Featured Articles
Up one levelRecently Reviewed
Audioholics Store $750 Audio System
Clint DeBoer — last modified September 16, 2009 13:37
From time to time the Audioholics Store puts together systems it feels are simply excellent purchases for our readers and which represent an excellent value for consumers. The $750 system, while it won't include such niceties as a display or power conditioner, will present an excellent upgrade of audio and video capabilities for those looking to make the move into a true 5.1 home theater system.
Audioholics Store $1000 Audio System
Clint DeBoer — last modified September 16, 2009 14:16
The $1000 system from The Audioholics Store delivers a solid surround sound experience for a bargain price. While the $1000 system won't include a flat panel display, it does add upgraded features & components such as a power conditioner and a more capable A/V receiver. This level of system will present a more than subtle upgrade of the audio and video capabilities of a television or even a soundbar. For those looking to make the move into a true 5.1 home theater system, this is going to be a major upgrade.
The $3500 Balanced AV System
Gene DellaSala — last modified May 05, 2009 20:30
The following is an entry-level system designed to balance the desire for optimal quality of both audio and video aspects of the room. Key things to note are that this could be a front projection system (no screen, DIY screen, or an inexpensive pull-down “starter” product), or a flat panel or rear projection system depending upon the desired screen size.
The $25k Home Theater System
Clint DeBoer , Gene DellaSala — last modified April 04, 2008 19:48
Now we're talking home theater... The $25K recommended system takes some of the best equipment for the money and puts it together for an impressive immersive environment. Whether you're a two-channel nut or a fan of movies on the big screen, this system will deliver the satisfaction for all types of source material. These products are some of the best performers available that won't make you take out a second mortgage.
The $1000 Bare Bones System
Clint DeBoer — last modified April 07, 2008 17:20
Looking for an entry level home theater system? This is what we recommend for $1000. It will keep you from getting ripped off by the big box stores and deliver more than the average home theater in a box.
The $75,000 Home Theater System
Clint DeBoer , Gene DellaSala — last modified December 11, 2008 15:36
We decided to go all out on this $75,000 and include mostly top notch products priced right at the crest of that place your budget hits the point of diminishing returns. This means we included some of the finest A/V products "smart" money can buy. You can possibly do better, but not likely for the price.
The $12k Home Theater System
Clint DeBoer — last modified February 07, 2007 19:00
So, you are thinking about putting together a Home Theater system and have a $12,000 budget? It's very easy to spend $12,000. All you have to do is buy a Flagship receiver or Processor / Amp combo for $4500, a set of mid to high end speakers for $3000-$4000, a high end DVD player for $1200, an HDTV Rear Projector for $3000 (or smaller Plasma for $4000), some cables, and you're done! Right?
The $7500 Video-centric System
Clint DeBoer — last modified June 17, 2008 23:10
In this system we've added a few more things. We've integrated remote control choices, terminated cables and a healthier budget on just about all components.
The $5000 Video-centric System
Clint DeBoer — last modified March 07, 2008 15:31
This system tilts decidedly towards a preference for making sure the video aspects are favored. This system is for home theater buffs who may not spend as much time listening to two-channel music, but who favor the high-impact value of a good theater-killer system. Grab the popcorn, and a pen and paper and let's get started...
