Auralex MoPADs Monitor Isolation Review
- Product Name: MoPADs Monitor Isolation Pads
- Manufacturer: Auralex
- Performance Rating:
- Value Rating:
- Review Date: May 06, 2006 19:00
- MSRP: $ 39.95 (2 pair)
- 5 position wedge adjusters (+4,+8,0,-4,-8) degrees
- Dimensions: 12" long x 4" wide
- Weight Limitations: 100lbs.
- Does fantastic job of decoupling speakers
- Variable pitch for wide installation options
- Improves fidelity of poorly installed speakers
- Raises speaker 1.25"
- Not available in alternative colors
Auralex MoPADs Monitor Isolation Introduction
In an ideal world there would be no war, disease or hunger and our loudspeakers would be perfectly placed in perfect rooms for perfect sound. While Auralex probably can't help resolve world issues, they certainly can help with speaker placement, room acoustics and isolation as evident by their isolation pad devices they refer to as MoPADs and the up and coming new acoustically treated room for the Audioholics Showcase home premier reference system .
Auralex MoPADs Monitor Isolation Overview
My family room system is at a bit of a disadvantage for the front three speakers since they are mounted about six feet in the air on top of a built in entertainment center that houses my equipment and 56 舡 Toshiba 1080p DLP display. While I chose excellent loudspeakers for the task, their biggest hindrance was their placement which was about three feet above ear level.
My initial solution was to toe them down using door stoppers and a thin rubber pad to help decouple them from the base of the entertainment center. This was certainly a very good cost effective and practical solution, though I never seemed to be entirely satisfied with the look (especially when viewing the speakers on the sides) or even the sound. Thus I called on Auralex for their suggestions. It was then that they introduced me to the concept of their MoPADs. They didn't offer them to me as a sonic cure all, but as a means to perfectly decouple the speakers from the entertainment center, while also providing a more optimal downward angle towards the seating area and even more importantly a more aesthetically pleasing solution for my significant other. Hmm, so I could kill three birds with one stone? Where do I sign up?
Auralex MoPADs Setup, Listening Tests and Conclusion
The MoPADs come in two pairs per package (four individual units) which can serve a pair of normal sized
(under 1cu^ft) bookshelf speakers or one center channel speaker mounted horizontally.
The MoPAD
base is about 1 inch thick, 12 inches deep, 4 inches wide and with the use of their wedge adjustor pads
(included in the kit) provisions for variable pitch of your speakers between -8, -4, 0, +4 and +8
degrees.
Since I obviously needed to pitch my speakers downward, I oriented the wedge adjustor
pad so that the speakers would fire at a pitch of 8 degrees downward.
For those installing a
center channel on a floor or stand under a projection screen, pitching the speaker upward would be most
useful. I intend on taking full advantage of this once I get my primary reference system up and
running.
My reference bookshelf speakers are a relatively small profile design (8 inches wide) the exact width of two MoPADs placed together - making for a perfect fit.
My center channel required a pair of MoPAD kits spaced out about 3.5 inches.
At this point, I was ready to dig into some listening tests. Listening tests you say? Has the Prez of Audioholics turned to the dark side of esoteric audio? I certainly hope not. While I initially wasn't expecting any sonic miracles from this tweak, I did find it intriguing to determine if I thought I could subjectively hear a difference in my setup.
Disclaimer to the Objectivists: Red Alert Red Alert!
This is by no means a scientifically controlled DBT. I am fully aware that audio memory can play tricks on the mind but I found little reason to bring out the big guns in this review since the focus of this product was really to help properly position the speakers and decouple them from the surface they are to be placed upon. At such a contest the MoPADs delivered exactly as promised.
Listening Tests
I've been spending a lot of time lately listening to the fabulous recorded demo disc from AIX records. Recordings like this really help drive my point home about the Dumbing Down of Audio and the complacent tolerance most consumers have towards low fidelity, highly compressed media. Recordings like those found on this disc truly make your playback system live up to its full potential. Before installing the MoPADs, the surround experience on this disc was nothing short of stunning. The bass was pronounced and the instruments sounded real and uncompressed. After the MoPAD installation, I felt as if the vocals from the front soundstage became more focused and the upper mid bass sounded even tighter and more defined. The pitch downward from the MoPADs allowed for a more uniform dispersion of the front three speakers showering the listening area with a more direct sound experience and bringing me closer to the performance rather than reflections and refractions caused by poor speaker placement and the room. I couldn't help but to give my speakers more juice because for the first time since I installed them above the entertainment center, they seemed to be properly imaging. The nasally characteristic caused by interaction between the entertainment center and the speakers and inadequate pitch towards the listener I had heard before seemed to be significantly reduced. Lowen and Navarro's "Cold Outside" sounded absolutely stunning. The vocals came across as dynamic and airy, while the instruments were clearly defined and well placed within the listening space.
Shameless Plug for AIX Records: We've finally found a producer and recording/mix engineer that knows how multi channel audio should sound. Now if they could only ramp up with record deals from more popularly known jazz and rock artists we'd be good to go.
Recommendations
If you've got no choice but to install your speakers on top of an entertainment center or a poorly inert stand or shelf, this is the "must have" product to decouple your speakers and eliminate resultant sound colorations caused by nasty resonances. The variable pitch capability of these isolator pads is very useful for speaker installations that aren't at or near ear level. The only minor gripe I had was that the MoPADs themselves are about 1.25" in height towards the front of the speaker, which will of course raise an already elevated speaker even higher. Overall, this is a small price to pay for sound isolation and properly pitching your speakers to the listening position.
While we still have compelling world issues to deal with, at least we can rest safely knowing there are companies making product to better the sound of our systems. The Auralex MoPADs isolation devices are worth their price of admission and are highly recommended!
MSRP: $39.95 / 2 pair
www.auralexelite.com
— Excellent
— Very Good
— Good
— Fair
— Poor
Metric | Rating |
Ergonomics & Usability | ![]() ![]() ![]() ![]() ![]() |
Ease of Setup/Programming/Integration | ![]() ![]() ![]() ![]() ![]() |
Performance | ![]() ![]() ![]() ![]() ![]() |
