Yamaha DVD-S2300 MK2 Universal DVD/SACD Player Review
- Product Name: DVD-S2300 MK2
- Manufacturer: Yamaha
- Performance Rating:
- Value Rating:
- Review Date: February 28, 2004 19:00
AUDIO
DSD
Decoder: Sony
CXD-2753R
DACs: Analog
Devices AD1955ARS
Frequency
Response
DVD
Audio (192kHz): 2Hz - 88kHz
DVD
(96kHz): 2Hz - 44kHz
DVD
(48kHz): 2Hz - 22kHz
CD,
Video CD: 2Hz - 20kHz
Harmonic
Distortion
SACD:
0.0016%
DVD
(48kHz/24-bit): 0.002%
CD:
0.0022%
SNR: 115dB (weighted)
Dynamic
Range
SACD: 108dB
DVD
(48kHz/24-bit): 103dB
CD,
Video CD: 99dB
VIDEO
Decoding Engine: Faroudja FLI-2200
Video
Signal level
Composite:
1 Vp-p/75-ohms
S-Video
(Y/C): 1 Vp-p/0.286 Vp-p/75-ohms
Component
(Y, Pb, Pr): 1 Vp-p/0.3 Vp-p/75-ohms
GENERAL
Power
Consumption: 35 W (Standby 0.8 W)
Dimensions:
17.125" x 4.563" x 13.75" (435mm
x 116mm x 350mm)
Weight:
19.8 lbs (9.0 kg)
- Superlative playback performance of CD, SACD, DVD-A and DVD-Video with DCDi 480p output
- Bass management & digital delay compensation for DVD-A
- Separate bass management for SACD
- Excellent build quality
- Doesn't retain last played DVD/CD track when unit is powered down
- Limited bass management crossover options
- No digital video output options
- No digital audio output options for
- DVD-A or SACD (Standards not available at time of manufacture)
- No digital delay compensation for SACD
- Mediocre remote control
Yamaha DVD-S2300 MK2 Technology Overview
We are at a bit of a
crossroads in technology right now as some of the digital rights management rules change and digital
transmission of DVD-Audio and SACD finally become a reality. As of right now (but not for long), the
choices remain to go analogue or utilize a proprietary digital format for audio. Digital video output
specifications are also in a state of flux as DVI and HDMI are being discussed (and possibly both
utilized) as standards. Since many people are still in possession of analogue displays (CRT direct view
or rear projection) this is not a limiting factor at all. In fact, it's the newer technologies that have
yet to prove themselves and deal with issues and difficulties long ago solved by their analogue
counterparts (resolution conversion and enhancement, for example.)
Which brings us to Yamaha. The company who produced some of the finest value projection systems on the market is now the company releasing its next-generation high-end universal DVD/SACD player. Let's discuss some of the more apparent features:
Faroudja DCDi 480p (progressive)
Output
DCDi is a specific digital technology Faroudja introduced a several years ago in their broadcast up-converter. DCDi is a digital video mode algorithm that stands for D irectional C orrelation D e i nterlacing. -
MP3 Multi-Session Support
The DVD-S2300 MK2 supports playback of MP3 files written to disc in a hierarchical format, with entire albums (chapters) stored in folders (titles). Playback of MP3s is possible within the bitrate range of 32kbps - 320kbps at either 44.1kHz or 48kHz sampling frequencies. Random Play and Program Play will not function with MP3 discs. -
Completely Independent SACD and DVD
Circuits
This is one of the nicest features of the unit. It is often mistakenly thought that a universal player lacks the dedicated features to excel at both SACD and DVD-A, however with truly dedicated processing circuitry you are getting (quite literally) two players in one.
Yamaha's DVD-S2300 MK2 differs from the original DVD-S2300 by:
- Adding an RS-232C port with extended IR command/control capability for use with a touch panel system.
- Producing a reported improvement in the trackability of hybrid discs.
What really stands out in this abbreviated feature set is the inclusion of the FLI2200. The single-chip FLI2200 was introduced as a mass-production item in August of 2001 and retains the same deinterlacing and post processing advantages of its predecessor. The FLI2200 uses motion-adaptive deinterlacing that selects optimal filtering on a pixel-by-pixel basis to produce the best resolution without introducing motion artifacts. Possibly the best use of this technology is with film mode, which enables proper handling of 3:2 and 2:2 pulldown as well as bad edit detection/correction (the mismatching of incorrect fields, creating a comb error).
Faroudja's proprietary DCDi technology identifies edges at any angle in moving images and interpolates along the edge to produce smooth, natural images without the staircasing or jagged edges produced by other deinterlacing technologies. The FLI2200 also incorporates motion-adaptive cross-color suppression that removes coloration artifacts produced by commonly used video decoders. On-chip 10-bit DACs are also present, allowing high-resolution analogue output.
We'll go into more of these in detail, but it's not a bad start for the DVD-S23000 MK2 to supply a high-quality Faroudja engine, support most mainstream Audio and Video formats, and have complete separation of its DVD-Audio and SACD circuitry - all for under $1000. We've seen far less in more expensively priced units and were enticed by the thought that Yamaha may have provided a true high-end universal transport for a value price.
Yamaha DVD-S2300 MK2 Setting Up the Player
Setting up the Yamaha DVD-S2300 MK2 was a breeze. Yamaha must have taken a look at their finished product in this player and thought "Hey, we should make our flagship Z9 receiver this easy to use!" The graphical user interface of the DVD-S2300 MK2 was absolutely straightforward and unobtrusive. Across the top, via tabbed folder-like sections, you have access to Audio, Disc, Video, Display and "Others" Settings. Each section is fairly intuitively populated, with the exception of "Display" which really had to do only with the DVD player's On-Screen Display.
The Audio Menu allows you to set Speaker Settings (multi-channel or 2-channel), PCM Down Conversion (down converting high sampling frequency audio signals from non copyright-protected discs), Dolby Digital and DTS Bitstream or PCM output for equipped decoders/processors/receivers, Dynamic Range Compression (for reducing the dynamic range when watching Dolby Digital movies - generally a late-night feature), and Audio During Search. Enabling Audio During Search is something I always appreciate, especially coming from a time where I had to search through stacks of DVDs to find content for various music videos for Planet Hollywood. When looking for a particular phrase or section of a movie that you're not familiar with, this feature has saved me countless hours. Yamaha's implementation of this feature, however, sounds a bit like a woodpecker on a record player (lots of skips and jumps with little if any intelligible dialogue). Sony had an implementation of audio during search that involved playing 2-seconds or so of audio, then skipping ahead 4 seconds and repeating. This way, audio was intelligible, but also kept up with the movie. Most people probably don't use this feature, but a better implementation in the future might result in more people who do.
When setting up the speakers for analogue multi-channel output (for digitally-outputted signals your receiver will control all speaker configuration settings) realize that the icons control whether the speakers are large or small and can be altered by using the up and down arrows on the remote control. You will want to set these first and then utilize the built-in test tone to set the levels for the center, sub and surround. My configuration had the mains set to large and all other speakers set to small. Since I could set the subwoofer level in the DVD player in DVD-A/V mode, this compensated for the lack of independent subwoofer level trims in the Integra DTC-9.4's multi-channel input. One thing I would like to see in the future, however, is the ability to set separate subwoofer levels for SACD and DVD-A/V playback.
Navigating to the Video Menu will expose you to options for TV Aspect Ratio (16:9, 4:3 pan and scan or 4:3 letterbox), Still Mode (if still frames jitter try "Field" or "Frame"), and Black Level Control. The manual gives instructions for component vs. composite/s-video black level settings, but with even a somewhat calibrated monitor, we recommend always setting this to "Darker". The exception would be if you have done your best to calibrate your television and you are still unable to make out shadow detail in darker areas of films. Just about any recent or recently transferred horror or suspense film should allow you to test out your black level performance.
Yamaha DVD-S2300 MK2 Setup SACD, Video Tests
Setting up the player for SACD is easy and involves using the instruction manual and the front panel display to set your speaker configuration and bass mangement settings. There is no on-screen display or GUI for any of the SACD settings, again a function of having completely discreet circuitry for those functions. As SACD has no video functions, there is no reason to introduce video circuitry into that part of the system. I believe this was an excellent call on the part of Yamaha. When configuring the system, you may ghost a center channel and elect to not utilize a subwoofer, but you must have rear (surround) speakers to enjoy multichannel SACD - there is no provision for combining the rear channel information into the front channels. Your receiver's analogue inputs may, however, be able to handle this function in DSP, but this would incur additional A/D/A conversion. Obviously, 2-channel SACD content will not have these requirements.
Video Resolution and Noise Comparison
I wanted to see how well the Yamaha DVD-S2300 MK2 handled high resolution video. As I ran through some of the AVIA set up tests, I was pleased to see that the Yamaha (as well as my old Sony player) could handle high resolution images up to the maximum resolution of 540 lines (theoretical limit for DVD's native format). During this test, I was somewhat surprised to notice a huge difference in the performance of the Yamaha vs. my old Sony DVP-S550D player in terms of video degradation. This showed up clearly in the AVIA 100 TVL and 200 TVL wedge resolution test patterns as noise in the lower right hand corner. Take a look at these images:
Sony DVP-S550D: Notice the video noise present in the test pattern, indicating the Sony's inability to cleanly display high-resolution images. (480i) |
Yamaha DVD-S2300 MK2: There is absolutely no video noise present in the test pattern, showing the clean, noise-free potential of the Yamaha player. (480p) |
Because of the excellent performance of the Yamaha DVD-S2300 MK2, and tests we have performed on several television sets, we recommend utilizing the Faroudja de-interlacing circuitry in lieu of the technology which may be present in your television. This will result in a cleaner picture and better video performance.
Yamaha DVD-S2300 MK2 Viewing Evaluation
Measurements and
test patterns are fine, but we enjoy good old-fashioned viewing tests to really see how a player
performs. My favorite method of doing this is through a series of movies I am very familiar with,
allowing observation of elements and subtle details of film scenes that can visually distinguish the
excellent players from the mediocre.
Finding Nemo
Finding Nemo was
the perfect opportunity to see the way the Yamaha DVD-S2300 MK2 handled motion with its progressive scan
output. As with all digitally animated films, there is a large amount of motion blur utilized for fast
moving scenes, so edge combing will not be as apparent, but the vibrant colors and stark contrasts of
this film, not to mention notorious embedded sub frame pixelation) serve to make other nuances viewable
that would otherwise go unnoticed. For example, one of my favorite tricks is to see how clearly defined
the MPEG-2 compression is when Marlin or Nemo is shown against the blue background of the ocean. While
this is one of the drawbacks of a high-resolution system (try spotting this with a 32" CRT and a mediocre
DVD player) it is a great way to illustrate a DVD player's resolution. Below is an enhanced photo of some
MPEG-2 artifacts which, unfortunately, appear all over the Nemo movie. While Pixar is excellent at story
writing and animation, their digital DVD transfers leave a lot to be desired!
Sub-Frame PixelationNotice the square
MPEG-2 compression visible around Marlin (circled for easier spotting). It is quite apparent during full
motion viewing - a little harder to point out in a still capture - but you should be able to see the hard
edges enough to observe the sub-frame pixelation.
The Yamaha reveals these types of errors more so than other progressive players which may
soften the picture due to inexpensive video decoding engines. This is simply the price of admission into
the world of HDTV and high-end players. Hopefully, as high definition formats evolve and emerge, these
problems will disappear as larger amounts of data, and higher resolution images can be stored to optical
disc for artifact-free playback. For now, I'll continue to use this phenomenon to measure the clarity of
DVD: The Lord of the Rings The Two Towers
Some of the most beautiful scenery is located in this film during the time spent
in Rohan and also within
Fangorn
Forest
. Within each of these scenes lie details that many inexpensive DVD players will miss.
The Yamaha DVD-S2300 MK2 does an excellent job of picking up the cloud detail over the mountain range at
the Rohan capital of Edoras. Also in these scenes, the detail of the thatched rooftops is something that
simply will not be clearly visible (with detail) on players not capable of reproducing at least 6.75 MHz
of video bandwidth.
This is by far my favorite DVD of the year and I am always amazed at how much attention to background elements the set designers gave during the creation of the film. There are countless opportunities to test the limits of your video reproduction system, from costume details (check out the detailed armor of King Theoden), to etched stone staircases (Edoras), to digitally-enhanced background elements (Rohan and the journey to Helm's Deep), to meticulously prepared hair and makeup elements (there are more than enough close-ups of Aragorn and Frodo.)
DVD: Pirates of the Caribbean The Curse of the Black Pearl
This movie is an excellent
test of your system's black levels, but for our purposes it also served as an excellent gauge of the
Yamaha's color reproduction and detail. In watching the live action sword fights (Johnny Depp and Orlando
Bloom) we could notice no comb errors or motion artifacts due to inaccurate 3:2 pulldown or poor error
correction from the video decoding engine. In fact, the smooth motion of the scenes, excellent color
reproduction, and fantastic clarity made this movie worth watching completely through. Having calibrated
the system prior to these viewing tests, I noted that the Yamaha DVD-S2300 MK2 did a superb job of
rendering black levels, even in the darkest scenes. I flipped the DVD player's video black level control
to "lighter" as a test and noticed a fairly significant gain, presumably from 0 IRE to approximately 7.5
IRE - not something you would want unless your display device absolutely cannot reproduce blacks (a front
projection system with low lumens, contrast ratio combined with a neutral or low gain screen,
perhaps.)
DVD-S2300 MK2 Listening Tests and Conclusions
I was thoroughly impressed with the video performance of the DVD-S2300 MK2. Now it was time to put the discreet DVD-Audio and SACD circuitry to the test. I put in two of my standard evaluation discs, each of which I am intimately familiar with, helping me to recognize any significant or otherwise noticeable differences in sound due to transport colorization or performance.
Toy Matinee's self-titled DVD-A Disc and Norah Jones' Come Away With Me SACD consistently appear in my listening tests because they have a myriad of elements that allow me to compare various devices to see how they affect the sound. With Toy Matinee, I am listening for the clean reproduction of reverb, without the loss of decay or smoothness, as well as the clean reproduction of Kevin Gilbert's vocals across all three front channels (he is generally isolated in the center with doubling, background vocals and reverb on the mains and surrounds). Norah Jones, while a simple mix and containing none of the complexity and layering of the Toy Matinee disc, provides some of the cleanest vocal and bass sounds you could ask for. By not attempting to overproduce the material, the disc emphasizes style and talent in lieu of over-produced content. As an aside, Norah Jones is playing on a Yamaha grand piano on the recording. I recommend both of these discs if you want some solid performers in your collection.
I configured the Integra DTC-9.4 for Pure Direct mode, and disabled all video circuitry in the DVD-S2300 MK2, allowing analogue only input from the player to be routed directly through to the Sherbourn 7/2100 amplifier with no DSP. Levels were calibrated prior to the listening session and the subwoofer was set to a level with which I am familiar and comfortable. Since bass management is handled by the DVD player when utilizing the multi-channel analogue inputs, I configured the speakers for small , except the front Left and Right. The only confusing thing about the DVD setup was in the manual, where it states that for DVD-Audio large speakers are defined as those capable of handling frequencies "under 100 Hz" and for SACD large speakers are defined as those capable of handling frequencies "under 90 Hz". Unless you are using a cube system, most bookshelf speakers (let alone floorstanding speakers) can handle frequencies below 90-100Hz. Combine this with the lack of a crossover setting for the subwoofer and you can see that the player may present some interesting issues for multi-channel output. From listening to the unit, my perception was that the crossover point was rather lenient, maybe 6db/octave or at most 12dB/octave. In either case, I supplemented the crossover slope by setting the subwoofer crossover at 90Hz during SACD sessions and 100Hz during DVD-Audio playback.
During both listening sessions, reverb was clean and compression-free. Vocals were strong and clear with no audible distortion. In my opinion, the DVD-S2300 MK2 was fairly transparent and didn't seem to colorize or hamper the sound in any way - something I look for and appreciate in a good universal player. Yamaha has provided an excellent transport that handled everything I threw at it with precision-like detail and reproducible reliability. Not once did the player exhibit any signs of compression, colorization or make any additions to the expected music tracks.
I spent quite a bit of time listening to CDs via a digital coax S/PDIF connection to the excellent performing Integra DTC-9.4 processor. I A/B'd CDs using the DACs in the DVD-S2300 MK2 and those in the DTC-9.4 and found that both performed equally well - or at least close enough that I didn't have a clear preference. Someday I look forward to being able to compare digital DSD and DVD-Audio with bass management provided via a high-end receiver or processor, but until then the Yamaha provided excellent analogue multi-channel output.
The DVD-S2300 MK2 is an excellent performer for all formats tested. Its ability to provide clean, accurate analogue audio output was bested only by its quality rendering of high resolution progressive scan video output. I noticed no flaws in the design, save more detailed bass management crossover options, digital delay compensation for SACD, and IEEE1394 digital output. The remote control was adequately ergonomic but will probably be unused at this price point as any competent receiver or processor will provide something that can either incorporate or learn its functions. The attractiveness of the Yamaha is enhanced by its very competitive price point. Obtaining a player of this caliber with a Faroudja display engine at an MSRP of $999 puts the DVD-S2300 MK2 in a very competitive place. It would sit nicely in any high-end home theater system and in my opinion is formidable its price class.
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Standard Definition Video Performance | ![]() ![]() ![]() ![]() |
High Definition Audio Performance | ![]() ![]() ![]() ![]() |
Analogue Audio Performance | ![]() ![]() ![]() ![]() |
Bass Management | ![]() ![]() ![]() |
Ergonomics & Usability | ![]() ![]() ![]() ![]() ![]() |
Ease of Setup | ![]() ![]() ![]() ![]() ![]() |
Features | ![]() ![]() ![]() ![]() |
Remote Control | ![]() ![]() ![]() |
Performance | ![]() ![]() ![]() ![]() ![]() |
