EMP Tek Impression Series E5TiR Floorstanding Loudspeaker Review
- Product Name: Impression Series E5TiR
- Manufacturer: EMP Tek
- Performance Rating:
- Value Rating:
- Review Date: October 27, 2009 06:10
- MSRP: $ 730/Pair
- Specifications
- Dual 6½ " (203mm) Poly-matrix Woofers
- 5¼" (133mm) Aluminized Poly-matrix Woofer
- 1" (25mm) Fabric Dome Tweeter
- Recommended Power 50-150 Watts
- Impedance 6 Ohms
- Frequency Response 50Hz-20kHz ±3dB
- Crossover Frequency 120 Hz/ 3,000 Hz
- Sensitivity 87dB (2.83V@1m)
- Dimensions 8½" W x 35½" H x 12¼" D (216mm W x 902mm H x 311mm D)
- Weight 35 lbs. (15.88 kg.)
- Available in High Gloss Red Burl or Black Wood
- PRICE!!!!!!
- Aesthetics
- Performance
- At this price point I'd be a fool to complain about much but…
- Unstable (needs better footing options including something for hardwood/tile)
- Dual pairs of binding posts invites damage
- Height challenged
Introduction
By now, you've probably heard of the EMP Impression Series E5Ti speakers, they are the ones going for the incredibly low asking price of $400 a pair. There must be something wrong with them, right? That's what our reviewer thought at first too. But after hearing the E5Ti speakers, his mind wasn't just changed, it was blown.
Recent Forum Posts:
esox72 posts on November 05, 2009 16:59
Thanks. Thats kind of what I thought.
Imitation posts on November 05, 2009 10:28
esox72;643133
One quick question. I have an RX-V465 and would like to buy these speakers. I am currently using 8 ohm speakers from an old HTIB. Can I run both 8 ohm and 6 ohm speakers at the same time? I will be changing the rest of the speakers out over time.
I wouldn't see why not. The EMP 5.1 package has 6ohm fronts and the bookshelves are rated at 8ohms. Doubt they'd sell em like that if you couldn't run them all together off a receiver.
esox72 posts on November 04, 2009 18:06
Tungsten06GT posts on November 04, 2009 10:58
Ahhh thanks! I couldn't see it in the smaller picture I was looking at. That helps a ton though.
Matt34 posts on November 04, 2009 10:54
Tungsten06GT;642964
Oh, looking at the back of the vsx-21, I couldn't find an RCA hookup for the sub...
In the pre-out box there is a lone Red RCA output that is inside a white box labeled "subwoofer".
