highly recommended!”
18151 SW Boones
Ferry Road,
Portland, Oregon
97224
1-888-880-8992
About
Aperion Audio
Aperion Audio is an online direct-to-consumer speaker manufacturer for smart
shoppers who are frustrated with the retail experience. Aperion offers a better
value, meaningful information, generous service, and unlike other speaker
retailers and manufacturers, is the only company to deliver an honest and
Totally Risk-Free In-Home Audition. For additional information, visit www.aperionaudio.com
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Appearance | ![]() ![]() ![]() ![]() ![]() |
Treble Extension | ![]() ![]() ![]() ![]() ![]() |
Treble Smoothness | ![]() ![]() ![]() ![]() |
Midrange Accuracy | ![]() ![]() ![]() ![]() |
Bass Extension | ![]() ![]() ![]() |
Bass Accuracy | ![]() ![]() ![]() ![]() |
Dynamic Range | ![]() ![]() ![]() |
Performance | ![]() ![]() ![]() ![]() ![]() |
